EMD-Empirical Mode Decomposition
Started by joanna ●October 24, 2011
Hello.
I have a question and hope someone can help me. I'm dealing with the EMD
since a few weeks and have a problem with one aspect.
The first step is to identify all the local extrema in the test data x. My
question is the following:
Is every extreme I find, a real extreme? I have for example sinus signal
that is superimposed by noise. So it might be, that I found a lot of
extreme values sequently. I have for example a maximum on the position x(5)
and a minimum on x(6) and on x(7) again a maximum. Is that right, or shall
I eliminate the extreme on x(6)? And must all Maxima be positiv and all
Minima be negativ?
I hope someone can help me. Sorry for my english. English isn't my mother
tongue. I hope you still understand me.
Best regards
Joanna
On 10/24/2011 11:49 AM, joanna wrote:
> Hello. > > I have a question and hope someone can help me. I'm dealing with the EMD > since a few weeks and have a problem with one aspect. > > The first step is to identify all the local extrema in the test data x. My > question is the following: > > Is every extreme I find, a real extreme? I have for example sinus signal > that is superimposed by noise. So it might be, that I found a lot of > extreme values sequently. I have for example a maximum on the position x(5) > and a minimum on x(6) and on x(7) again a maximum. Is that right, or shall > I eliminate the extreme on x(6)? And must all Maxima be positiv and all > Minima be negativ? > > I hope someone can help me. Sorry for my english. English isn't my mother > tongue. I hope you still understand me.
Joanna, Your question is perfectly clear. Your use of English is in fact quite good. I wish most Americans spoke a foreign language as well as you write English. You ask for a definition of extremum that must depend on your application. With noisy data, the rule "A point both of whose neighbors are larger is a minimum, and both of whose neighbors are smaller is a maximum" clearly needs to be modified. You ask what modification is correct. There is probably no correct way, only a best compromise that depends on what the results are used for. Do you need results as the data are being collected, or can you wait? Local minima can be positive and local maxima can be negative by the most general definition. You may have other constraints. One way I dealt with your problem -- I had the luxury of analyzing data already collected and stored -- was by smoothing the data with a low-pass filter, finding extrema in the usual way, then referring the corrected* time of of the extremum back to the original data. _____________________ * Filtering delays the data. It also corrupts the beginning and end for a time equal to about double the delay.) Jerry -- Engineering is the art of making what you want from things you can get.
Hi ,
>One way I dealt with your problem -- I had the luxury of analyzing data >already collected and stored -- was by smoothing the data with a >low-pass filter, finding extrema in the usual way, then referring the >corrected* time of of the extremum back to the original data. >_____________________
exactly the same way I done it. I'm relieved that my idea wasn't so bad. But I have another question. When I compute the instanteanous frequency I receive also negative frequencies. What shall I do with them? Best regards Joanna
On 10/25/2011 10:14 AM, joanna wrote:
> Hi , > >> One way I dealt with your problem -- I had the luxury of analyzing data >> already collected and stored -- was by smoothing the data with a >> low-pass filter, finding extrema in the usual way, then referring the >> corrected* time of of the extremum back to the original data. >> _____________________ > > exactly the same way I done it. I'm relieved that my idea wasn't so bad. > > But I have another question. When I compute the instanteanous frequency I > receive also negative frequencies. > > What shall I do with them?
Whatever one might believe about the actual existence of negative frequencies, they are part of the simplified mathematics that we use in our calculations. That is, replacing trigonometry with complex arithmetic by replacing cos(x) with ((exp(ix) + exp(-ix))/2 introduces negative frequencies into our work. (Note the exp(-ix).) Nevertheless, I remain puzzled. You have a series in the time domain. You want extrema, which are time-domain phenomena. Why involve frequency? Frequency is the rate at which phase changes. The nature of inverse trig functions can make a plot of phase vs. time appear to be discontinuous. For accurate calculations "everywhere", the phase needs to be "unrolled". Are there phase discontinuities in the interval you use for differentiating? Jerry -- Engineering is the art of making what you want from things you can get.
I think there are no phase discontinuities. I compute the phase in matlab
with this:
phase = unwrap(angle(z));
z is the analytic signal. unwrap corrects phase angles to produce smoother
phase plots. I dont't know if that means that i dont't have phase
discontinuities. My know-how in signal prosessing isn't so big :-)
I hope this answear helps ?!?
On 10/25/2011 11:02 AM, joanna wrote:
> I think there are no phase discontinuities. I compute the phase in matlab > with this: > > phase = unwrap(angle(z)); > > z is the analytic signal. unwrap corrects phase angles to produce smoother > phase plots. I dont't know if that means that i dont't have phase > discontinuities. My know-how in signal prosessing isn't so big :-) > > I hope this answear helps ?!?
Discontinuities aren't a problem except that unwrap() sometimes fails. Why do you need frequency at all? What are you doing? Jerry -- Engineering is the art of making what you want from things you can get.
On Oct 25, 11:30&#4294967295;am, Jerry Avins <j...@ieee.org> wrote:
> On 10/25/2011 11:02 AM, joanna wrote: > > > I think there are no phase discontinuities. I compute the phase in matlab > > with this: > > > phase = unwrap(angle(z)); > > > z is the analytic signal. unwrap corrects phase angles to produce smoother > > phase plots. I dont't know if that means that i dont't have phase > > discontinuities. My know-how in signal prosessing isn't so big :-) > > > I hope this answear helps ?!? > > Discontinuities aren't a problem except that unwrap() sometimes fails. > Why do you need frequency at all? What are you doing? > > Jerry > -- > Engineering is the art of making what you want from things you can get.
Hi Jerry, How is everything is going well. I don't know if you are familiar with EMD, so forgive this if you are. EMD is relatively recent analysis method for non-linear and non-stationary signals. A "bunch" of guys from NASA, NOAA, Naval Research Labs, Naval Surface Warfare, and NC State wrote a paper on it for theRoyal Society around 1999 or 2000. It breaks things down into "intrinic mode functions". With the Hilbert transform the final thing you get is an energy/frequency/time distribution. It looks at signals as basin intrinic mode oscillations and gives instantaneous frequency as a function of time. Thus the need to look at frequency. That's about all I know about it - enough to be VERY dangerous :) Joanna, Is this is what you are studying? Are you using the Royal Society paper as a basis? If so, maybe you can explain the concept behind the Hilbert Spectrum. Maurice Givens
On 10/25/2011 3:34 PM, maury wrote:
> Hi Jerry, > How is everything is going well. I don't know if you are familiar with > EMD, so forgive this if you are. EMD is relatively recent analysis > method for non-linear and non-stationary signals. A "bunch" of guys > from NASA, NOAA, Naval Research Labs, Naval Surface Warfare, and NC > State wrote a paper on it for theRoyal Society around 1999 or 2000. It > breaks things down into "intrinic mode functions". With the Hilbert > transform the final thing you get is an energy/frequency/time > distribution. It looks at signals as basin intrinic mode oscillations > and gives instantaneous frequency as a function of time. Thus the need > to look at frequency. > > That's about all I know about it - enough to be VERY dangerous :) > > Joanna, > Is this is what you are studying? Are you using the Royal Society > paper as a basis? If so, maybe you can explain the concept behind the > Hilbert Spectrum.
Hi Maury, Thanks for asking. I'm fine as long as I get regular maintenance. (Today I arrived at my dentist's at 1:30, had two teeth drilled and filled, and was back in my car at 2:00. Ain't modern times wonderful?) I hope you're well too. Joanna's task, as I understand it, is identifying extrema in a set of data points in the presence of noise. I once attacked a similar problem by low-pass filtering the data to emphasize long-term trends. (My filter's coefficients were read off Pascal's triangle, my own invention and the only kind I knew how to calculate that was better than a boxcar averager. It is a convolution of N two-element averagers. and convinced me that I had better learn something about DSP.) FIR filters introduce known delay and corrupt the ends of the data points. My result was displayed as a graph of the original (unfiltered) data with vertical lines showing the extrema. Fortunately, I could ignore the ends, and dealt with the delay by subtracting the filter's phase delay. I wouldn't be comfortable with this for all data and all uses, but it worked well enough for me. (The data were collected by, operated on, and displayed on a Nicolet oscilloscope.) Joanna wrote that she had done essentially the same thing, so I wondered how frequency came in. I know nothing of EMD, so I ignored the subject line of the thread. Bad! Jerry -- Engineering is the art of making what you want from things you can get.
On Oct 25, 3:15&#4294967295;pm, Jerry Avins <j...@ieee.org> wrote:
> On 10/25/2011 3:34 PM, maury wrote: > > &#4294967295; &#4294967295;... > > > > > > > Hi Jerry, > > How is everything is going well. I don't know if you are familiar with > > EMD, so forgive this if you are. EMD is relatively recent analysis > > method for non-linear and non-stationary signals. A "bunch" of guys > > from NASA, NOAA, Naval Research Labs, Naval Surface Warfare, and NC > > State wrote a paper on it for theRoyal Society around 1999 or 2000. It > > breaks things down into "intrinic mode functions". With the Hilbert > > transform the final thing you get is an energy/frequency/time > > distribution. It looks at signals as basin intrinic mode oscillations > > and gives instantaneous frequency as a function of time. Thus the need > > to look at frequency. > > > That's about all I know about it - enough to be VERY dangerous :) > > > Joanna, > > Is this is what you are studying? Are you using the Royal Society > > paper as a basis? If so, maybe you can explain the concept behind the > > Hilbert Spectrum. > > Hi Maury, > > Thanks for asking. I'm fine as long as I get regular maintenance. (Today > I arrived at my dentist's at 1:30, had two teeth drilled and filled, and > was back in my car at 2:00. Ain't modern times wonderful?) I hope you're > well too. > > Joanna's task, as I understand it, is identifying extrema in a set of > data points in the presence of noise. I once attacked a similar problem > by low-pass filtering the data to emphasize long-term trends. (My > filter's coefficients were read off Pascal's triangle, my own invention > and the only kind I knew how to calculate that was better than a boxcar > averager. It is a convolution of N two-element averagers. and convinced > me that I had better learn something about DSP.) FIR filters introduce > known delay and corrupt the ends of the data points. My result was > displayed as a graph of the original (unfiltered) data with vertical > lines showing the extrema. Fortunately, I could ignore the ends, and > dealt with the delay by subtracting the filter's phase delay. > > I wouldn't be comfortable with this for all data and all uses, but it > worked well enough for me. (The data were collected by, operated on, and > displayed on a Nicolet oscilloscope.) Joanna wrote that she had done > essentially the same thing, so I wondered how frequency came in. I know > nothing of EMD, so I ignored the subject line of the thread. Bad! > > Jerry > -- > Engineering is the art of making what you want from things you can get.- Hide quoted text - > > - Show quoted text
Jerry, I'm doing well too. The way I understand it (and this is very simplistic), she needs to find all the positive peaks, then essentially connect them to form a type of low-pass filter. Then do the same for the negative peaks. Them the two are subtracted (called the intrinic mode function IMF) to get the residule. The process is then repeated for the residule. Each iteration gives an IMF (IMF0, IMF1, ...). Johanna, Is this correct? Maurice
For those with any interest, the royal Proceedings paper is available at: http://webber.physik.uni-freiburg.de/~jeti/studenten_seminar/stud_sem_WS_08_09/Huang_etal98.pdf The title is: The empirical mode decomposition and the Hilbert spectrum for nonlinear and non-stationary time series analysis By Norden E. Huang et al. The empirical modes decompose a complex signal into components for which the instantaneous frequency can be calculated. The empirical modes do not rely on the properties of conventional transform basis functions. YMMV. Dale B. Dalrymple
