controller design: Frequency domain or state space approach?
Started by steve nospam November 13, 2011
If I want to learn controller design, which is better to learn, do it
in
state space (pole placement, etc..) or use frequency domain (transfer
function,  PID, etc.. classical approach?).
What is done in practice, i.e. real world?
I know for MIMO, one has to use state space. But for SISO, which
approach would you choose?
thank you,
Steve
On Nov 13, 9:22&#4294967295;am, steve nospam <steve.nosp...@gmail.com> wrote:
> If I want to learn controller design, which is better to learn, do it > in > state space (pole placement, etc..) or use frequency domain (transfer > function, &#4294967295;PID, etc.. classical approach?). > > What is done in practice, i.e. real world? > > I know for MIMO, one has to use state space. But for SISO, which > approach would you choose? > > thank you, > Steve
Learn stae space. Far more versatile, and contains 'classical' approach as a sub-subject. Rune
On Sun, 13 Nov 2011 07:07:21 -0800, Rune Allnor wrote:
> On Nov 13, 9:22&nbsp;am, steve nospam <steve.nosp...@gmail.com> wrote: >> If I want to learn controller design, which is better to learn, do it >> in >> state space (pole placement, etc..) or use frequency domain (transfer >> function, &nbsp;PID, etc.. classical approach?). >> >> What is done in practice, i.e. real world? >> >> I know for MIMO, one has to use state space. But for SISO, which >> approach would you choose? >> >> thank you, >> Steve > > Learn state space. Far more versatile, and contains 'classical' approach > as a sub-subject.
Inneresting. 'cause my take on it is to learn the classical approach, because it works well in almost all cases, you can often do your "system ID" with sine sweeps (dead easy, and fairly easy to accommodate mild system nonlinearities), and it makes a nice mental framework from which to springboard to state-space. As far as I can tell, there are three ways (well, four) to do "modern" control design: 1: Use naive pole placement, and fail because your system is insufficiently robust. 2: Use pole placement, and succeed because you've been doing it for years on similar plants and you know how to fake a robust design. Characterized by the statement "but I only choose target poles that'll work". 3: Use robust design techniques (I.e. H-infinity) that take parameter variation into account, and which are based on mathematical methods that take a considerable amount of work to wrap your brain around. 4: Learn how to type in Matlab or Scilab, and use the toolbox functions for H-infinity controller design that you should only attempt when you understand the math. This is the "million monkeys with typewriters and we're waiting for Othello to pop out" solution, except that there's only one monkey and you're it. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Nov 13, 9:22&#4294967295;pm, steve nospam <steve.nosp...@gmail.com> wrote:
Learn classical control first - always. Then state-space. State space has no handle on things like bandwidth which is very important. If you go H infinity then you can kind of mix the two. No point in trying to design a controller if you don't understand phase-margin though. Hardy
On 13 Nov, 18:28, Tim <t...@seemywebsite.please> wrote:
> On Sun, 13 Nov 2011 07:07:21 -0800, Rune Allnor wrote: > > On Nov 13, 9:22&nbsp;am, steve nospam <steve.nosp...@gmail.com> wrote: > >> If I want to learn controller design, which is better to learn, do it > >> in > >> state space (pole placement, etc..) or use frequency domain (transfer > >> function, &nbsp;PID, etc.. classical approach?). > > >> What is done in practice, i.e. real world? > > >> I know for MIMO, one has to use state space. But for SISO, which > >> approach would you choose? > > >> thank you, > >> Steve > > > Learn state space. Far more versatile, and contains 'classical' approach > > as a sub-subject. > > Inneresting. &#65533;'cause my take on it is to learn the classical approach, > because it works well in almost all cases,
The intro chapter in Friedland's book on control theory, http://www.amazon.com/Control-System-Design-Introduction-State-Space/dp/0486442780/ref=sr_1_1?ie=UTF8&qid=1321206179&sr=8-1 contains some rather interesting comparisions between the 'classical' western approach to contro theory, and the Russian approach that started from the state space POV. After having read that chapter, I will never tout the 'classic' approach ever again. It seems it is merely the lazy jack-of-all-trades-but- master- of-none's approach to the subject. Yes, it works well a lot of the time, but when the going gets though the state space approach - according to Friedland - comes out on top. Rune
On Sun, 13 Nov 2011 09:48:16 -0800, Rune Allnor wrote:
> On 13 Nov, 18:28, Tim <t...@seemywebsite.please> wrote: >> On Sun, 13 Nov 2011 07:07:21 -0800, Rune Allnor wrote: >> > On Nov 13, 9:22&nbsp;am, steve nospam <steve.nosp...@gmail.com> wrote: >> >> If I want to learn controller design, which is better to learn, do >> >> it in >> >> state space (pole placement, etc..) or use frequency domain >> >> (transfer function, &nbsp;PID, etc.. classical approach?). >> >> >> What is done in practice, i.e. real world? >> >> >> I know for MIMO, one has to use state space. But for SISO, which >> >> approach would you choose? >> >> >> thank you, >> >> Steve >> >> > Learn state space. Far more versatile, and contains 'classical' >> > approach as a sub-subject. >> >> Inneresting. &#65533;'cause my take on it is to learn the classical approach, >> because it works well in almost all cases, > > The intro chapter in Friedland's book on control theory, > > http://www.amazon.com/Control-System-Design-Introduction-State-Space/
> > contains some rather interesting comparisions between the 'classical' > western approach to contro theory, and the Russian approach that started > from the state space POV. > > After having read that chapter, I will never tout the 'classic' approach > ever again. It seems it is merely the lazy jack-of-all-trades-but- > master- > of-none's approach to the subject. > > Yes, it works well a lot of the time, but when the going gets though the > state space approach - according to Friedland - comes out on top.
Indeed it does -- but why use a lathe when a pocket knife will do splendidly? -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On 13 Nov, 21:38, Tim <t...@seemywebsite.please> wrote:
> On Sun, 13 Nov 2011 09:48:16 -0800, Rune Allnor wrote: > > > Yes, it works well a lot of the time, but when the going gets though the > > state space approach - according to Friedland - comes out on top. > > Indeed it does -- but why use a lathe when a pocket knife will do > splendidly?
That was not the question. The OP asked where to invest his efforts. Just out of curiousity: If you, present-day TimW, were given the opportunity to rewind the calender 20 or 30 or whatever, years, and give your younger Self and advice as he were to choose his first class or course on control theory, what would you tell him? "Take the plain vanilla class now and struggle with state space later on, amongst running your company and handling a family"? Or "get to grips with the hard stuff right away, now that you are young and committed to studying"? Rune
steve nospam wrote:
> If I want to learn controller design, which is better to learn, do it > in > state space (pole placement, etc..) or use frequency domain (transfer > function, PID, etc.. classical approach?).
It doesn't matter. Learn something. Eventually it will make sense.
In practice, controllers are tweaked. There are too many unknowns and intractables.
A highly scientific method of Ziegler and Nichols ? Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Sun, 13 Nov 2011 13:08:55 -0800, Rune Allnor wrote:
> On 13 Nov, 21:38, Tim <t...@seemywebsite.please> wrote: >> On Sun, 13 Nov 2011 09:48:16 -0800, Rune Allnor wrote: >> >> > Yes, it works well a lot of the time, but when the going gets though >> > the state space approach - according to Friedland - comes out on top. >> >> Indeed it does -- but why use a lathe when a pocket knife will do >> splendidly? > > That was not the question. The OP asked where to invest his efforts. > > Just out of curiousity: If you, present-day TimW, were given the > opportunity to rewind the calender 20 or 30 or whatever, years, and give > your younger Self and advice as he were to choose his first class or > course on control theory, what would you tell him? "Take the plain > vanilla class now and struggle with state space later on, amongst > running your company and handling a family"? Or "get to grips with the > hard stuff right away, now that you are young and committed to > studying"? > > Rune
I would say "take the basics first so that you can understand the fancy stuff when you come to it". My understanding of state-space control was very much informed by my understanding of classical control theory, just as my day-to-day use of transfer functions for characterizing SISO systems is very much informed by my understanding of the state-space reality that underpins any system that happens to be single-input, single output. Classical design methods work quite well when you have a SISO (or even "few-input, few-output") systems that are difficult to characterize from first principals (e.g., the belt-drive system that I'm working with right now for a customer), but which are amenable to swept-sine or other relatively easy frequency-domain measurement techniques. State-space design methods work quite well when you have a system which is easy to characterize from first principals well enough to meet your performance goals. This includes systems that tend to vary, 'meta systems' where you want to write a reusable controller to work with a class of systems, systems that have distinct nonlinearities that render any frequency-domain testing difficult to interpret, etc. Since I use both state-space and classical methods quite profitably, it's going to be hard to talk me out of one or the other -- just as you'd have a hard time of talking me out of either my lathe or my pocket knife. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Sun, 13 Nov 2011 15:31:55 -0600, Vladimir Vassilevsky wrote:
> steve nospam wrote: > >> If I want to learn controller design, which is better to learn, do it >> in >> state space (pole placement, etc..) or use frequency domain (transfer >> function, PID, etc.. classical approach?). > > It doesn't matter. Learn something. Eventually it will make sense. > >> What is done in practice, i.e. real world? > > In practice, controllers are tweaked. There are too many unknowns and > intractables.
Or they are really, really dumbed down as far as the performance that they deliver vs. the performance that their particular plant _could_ deliver. And even then they're tuned and tweaked, sometimes.
>> I know for MIMO, one has to use state space. But for SISO, which >> approach would you choose? > > A highly scientific method of Ziegler and Nichols ?
Even Ziegler and Nichols were up front about their rules-based tuning being ad-hoc, and IIRC they state that their tuning is "good for most industrial plants" or some such -- in other words, they pulled those numbers out of their donkey*. * I still don't understand that figure of speech. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
