Hi All: I am trying to communicate between C5502 and an Atmel processor with ARM7 core. We want to do the communication using SPI protocol with ARM acting as SPI master and C5502 acting as Slave. In our design, the ARM asserts the slave-enable(SS) signal only once at the start of transmission of the frame and it stays active throughout the transmission of all words in a single frame. The transmission of each word is thus facilitated by activating and deactivating the shift-clock(SCLK) by the ARM. This mode of operation is necessary for smooth DMA operation of the ARM. Now, while testing, it appears that DSP does'nt work properly as Slave if slave-enable signal is not asserted and deasserted for transfer of every single word in the frame but it does work fine otherwise. My question is: does anyone have any idea if our desired mode of operation could actually work? and if it can, what needs to be done in the McBSP configuration? The DSP manual(spru592.pdf) is ambiguous about it. I have also checked McBSP operation in spru302(C54) and spru190(C6x) but none helped. Any help/comment will be appreciated. Thanks, Zia
McBSP as SPI slave
Started by ●January 2, 2004
Reply by ●January 5, 20042004-01-05
On 2 Jan 2004 10:57:51 -0800, a_z129@yahoo.com (Zia) wrote:>Hi All: > >I am trying to communicate between C5502 and an Atmel processor with >ARM7 core. We want to do the communication using SPI protocol with ARM >acting as SPI master and C5502 acting as Slave. > >In our design, the ARM asserts the slave-enable(SS) signal only once >at the start of transmission of the frame and it stays active >throughout the transmission of all words in a single frame. The >transmission of each word is thus facilitated by activating and >deactivating the shift-clock(SCLK) by the ARM. This mode of operation >is necessary for smooth DMA operation of the ARM. >Now, while testing, it appears that DSP does'nt work properly as Slave >if slave-enable signal is not asserted and deasserted for transfer of >every single word in the frame but it does work fine otherwise. > >My question is: does anyone have any idea if our desired mode of >operation could actually work? and if it can, what needs to be done in >the McBSP configuration? > >The DSP manual(spru592.pdf) is ambiguous about it.I guess you mean that: "The McBSP requires an active edge of the slave-enable signal on the FSX input for each transfer. This means that the master device must assert the slave-enable signal at the beginning of each transfer, and deassert the signal after the completion of each packet transfer; the slave-enable signal cannot remain active between transfers." So what this means all depends on the definition of "packet transfer". A packet is defined by X/RWDLENx and X/RFRLENx, the latter being related to the FSRX signal. Unfortunately from your point of view, if you want to use SPI (Clock-Stop) mode on the C5502, you have to set X/RFRLENx to 0 to give a frame length of 1 serial word (see section 6.3, table 6-1 of spru592a). So basically what you want to do can't be done without some external logic. Best Regards John McCabe To reply by email replace 'nospam' with 'assen'
Reply by ●September 26, 20052005-09-26
Hi I'm using a 6713(slave) with a Atmel AT91RM9200 (Master), and I have had the same problem, as a possible solution I have tried to use the multiple numbers of elements in a frame. The data transfered between the Atmel and the dsp seems to get corrupted in the DSP. I.E if I send 8 words or 16 bits in a block, when I receive them in the DSP I will see 8 words but only a few of them will be the words I expected! The Atmel seems extends the clk on the last clk of every element, where a chip select cycle should be, am I missing some key combination of settings here or is it the extended clk thats messing things up? Regards DaveE>On 2 Jan 2004 10:57:51 -0800, a_z129@yahoo.com (Zia) wrote: > >>Hi All: >> >>I am trying to communicate between C5502 and an Atmel processor with >>ARM7 core. We want to do the communication using SPI protocol with ARM >>acting as SPI master and C5502 acting as Slave. >> >>In our design, the ARM asserts the slave-enable(SS) signal only once >>at the start of transmission of the frame and it stays active >>throughout the transmission of all words in a single frame. The >>transmission of each word is thus facilitated by activating and >>deactivating the shift-clock(SCLK) by the ARM. This mode of operation >>is necessary for smooth DMA operation of the ARM. >>Now, while testing, it appears that DSP does'nt work properly as Slave >>if slave-enable signal is not asserted and deasserted for transfer of >>every single word in the frame but it does work fine otherwise. >> >>My question is: does anyone have any idea if our desired mode of >>operation could actually work? and if it can, what needs to be done in >>the McBSP configuration? >> >>The DSP manual(spru592.pdf) is ambiguous about it. > >I guess you mean that: > >"The McBSP requires an active edge of the slave-enable signal on the >FSX input for each transfer. This means that the master device must >assert the slave-enable signal at the beginning of each transfer, and >deassert the signal after the completion of each packet transfer; the >slave-enable signal cannot remain active between transfers." > >So what this means all depends on the definition of "packet transfer". >A packet is defined by X/RWDLENx and X/RFRLENx, the latter being >related to the FSRX signal. Unfortunately from your point of view, if >you want to use SPI (Clock-Stop) mode on the C5502, you have to set >X/RFRLENx to 0 to give a frame length of 1 serial word (see section >6.3, table 6-1 of spru592a). > >So basically what you want to do can't be done without some external >logic. > > >Best Regards >John McCabe > >To reply by email replace 'nospam' with 'assen' >This message was sent using the Comp.DSP web interface on www.DSPRelated.com
