How to apply Bandstop IIR Digital filter to the 60Hz Noisy ECG Signal??
Started by wongjowo December 18, 2011
Hi every one..
I has designed a bandstop IIR filter to removed 60 Hz Sinus Noise at ECG
signal.
The step of I have done are :
1. Designed a bandpass filter (frequency domain) -> it will be H
2. Do FFT to the ECG Signal -> it will be X
3. Do the circular convolution -> Y = X.*H
But my question is : the output of Y is WRONG, because the result of X by
FFT is SYMMETRIC , but H is not symmetric.
Please help to let me know how to apply the bandstop to the signal???
Thanks in advance
it should be, otherwise you'll get a complex-valued output time domain waveform from real-valued input.
On Sun, 18 Dec 2011 13:32:30 -0600, wongjowo wrote:
> Hi every one.. > > I has designed a bandstop IIR filter to removed 60 Hz Sinus Noise at ECG > signal. > The step of I have done are : > > 1. Designed a bandpass filter (frequency domain) -> it will be H
2. Do FFT to the ECG Signal -> it will be X 3. Do the circular convolution -> Y = X.*H
> > But my question is : the output of Y is WRONG, because the result of X > by FFT is SYMMETRIC , but H is not symmetric. Please help to let me know > how to apply the bandstop to the signal???
Huh? You've said nothing at all about Y, only about the symmetry of X and H. Yes, the impulse response of an IIR filter is not symmetric -- so? -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
