If I split an 8th order fixed-point IIR filter into 4 second-order IIR filters in cascade, how should the filter coefficients be calculated so that the overall filter: 1) Doesn't produce ringing when an impulse is applied ? 2) Doesn't produce ringing when a step signal is applied ? The filters are implemented as Direct Form II Transposed structures. Is it even possible? If so, what are the limitations? I intend to use the filter for resampling audio by a factor of P/Q, so the procedure would be something like this: 1) Given an audio signal, x, sampled at F1 Hz 2) Upsampling: Append (P-1) zeros after each sample in x to create upsampled signal y 3) Apply filter to y. Filter has a normalized cut-off frequency at Fc where Fc = min{1/P, 1/Q}. Output of filter is denoted z 4) Downsampling: Keep every Q'th sample in z
IIR filter question
Started by ●December 14, 2011
Reply by ●December 14, 20112011-12-14
On 14 Des, 23:44, John McDermick <johnthedsp...@gmail.com> wrote:> If I split an 8th order fixed-point IIR filter into 4 second-order IIR > filters in cascade, how should the filter coefficients be calculated > so that the overall filter: > > 1) Doesn't produce ringing when an impulse is applied ? > > 2) Doesn't produce ringing when a step signal is applied ? > > The filters are implemented as Direct Form II Transposed structures. > > Is it even possible? If so, what are the limitations?It seems you need to read up on basic filter theory. Ringing is one of the proerties of filters, the question is not how to avoid it, but how much is tolerable. You need to - Understand filters - Understand specifications - Come up with a spec which is accetable - Design a set of filters which meet the spec Rune
John McDermick <johnthedspguy@gmail.com> wrote: (snip)> I intend to use the filter for resampling audio by a factor of P/Q, so > the procedure would be something like this:Deviating slightly from the original question, as I understand it the 48kHz sampling rate of DAT was supposed to be different enough (small GCD) to make resampling from 44.1kHz hard. (CD copying.) Later, I learned that there are algorithms that do fairly simple interpolations, and aren't bothered by large P and Q. Though also changes in computing hardware have made it easier. -- glen
Hey idiot, It doesn't matter in which way the IIR filter is built, and what is your stupid usage for that filter. As long as the resultant transfer function has poles with damping less then 1, the response will be oscillatory. John McDermick wrote:> If I split an 8th order fixed-point IIR filter into 4 second-order IIR > filters in cascade, how should the filter coefficients be calculated > so that the overall filter:> 1) Doesn't produce ringing when an impulse is applied ? > > 2) Doesn't produce ringing when a step signal is applied ? > > The filters are implemented as Direct Form II Transposed structures. > > Is it even possible? If so, what are the limitations?> I intend to use the filter for resampling audio by a factor of P/Q, so > the procedure would be something like this: > > 1) Given an audio signal, x, sampled at F1 Hz > 2) Upsampling: Append (P-1) zeros after each sample in x to create > upsampled signal y > 3) Apply filter to y. Filter has a normalized cut-off frequency at Fc > where Fc = min{1/P, 1/Q}. Output of filter is denoted z > 4) Downsampling: Keep every Q'th sample in z >
Reply by ●December 15, 20112011-12-15
>> for resampling audio by a factor of P/QTry a Lagrange interpolator. This piece of code http://www.dsprelated.com/showcode/3.php does a good job at it and is quite efficient on a CPU. This http://yehar.com/blog/wp-content/uploads/2009/08/deip.pdf is worth reading. Never mind the pink elephant.
one more thought: the abovementioned methods boil down to FIR polyphase interpolation. Lagrange, Catmull-Rom etc are different methods to calculate the FIR coefficients. Here is another one that -might- give some very good results: http://www.dsprelated.com/showcode/236.php function c = gPulseCoefs(u,T,B,P) gives a 2P+1 tap set for "u" fractional delay. B sets the passband width relative to the sampling time T.
On Wed, 14 Dec 2011 15:36:24 -0800, Rune Allnor wrote:> On 14 Des, 23:44, John McDermick <johnthedsp...@gmail.com> wrote: >> If I split an 8th order fixed-point IIR filter into 4 second-order IIR >> filters in cascade, how should the filter coefficients be calculated so >> that the overall filter: >> >> 1) Doesn't produce ringing when an impulse is applied ? >> >> 2) Doesn't produce ringing when a step signal is applied ? >> >> The filters are implemented as Direct Form II Transposed structures. >> >> Is it even possible? If so, what are the limitations? > > It seems you need to read up on basic filter theory. Ringing is one of > the proerties of filters, the question is not how to avoid it, but how > much is tolerable. You need to > > - Understand filters > - Understand specifications > - Come up with a spec which is accetable - Design a set of filters which > meet the specWell, a filter doesn't necessarily _have_ to ring -- but an audio filter that doesn't ring is going to be pretty crappy. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Wed, 14 Dec 2011 14:44:13 -0800, John McDermick wrote:> If I split an 8th order fixed-point IIR filter into 4 second-order IIR > filters in cascade, how should the filter coefficients be calculated so > that the overall filter: > > 1) Doesn't produce ringing when an impulse is applied ? > > 2) Doesn't produce ringing when a step signal is applied ? > > The filters are implemented as Direct Form II Transposed structures. > > Is it even possible? If so, what are the limitations? > > I intend to use the filter for resampling audio by a factor of P/Q, so > the procedure would be something like this: > > 1) Given an audio signal, x, sampled at F1 Hz 2) Upsampling: Append > (P-1) zeros after each sample in x to create upsampled signal y > 3) Apply filter to y. Filter has a normalized cut-off frequency at Fc > where Fc = min{1/P, 1/Q}. Output of filter is denoted z 4) Downsampling: > Keep every Q'th sample in zYou are asking two different questions. You start by asking how to split an 8th-order IIR filter into a cascade of 4th-order biquads. That's a fairly mechanical process (getting the zeros placed intelligently can take a bit of work, but other than that it's mechanical). When you're done with this you should have -- barring details like quantization issues -- a filter with exactly the same response as what you started. Correctly cascading 2nd-order sections into an overall big-order filter doesn't change the overall filter response. But then you ask if the resulting filter will have a bunch of properties. But those properties are all things that are determined by the design of the 8th-order filter -- not by the fact that you happen to be implementing it as a cascade of 2nd-order biquads, or as one, big, happy 8th-order filter (with, presumably, some really seriously high precision math). So to answer your question about whether it is possible, and what the limitations are, to split an 8-th order filter into 2nd-order biquads: yes, it's done all the time and while the task isn't completely trivial it's pretty easy. To answer your question about whether it is possible, and what the limitations are, to make a non-ringing 8th-order filter: sure, you can do that. But as everyone else says, it's not something that's going to make you happy in the end. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
mnentwig wrote:>>>for resampling audio by a factor of P/Q > > Try a Lagrange interpolator.Using direct Lagrange interpolation for quality audio is no good idea. An arbitrary interpolator with BW of 90% of Nyquist and with less then -100dB worst case artifacts is quite demanding on the CPU. RBJ wrote several articles on that; IIRC it requires upsampling by factor ~ 100 before polynomial interpolation. VLV
>Using direct Lagrange interpolation for quality audio is no good idea. >An arbitrary interpolator with BW of 90% of Nyquist and with less then >-100dB worst case artifacts is quite demanding on the CPU. >RBJ wrote several articles on that; IIRC it requires upsampling by >factor ~ 100 before polynomial interpolation.I agree with that: the question is where to draw the line for "quality audio". One obvious problem with Lagrange and friends is that there is no direct control over the bandwidth of the passband. But, reading between the lines, I don't expect the OP needs to meet a 100 dB target. The Catmull-Rom interpolator wouldn't get anywhere close, but often does a fairly decent job nonetheless, given its simplicity. It depends on the application.
