tone start/stop detection algorithms?
Started by Ronald H. Nicholson Jr. October 5, 2004
allnor@tele.ntnu.no (Rune Allnor) wrote
> > Check out detection theory. The books by van Loan ought to be a good > starting point: > > van Loan: Detection, estimation and modulation theory, vols I-IV, > Wiley. >
Err, I think you mean van _Trees_. Van Loan is the Matrix Computations dude. Ciao, Peter K.
A similar problem has been solved by S. Kay in his Detection Theory
text: detection of a sinusiod with unknown amplitude, phase,
frequency, and arrival time.  See page 269.
Also note that this is a common problem in radar and sonar.  The
solution to this problem ought to be well known.
Steven Kay, Fundamentals of Statistical Signal Processing, Vol II -
Detection Theory
- Jesse
allnor@tele.ntnu.no (Rune Allnor) wrote in message news:<f56893ae.0410052231.92ae9ee@posting.google.com>...
> "Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message news:<Ed6dnWT8paTLvf7cRVn-iw@centurytel.net>... > > > Using shorter FFT windows is equivalent to using wider bandwidth - as > > described above. So, the SNR will be reduced if you do this. > > Using overlapped FFTs might be a better way to go. > > I would test wavelets before using STFTs. I don't have any experience > with wavelets, though, but STFTs are not awfully good to do detailed > transient analysis. > > > The ultimate is to overlap the FFTs by N-1 samples and to create an output > > sample at each frequency as often as input temporal samples occur. Then you > > can look at each frequency with lots of time samples. The output will still > > have a rise time equivalent to the length of the temporal epoch of the > > data - length of the FFT. This may not be practical in the end but it could > > help answer some of your questions. > > Check out detection theory. The books by van Loan ought to be a good > starting point: > > van Loan: Detection, estimation and modulation theory, vols I-IV, > Wiley. > > Rune
p.kootsookos@iolfree.ie (Peter Kootsookos) wrote in message news:<3fca8095.0410060311.73fb69e1@posting.google.com>...
> allnor@tele.ntnu.no (Rune Allnor) wrote > > > > Check out detection theory. The books by van Loan ought to be a good > > starting point: > > > > van Loan: Detection, estimation and modulation theory, vols I-IV, > > Wiley. > > > > Err, I think you mean van _Trees_. Van Loan is the Matrix Computations dude.
Ouch!! Of course you are right. Thanks for the correction. Rune
