On Wed, 30 Nov 2011 18:18:15 +0000, glen herrmannsfeldt wrote:> Tim <tim@seemywebsite.please> wrote: >> On Wed, 30 Nov 2011 06:28:33 -0800, Lox wrote: > >>> I would need to change the frequencies from 0 ??? 80 kHz to 0 to 10 >>> kHz, a linear scaling of the frequency. > > (snip) >> Why 'would' you need to do this? > >> It is possible, but unless your signal is special all you'll do is >> hopelessly scramble it. > >> Bandwidth * time is information -- so cutting the bandwidth is >> compression. You'll have to leave information out to do this, and if >> its important information then you'll never be able to recover a decent >> semblance of your original signal. > > I am not so convinced. Without actually looking it up, I thought it was > more like bandwidth * time * S/N. > > Now, one way to scale the frequency is to also scale the time, but it > seems that the OP doesn't want to do that. > > This does remind me of the old problem of high-speed tape duplication, > though it isn't exactly the same. > > -- glenMy statement was fairly hand-waving -- but I do very much doubt that this can be done successfully for arbitrary signals. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
Compress frequency range to smaller range?
Started by ●November 30, 2011
Reply by ●November 30, 20112011-11-30
On 30 Nov, 22:09, Tim Wescott <t...@seemywebsite.com> wrote:> On Wed, 30 Nov 2011 12:44:18 -0800, Rune Allnor wrote: > > On 30 Nov, 18:58, robert bristow-johnson <r...@audioimagination.com> > > wrote: > > >> ... is, how you > >> say, a female canine. > > > ??????? > > http://en.wiktionary.org/wiki/bitch. �Definition 7.Ah. I associated 'canine' with Norwegian 'kanin' = 'rabbit'. That domesticated form of 'hare'. Sitting listening to gales outside (prelude to a storm coming in tomorreow), fire in the oven and darkness all day except for a few hours mid-day. Must have begun affecting my mind already, it isn't even January yet. Rune
Tim Wescott <tim@seemywebsite.com> wrote: (snip, I wrote)>> more like bandwidth * time * S/N.> My statement was fairly hand-waving -- but I do very much doubt > that this can be done successfully for arbitrary signals.Probably true, but the OP hasn't explained the real problem. Maybe the original signal has an unusually low S/N, such that it can be compressed easily. With discrete signals, it is easy to see the loss of information, not so easy with continuous signals. Also, it is interesting to compare to some of the bandwidth reducing coding systems used in data commmunications. Again, it is trading S/N for bandwidth. The MLT-3 coding used by 100baseTX, instead of coding as on/off, with the voltage changing on 1 and not on 0 (after a scrambler), they go through four different states, 0, +1, 0, -1. The result has half the bandwidth, but requires more S/N to decode. As UTP cable losses increase with frequency, and also RFI radiation increases with frequency, this is useful. A more complicated system is used for 1000baseT, which sends data both directions on each of four twisted-pairs at the same time, below, if I remember right, 100MHz bandwidth each, and through up to 100m of cable. -- glen
Reply by ●December 1, 20112011-12-01
