Hi all ! I am looking for the coefficients for a FIR filter to compute the pre-deemphasis 50/15 us. Does anybody know them ? Are there any IC that can do it without having to use a DSP ? Thanks in advance ! Sam
emphasis coefficients
Started by ●December 27, 2003
Reply by ●December 27, 20032003-12-27
"Sam \(r�p. sans -no-sp-am\)" <totalsam-no-sp-am@hotmail.com> wrote in message news:<3fede164$0$736$5402220f@news.sunrise.ch>...> Hi all ! > > I am looking for the coefficients for a FIR filter to compute the > pre-deemphasis 50/15 us. Does anybody know them ? > > Are there any IC that can do it without having to use a DSP ? > > Thanks in advance ! > > SamYou don't want to use FIR. The original standards are based on analog filters, so you should use IIR. This will give flat amplitude/phase for the whole system (if the pre-emph is linear-phase and the de-emph is analog or IIR, the composite phase response will not be flat) Since its a single pole-zero system, you can manually wiggle the 2 coefficients to fit the analog design and get pretty close pretty fast. It will never match the analog system perfectly, but you can get "close enough". Bob Adams
