This is a general question about acoustic echo cancellation based on NLMS. If an AEC receives a speaker signal which has been processed by an automatic gain control algorithm, will that have any adverse effects on the AEC's performance? If the change in speaker gain level is too sudden or far from being smooth, doesn't that result in the AEC having to re-adapt? Thank you.
Automatic gain control and acoustic echo cancellation
Started by ●November 2, 2011
Reply by ●November 2, 20112011-11-02
John McDermick wrote:> This is a general question about acoustic echo cancellation based on > NLMS. > > If an AEC receives a speaker signal which has been processed by an > automatic gain control algorithm, will that have any adverse effects > on the AEC's performance? > > If the change in speaker gain level is too sudden or far from being > smooth, doesn't that result in the AEC having to re-adapt?AGC inside EC loop makes the system nonlinear -> system model is inadequate -> EC doesn't work. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
> > >John McDermick wrote: >> This is a general question about acoustic echo cancellation based on >> NLMS. >> >> If an AEC receives a speaker signal which has been processed by an >> automatic gain control algorithm, will that have any adverse effects >> on the AEC's performance? >> >> If the change in speaker gain level is too sudden or far from being >> smooth, doesn't that result in the AEC having to re-adapt? > >AGC inside EC loop makes the system nonlinear -> system model is >inadequate -> EC doesn't work.If you can link the AGC to the EC you can make it all come right, but if they work independently, you're screwed Steve
If the speaker signal path looks like this: ----- speaker signal ----> [AGC] ----- gain corrected speaker signal ----> [AEC] -----> sout does that constitute the AGC being inside the EC loop ? I would say no, but I might be missing something?
