Unless I'm missing something, for hard real-time systems a cache is absolutely useless... I am new to the c6x family of DSPs (and DSPs with data caches) and although I like the c6x archetecture, there is something that is bothering me: the Program/Data cache. What good is a data-cache when I have to set my parameters (ie buffersize, numtaps, ect) for the worst case scenario (ie a 100% cache miss?). I'm working on a hard real-time system where a missed dealine cannot be tolerated. I suppose there might be some way to "prime the cache" like accessing all the data the algorithm would access first but this seems wastefull. Worse yet, there seems to be no way to turn off the cache off to level out the performance which really irritates me. I could understand this design decision if most DSP applications were not hard-realtime (like a Windows media player or something), but arent a majority of DSP applications hard real-time? Although I hate to be cynical, the only logical reason to use cache would seem to be to boost the paper specs on the part.
Why use cache on a DSP? (c6x specifically)
Started by ●January 5, 2004
Reply by ●January 5, 20042004-01-05
I can't speak for the C6x, but in my experience (primarily SHARC), you can often guarantee that the instruction cache will be used, for example with non-interruptible looped code. On the second, etc. times through the loop, with my code I know I will get 100% cache hits. With the data cache, is it a read-ahead type (again I'm not familiar with the C6X)? If so, I would think you could also guarantee cache hits with non-interruptible sequential access code. There are definitely situations where the cache is useful and you can count on hits. Whether yours is one of those or not, I do not know. -Jon "awestport" <awestport@hotmail.com> wrote in message news:427e5468.0401051230.2f49b9a@posting.google.com...> Unless I'm missing something, for hard real-time systems a cache is > absolutely useless... > > I am new to the c6x family of DSPs (and DSPs with data caches) and > although I like the c6x archetecture, there is something that is > bothering me: the Program/Data cache. What good is a data-cache when I > have to set my parameters (ie buffersize, numtaps, ect) for the worst > case scenario (ie a 100% cache miss?). I'm working on a hard real-time > system where a missed dealine cannot be tolerated. I suppose there > might be some way to "prime the cache" like accessing all the data the > algorithm would access first but this seems wastefull. > > Worse yet, there seems to be no way to turn off the cache off to level > out the performance which really irritates me. > > I could understand this design decision if most DSP applications were > not hard-realtime (like a Windows media player or something), but > arent a majority of DSP applications hard real-time? > > Although I hate to be cynical, the only logical reason to use cache > would seem to be to boost the paper specs on the part.
>>>>> "awestport" == awestport <awestport@hotmail.com> writes:awestport> Unless I'm missing something, for hard real-time systems a cache is awestport> absolutely useless... I used to use a Masscomp computer with a 68K and cache. It had a hard real-time OS. awestport> Although I hate to be cynical, the only logical reason to use cache awestport> would seem to be to boost the paper specs on the part. Maybe putting zero wait-state memory of the size and speed people want is too costly in silicon or power? Pick a different part if you don't like the cache on the c6x? Personally, I expect almost all high-end DSPs to come with cache, if they don't already. Ray
In article <427e5468.0401051230.2f49b9a@posting.google.com>, awestport <awestport@hotmail.com> wrote:>Unless I'm missing something, for hard real-time systems a cache is >absolutely useless...Depends. The caches are guaranteed to help the second time thru any loop or data set that fits completely inside the caches, unless interrupted in a manner which requires cache line reloads. Thus, all small noninterruptable loops are accelerated, and even interruptable loops, if the peak possible interrupt rate is significantly slower than the loop repeat rate. The amount of acceleration depends on whether and by how much cache latency is less than memory latency in cycles. There are also tricks that can be played, such as allocating instructions and data in interrupt routines to locked cache lines or to cache lines orthogonal from those used by all other routines (an exercise for the student, etc.) So it's not useless in many hard real-time cases, just harder to analyze.>Worse yet, there seems to be no way to turn off the cache off to level >out the performance which really irritates me.If there are cache invalidate instructions, you can use them to slow down performance to simulate your expected peak worse case rate of cache misses. IMHO. YMMV. -- Ron Nicholson rhn AT nicholson DOT com http://www.nicholson.com/rhn/ #include <canonical.disclaimer> // only my own opinions, etc.
Though I have not used the C6x series, I have used many TI DSPs, and every one of them has an easy way to disable the cache (i.e., one bit in a control register). Unless TI really broke with their ways, there is probably a way to disable it. Jim Gort "awestport" <awestport@hotmail.com> wrote in message news:427e5468.0401051230.2f49b9a@posting.google.com...> Unless I'm missing something, for hard real-time systems a cache is > absolutely useless... > > I am new to the c6x family of DSPs (and DSPs with data caches) and > although I like the c6x archetecture, there is something that is > bothering me: the Program/Data cache. What good is a data-cache when I > have to set my parameters (ie buffersize, numtaps, ect) for the worst > case scenario (ie a 100% cache miss?). I'm working on a hard real-time > system where a missed dealine cannot be tolerated. I suppose there > might be some way to "prime the cache" like accessing all the data the > algorithm would access first but this seems wastefull. > > Worse yet, there seems to be no way to turn off the cache off to level > out the performance which really irritates me. > > I could understand this design decision if most DSP applications were > not hard-realtime (like a Windows media player or something), but > arent a majority of DSP applications hard real-time? > > Although I hate to be cynical, the only logical reason to use cache > would seem to be to boost the paper specs on the part.
Reply by ●January 6, 20042004-01-06
awestport@hotmail.com (awestport) wrote in message news:<427e5468.0401051230.2f49b9a@posting.google.com>...> Unless I'm missing something, for hard real-time systems a cache is > absolutely useless... > > I am new to the c6x family of DSPs (and DSPs with data caches) and > although I like the c6x archetecture, there is something that is > bothering me: the Program/Data cache. What good is a data-cache when I > have to set my parameters (ie buffersize, numtaps, ect) for the worst > case scenario (ie a 100% cache miss?). I'm working on a hard real-time > system where a missed dealine cannot be tolerated. I suppose there > might be some way to "prime the cache" like accessing all the data the > algorithm would access first but this seems wastefull. > > Worse yet, there seems to be no way to turn off the cache off to level > out the performance which really irritates me. > > I could understand this design decision if most DSP applications were > not hard-realtime (like a Windows media player or something), but > arent a majority of DSP applications hard real-time?The cache is there to cut down on the cost of the part. It is true that you must be aware of it and how to work around it's limitations to get maximum performance from the part... Instruction cache: No problem, It will quickly fill within the first loop or two of your critical code. If your really worried, execute your critical code once before the timing requirement is in effect. Data cache: The key is to make sure that all data is accessed once before the critical code executes so it is fluent in the cache: Take a fir filter for example... You are probably circular buffering your X data, so it will be in the cache. For your coefficents, just read them once before the timing requirement is needed. One caveot though: If your data+coefficients are bigger than the cache, you will take some misses. Look at the cache sizes and plan for this.> Although I hate to be cynical, the only logical reason to use cache > would seem to be to boost the paper specs on the part.LOL. It's really just to save on expensive, wide memory. The c67x can access up to 128 bits of data memory and 256 bits of program memory (8 32 bit instructions) per cycle. The reason for this cache is to cut down on the amount of this wide memory and thereby the cost.
> What good is a data-cache when I > have to set my parameters (ie buffersize, numtaps, ect) for the worst > case scenario (ie a 100% cache miss?).The cache guarantees less that 100% cache miss... that's why it's there! For my experience (And you'll have to trust me on this one), the cache introduces a degradation of 5%-15% in performance, depending on the application. However, with the introduction of caches, zero-wait-state memories can be eliminated, and thus the frequency can be increased (usually by more than 15%). So, in general The customers gets a cheaper, faster DSP !!! Also, don't forget that the cache includes mechanisms like prefetch and locking to improve its' effectiveness.> Worse yet, there seems to be no way to turn off the cache off to level > out the performance which really irritates me.I'm sure there is -- you just didn't find it. Look in the user manual of the device. In the MSC8102 (Motorola Quad-Core SC140), the ICache and Prefetch are fully controllable.> Although I hate to be cynical, the only logical reason to use cache > would seem to be to boost the paper specs on the part.No.. It's to reduce prices, increase frequency, and decrease power.
erez_st@hotmail.com (Erez Steinberg) writes: <snip> MJT> awesport wrote:> > Worse yet, there seems to be no way to turn off the cache off to level > > out the performance which really irritates me. > > I'm sure there is -- you just didn't find it. > Look in the user manual of the device. > In the MSC8102 (Motorola Quad-Core SC140), the ICache and Prefetch are > fully controllable. >The C6x11 (low-cost) parts cannot disable the L1 cache, although the L2 cache can be disabled and used as normal SRAM. This appears to be to reduce the required bandwidth beyond the L1 boundary, as someone else pointed out, the C6x core can read 256-bits of code and 128-bits of data each cycle. Providing this from an SRAM the size of the L2 cache would be expensive. <snip> -- martin.j.thompson@trw.com TRW Conekt, Solihull, UK http://www.trw.com/conekt
> bothering me: the Program/Data cache. What good is a data-cache when I > have to set my parameters (ie buffersize, numtaps, ect) for the worstI am writing code on a C6713 for a hard disk audio recorder which uses the DSP for everything from audio processing to the GUI. The binary program takes up about 3Mbytes of SDRAM. The C6713 has 256Mbytes of internal ram that can be used as cache and/or internal program/data RAM. With the cache turned off I get a 50X hit in performance (not 50 percent, 50 times)! The real-time audio processing interrupt is too large to fit in internal memory. Without the cache I would have to plop down a few Mbytes of fast SRAM to make this work almost as well. In this situation the real-time task only takes up 80% or so or the DSP processing power. The remaining 20% is used for FireWire and GUI operations. Therefore if one of my audio interrupts takes an extra 19% of time to execute, it will not cause a problem. As long as there is an /average/ of 20% left over for the non-real-time tasks to do their thing then every one is happy. BTY, here is a link the Deva audio recorder that I am referring to: http://www.zaxcom.com/audio/devas.shtml that's a 320x240x18 color touch screen on the front... -howy zaxcom engineer
Reply by ●January 7, 20042004-01-07
howard@zaxcom.com (howy) writes:> > bothering me: the Program/Data cache. What good is a data-cache when I > > have to set my parameters (ie buffersize, numtaps, ect) for the worst > > I am writing code on a C6713 for a hard disk audio recorder which uses > the DSP for everything from audio processing to the GUI. The binary > program takes up about 3Mbytes of SDRAM. The C6713 has 256Mbytes ofk Bytes, surely :-) ^^^^^^> internal ram that can be used as cache and/or internal program/data > RAM. > > With the cache turned off I get a 50X hit in performance (not 50 > percent, 50 times)! The real-time audio processing interrupt is too > large to fit in internal memory.Sounds like a big interrupt service! Can it not be split, so that the *really really* time critical bits can live in internal RAM all the time? <snip> Cheers, Martin -- martin.j.thompson@trw.com TRW Conekt, Solihull, UK http://www.trw.com/conekt
