>"Sam (r鰮 sans -no-sp-am)" <totalsam-no-sp-am@hotmail.com> wrote inmessage>news:3ff754cd$0$726$5402220f@news.sunrise.ch... >> Hi all ! >> >> Thanks for reading ! I would like to design a 1st order digital highpass>> filter with a 50 us time constant. The analog transfer function is >> Ha(s)=50E-6*s/(1+50E-6*s). >> >> Then I use the bilinear transformation. Sampling freq is 48 kHz. The >> pre-warped pulsation is 0.4228 rad/sec and the z transfer function is >> H(z)=236.4E-6*(1-z^-1)/(1+0.999527*z^-1). >> >> When I compute this filter, it seems to be unstable at 24 kHz, and theFFT>> of a filtered signal gives a spike at this frequency. >> >> Is something wrong in my design ? > >Yes, but not in your calculations for the digital fitler. > >> How can I avoid having this oscillation ? > >You need to plot the results for a 20khz signal for 1 millisecond to seehow>the sampling is affecting your results. > >> Putting a low-pass filter after this one seems not to be a good idea I >think >> ... >> >> Who could help me ?? >> >> Thanks a LOT in advance ! >> >> Sam >> >> >You are right. Try putting the analog low pass filter before thedigital>filter. >Check out anti-aliasing. > >Peter Nachtwey >I suggest to introduce a ZERO at this point, this hopefully will cancelthe effect of oscillation. regards al> >
IIR design and stability
Started by ●January 3, 2004
Reply by ●July 28, 20082008-07-28
