Well the computational linguistics program is far enough away that I would have to move to enroll in it, the masters program I'm mostly considering is at the school I'm at now, so it would be much simpler, and I don't have the prereqs for the comp ling. program anyways. As for the main issue, if dsp engineer work is how Rune says it is then I'm not doing it, I'll just get the pure math masters and decide from there whether to teach at a CC or go on to a phd. But if the situation is better here in America then maybe I should do it, so hopefully I can hear more about that.
Masters in Applied Math w/ concentration in EE & DSP
Started by ●January 8, 2012
Reply by ●January 8, 20122012-01-08
On 8 Jan, 21:39, Tim Wescott <t...@seemywebsite.com> wrote:> On Sun, 08 Jan 2012 01:39:26 -0800, Rune Allnor wrote:> > I will not pretend to be able to tell you what to do. But I can > > confidently tell you what *not* to do: Stay away from a carreer in DSP. > > Pursue DSP if you want, but don't let it become more than a hobby. > > > Rune > > > [*] In the lottery, somebody actually wins. > > Rune, I'm not sure that what you say reflects working in Norway, or if > you're just getting bitter as you age.To the extent I have worked at PhD level, I have been messing with kooks and frauds. Like the guy who wanted to use a radar to measure the thickness of a piece of conducting material: He was a professor of radar technology with a (then) 25-year record of work with some rather high-profile & -prestige organizations. My job was to sit in with my clients, customers who considered buying his system, to spot why it did not work. I still don't understand why he was not pursued for attempted fraud - the only reason I can think of is that he went to sell the system to my clients' competitors. Then there was the sonar to detect corroded munitions - totally insane, as the chemical composition of materials can't be determied through acoustics. The acoustics professor with (then) 40 year experience ought to know. That's the kind of projects I have been involved with: Stuff that immediately fall to high-school physics, once one thinks the idea completely through. Rune
Eric Proffitt <esproff@gmail.com> wrote:> I fear this may not be the appropriate forum for this post, but I > don't know where else to go and since every bit of info I can get is > critical to making this very important life decision, I'm going to > anyways.> Very soon I will have to decide whether to continue on with pure math > with the intent of getting a phd, or to instead opt for an applied > math masters with a concentration in electrical engineering and dsp. > I really like math, and I think I would enjoy applying mathematical > analysis to solve real world problems a l� signal processing. I have > done quite a bit of lurking on this forum and it seems like some of > you know quite a bit of advanced math in the areas of complex and > fourier analysis, and even branching out into analytic number theory > from time to time (way cool). But I generally can't figure out which > posts come from people in industry, and which come from people in > academia.As far as I know, it isn't industry vs. academia, but what I usually call theoretical vs. applied. There are many stories in physics where it is obvious which side a person should be on. An old favorite is known as the Pauli effect, supposedly experiments have been known to fail if Pauli was even just in the building. My own favorite story was of someone I knew, a brand-new Ph.D in condensed-matter theory, who, at his Ph.D celebration couldn't figure out how to open a Champagne bottle. I remember in my undergraduate physics classes comments from the TA about which students were going to be theoretical and which experimental by noticing which problems they did better on. Do you like to take things apart and see how they really work? As far as I know, most good engineers and experimental physicists liked to take thing apart when they were pretty young. (Well, and put them back together again.) If you would rather read books, instead of take things apart, then I would suggest going for the pure (not applied) math choice.> I like physics and engineering as well and I think I would enjoy the > other aspects of dsp engineering: programming, writing reports, > working with others, troubleshooting etc. But I also like to be > intellectual challenged and creatively apply math, so is this the > right job for me?(snip) There should be enough problems in engineering or applied math to keep someone challenged, but they will be different kinds of problems, with different challenges. Consider Fermat's last theorem. While an engineer might find it interesting reading, most would not actually be interesting in working on a challenge like that. Engineers can be told that something is true, that someone else has proved that it is true, and use that without needing to see the proof. They know what works in actual, real-life, problems even if it doesn't work in the theoretical sense. -- glen
On 8 Jan, 23:48, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Do you like to take things apart and see how they really work? > As far as I know, most good engineers and experimental physicists > liked to take thing apart when they were pretty young. (Well, and > put them back together again.)I tend to agree with this.> If you would rather read books, instead of take things apart, then > I would suggest going for the pure (not applied) math choice.Hmmm... I have a problem with this one. *Math* is the one field of engineering where thinkers tend to do better than tinkers, no matter the application. The decider is not the theoretically or practically inclined mind; the theoretical inclination a must for both the 'applied' and the 'pure' math. The decider is the motivation: math for its own sake or because it is somehow useful?> Engineers can be told that something is true, that someone else has > proved that it is true, and use that without needing to see the proof. > They know what works in actual, real-life, problems even if it > doesn't work in the theoretical sense.Not long ago I did the exact opposite: Somebody had a problem with a manufacturing process they were not able to figure out. Troubleshooting had produced no results - nothing they tried made any difference to the problem - and now every (and I mean *every*) possible factor had been excluded as causing the problem. So we reviewed the theory: Everybody knew the theory said that one hunch some of the staff had, and I had picked up on, must be wrong. When I mentioned the hunch, some of the process engineer staff seemed as if they wanted the guys in white come and collect me, straight- jacket and all. My reasoning was simple: As Sherlock Holmes once said, "When every impossible solution has been excluded, whatever remains must be the answer, however improbable." The process foreman liked the idea, and tested it: Adjusting for the suspected effect caused the problem to go away. So the engineers *knew* the contributions from the effect to be insignificant. They even proved it, theoretically: "The energy conribution of this effect accounts for 0.0001% (or some such number) of the total energy balance. No way that's the problem!" So they *knew* the effect did not work, even if it was the only one switch we turned that actually had an effect on the problem under study: Every other factor had been tested and excluded as cause, as the problem persisted no matter what we did. After some time we even managed to come up with a theoretical explanation that both explained the effect, and also why the engineers was unable to pick up on it in their calculations. A ridiculously fun project to take part in. Not quite as much fun not to have the sufficient clout to get the solution implemented to my spec. Rune
Rune Allnor <allnor@tele.ntnu.no> wrote:> On 8 Jan, 23:48, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:>> Do you like to take things apart and see how they really work? >> As far as I know, most good engineers and experimental physicists >> liked to take thing apart when they were pretty young. (Well, and >> put them back together again.)> I tend to agree with this.>> If you would rather read books, instead of take things apart, then >> I would suggest going for the pure (not applied) math choice.> Hmmm... I have a problem with this one. *Math* is the > one field of engineering where thinkers tend to do > better than tinkers, no matter the application.I don't know if I can explain it better, but there is a difference. There are different kinds of thinkers, some of whom are good at practical problems, some at theoretical problems. But you are probably right, in that the weighting is wrong. The engineers also like to read books. Try again: If you like to read books and really hate having to take things apart and put them back together again, go for the pure math side. Would you trust someone who proved Fermat's last theorem to change the spark plugs on your car?> The decider is not the theoretically or practically > inclined mind; the theoretical inclination a must > for both the 'applied' and the 'pure' math. The > decider is the motivation: math for its own sake > or because it is somehow useful?Yes, but they are still different, at least in physics. Applied math is pretty close to physics in the cases that I know. (One applied math department I know mostly works on computational fluid dynamics.) But the math for its own sake, or because it is useful, probably also works.>> Engineers can be told that something is true, that someone else has >> proved that it is true, and use that without needing to see the proof. >> They know what works in actual, real-life, problems even if it >> doesn't work in the theoretical sense.> Not long ago I did the exact opposite: Somebody had > a problem with a manufacturing process they were > not able to figure out.(snip)> My reasoning was simple: As Sherlock Holmes once said, > "When every impossible solution has been excluded, > whatever remains must be the answer, however > improbable."> The process foreman liked the idea, and tested it: > Adjusting for the suspected effect caused the problem > to go away.Yes there are cases like that. There is a story, supposed to be true but you never know, about an electroplating company. Most of the time everything was fine, but sometimes it didn't work right. After much study, it was found that it failed when a certain janitor went on vacation, so they took the janitor in and asked him what he did to the electroplating tank. It took some convincing because he didn't want to get in trouble, but they finally convinced him that whatever he did was good, not bad. OK, he was finally convinced and admitted that he would pee in the tank and throw his cigars into the tank. As far as I know, though much of the theory of electroplating isn't known so well. -- glen
On 9 Jan, 02:23, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Rune Allnor <all...@tele.ntnu.no> wrote:> > Not long ago I did the exact opposite: Somebody had > > a problem with a manufacturing process they were > > not able to figure out. > > (snip) > > > My reasoning was simple: As Sherlock Holmes once said, > > "When every impossible solution has been excluded, > > whatever remains must be the answer, however > > improbable." > > The process foreman liked the idea, and tested it: > > Adjusting for the suspected effect caused the problem > > to go away. > > Yes there are cases like that. > > There is a story, supposed to be true but you never know, > about an electroplating company. Most of the time everything > was fine, but sometimes it didn't work right. After much study, > it was found that it failed when a certain janitor went on > vacation, so they took the janitor in and asked him what he did > to the electroplating tank. It took some convincing because he > didn't want to get in trouble, but they finally convinced him > that whatever he did was good, not bad. OK, he was finally > convinced and admitted that he would pee in the tank and throw > his cigars into the tank. As far as I know, though much of the > theory of electroplating isn't known so well.That kind of story is rather typical: The process varies unecplicably, and it turns out somebody does something to the process, either for better or for worse. Somebody with a 'mathematically inclined' mind and interest in practical work with tangible results, could do far worse than getting involved with Six Sigma type problem-solving teams. Rune
Reply by ●January 9, 20122012-01-09
On 1/8/2012 8:23 PM, glen herrmannsfeldt wrote: ...> There is a story, supposed to be true but you never know, > about an electroplating company. Most of the time everything > was fine, but sometimes it didn't work right. After much study, > it was found that it failed when a certain janitor went on > vacation, so they took the janitor in and asked him what he did > to the electroplating tank. It took some convincing because he > didn't want to get in trouble, but they finally convinced him > that whatever he did was good, not bad. OK, he was finally > convinced and admitted that he would pee in the tank and throw > his cigars into the tank. As far as I know, though much of the > theory of electroplating isn't known so well.That story morphed since I heard it only second hand. Bud Morris, the head plater at Sarnoff was the chairman of the Delaware Valley Electrechemical Society. A friend of his was called in as a consultant to a firm that did bright plating, a process that put a polish onto lipstick cases without the need for buffing. (The process involves biased low-frequency AC, so that material is plated on all over and selectively removed from the high points.) As business grew, a second shift was added. As it grew further, another plating tank was started up. The second tank gave poor results, and the owner spent a lot of time at it tinkering with the regime and the formula. When the first tank began to deteriorate, the owner -- himself an electrochemist -- called in Bud's friend. They arranged for him to be hired on as a working member of the crew, working undercover. The owner stayed away. After his second stint on the night shift, he went to the boss's office, and said "Do you know how far it is from the tank to the bathroom? That's how a urea additive came to be the trade secret behind successful bright plating. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins <jya@ieee.org> wrote: (snip of story on electroplating)> That story morphed since I heard it only second hand. Bud Morris, the > head plater at Sarnoff was the chairman of the Delaware Valley > Electrechemical Society. A friend of his was called in as a consultant > to a firm that did bright plating, a process that put a polish onto > lipstick cases without the need for buffing. (The process involves > biased low-frequency AC, so that material is plated on all over and > selectively removed from the high points.) As business grew, a second > shift was added. As it grew further, another plating tank was started > up. The second tank gave poor results, and the owner spent a lot of time > at it tinkering with the regime and the formula. When the first tank > began to deteriorate, the owner -- himself an electrochemist -- called > in Bud's friend. They arranged for him to be hired on as a working > member of the crew, working undercover. The owner stayed away. After his > second stint on the night shift, he went to the boss's office, and said > "Do you know how far it is from the tank to the bathroom? That's how a > urea additive came to be the trade secret behind successful bright plating.I am not sure now where I read this, probably in an electroplating book. Your story doesn't have the cigar, which I remember being in the one I read. It seems close enough. though, that it is likely somehow a variant of yours. -- glen
On Sun, 08 Jan 2012 14:08:33 -0800, Rune Allnor wrote:> On 8 Jan, 21:39, Tim Wescott <t...@seemywebsite.com> wrote: >> On Sun, 08 Jan 2012 01:39:26 -0800, Rune Allnor wrote: > >> > I will not pretend to be able to tell you what to do. But I can >> > confidently tell you what *not* to do: Stay away from a carreer in >> > DSP. Pursue DSP if you want, but don't let it become more than a >> > hobby. >> >> > Rune >> >> > [*] In the lottery, somebody actually wins. >> >> Rune, I'm not sure that what you say reflects working in Norway, or if >> you're just getting bitter as you age. > > To the extent I have worked at PhD level, I have been messing with kooks > and frauds. Like the guy who wanted to use a radar to measure the > thickness of a piece of conducting material: He was a professor of radar > technology with a (then) 25-year record of work with some rather > high-profile & -prestige organizations. > > My job was to sit in with my clients, customers who considered buying > his system, to spot why it did not work. I still don't understand why he > was not pursued for attempted fraud - the only reason I can think of is > that he went to sell the system to my clients' competitors. > > Then there was the sonar to detect corroded munitions - totally insane, > as the chemical composition of materials can't be determied through > acoustics. The acoustics professor with (then) 40 year experience ought > to know. > > That's the kind of projects I have been involved with: Stuff that > immediately fall to high-school physics, once one thinks the idea > completely through.I've run into a few PhD's like that. Fortunately most of them have been pretty down-to-earth. (One is a friend who I met because he got himself a job as a regular old software engineer, _specifically_ to pick up all the practical knowledge that he knew he hadn't learned getting it piled higher and deeper. I ended up being the technical lead told off to direct him, and it was a joy. He's my shining example of someone who not only made money implementing neural nets (which isn't surprising given when I met him), but whose neural nets made money for the people who paid him -- _that's_ an achievement). -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
On 9 Jan, 06:05, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Jerry Avins <j...@ieee.org> wrote: > > (snip of story on electroplating) > > > > > > > That story morphed since I heard it only second hand. Bud Morris, the > > head plater at Sarnoff was the chairman of the Delaware Valley > > Electrechemical Society. A friend of his was called in as a consultant > > to a firm that did bright plating, a process that put a polish onto > > lipstick cases without the need for buffing. (The process involves > > biased low-frequency AC, so that material is plated on all over and > > selectively removed from the high points.) �As business grew, a second > > shift was added. As it grew further, another plating tank was started > > up. The second tank gave poor results, and the owner spent a lot of time > > at it tinkering with the regime and the formula. When the first tank > > began to deteriorate, the owner -- himself an electrochemist -- called > > in Bud's friend. They arranged for him to be hired on as a working > > member of the crew, working undercover. The owner stayed away. After his > > second stint on the night shift, he went to the boss's office, and said > > "Do you know how far it is from the tank to the bathroom? That's how a > > urea additive came to be the trade secret behind successful bright plating. > > I am not sure now where I read this, probably in an electroplating book. > > Your story doesn't have the cigar, which I remember being in the > one I read. It seems close enough. though, that it is likely somehow > a variant of yours.The cigar doesn't quite make sense: it introduces solid residues in the bath, that would likely be detected during cleaning an maintenance, as well as by producing flaws in the electroplated surfaces. Peeing in the bath merely adjusts the chemical composition of the liquid, which is far harder to detect. Rune
