Hello, I'm studying and maintaining an existing tele-communication system. I guess it's a BPSK modulation but not quite sure. The transmitted data is a Chirp(up sweeping frequency)header followed by modulated data body. On the receiver side, the incoming data is auto-correlated with a locally stored up-chirp waveform and then defive 2 parameters, one is the sign the other is a delay information. Then the incoming data body is convoluted with a Root-Raised-Cosine filter alike waveform shown in this link:http://en.wikipedia.org/wiki/Raised-cosine_filter. BUT, my waveform is just UP-SIDE-DOWN! I'm just guessing the Root-Raised-Cosine filter alike waveform is used to demodulate the data body, by taking use of the 2 parameters derived from the Chirp header. Could you help to answer these questions? 1. What kind of modulation is this? 2. Any helpful documents about it? Thanks in advance! Jeff
PSK Modulation and demodulation
Started by ●January 19, 2012
Reply by ●January 19, 20122012-01-19
On Jan 19, 4:24�pm, "zhejunli" <JeffLi@n_o_s_p_a_m.cathedralenergyservices.com> wrote:> > On the receiver side, the incoming data is auto-correlated with a locally > stored up-chirp waveform and then defive 2 parameters, one is the sign the > other is a delay information. > > Then the incoming data body is convoluted with a Root-Raised-Cosine filter > alike waveform shown in this > link:http://en.wikipedia.org/wiki/Raised-cosine_filter. BUT, my waveform is > just UP-SIDE-DOWN! >If the estimate of the delay parameter is off by a half-period of the carrier frequency, or if the phase-locked loop (if one is in use) has locked onto the opposite phase (whether this can happen does depend on the design and implementation), then the received waveform would be upside down. Maybe the bits are differentially encoded at the transmitter to take into account this possibility, and if so, the demodulator output bit stream will be the same even if the waveforms are inverted. Dilip Sarwate
>On Jan 19, 4:24=A0pm, "zhejunli" ><JeffLi@n_o_s_p_a_m.cathedralenergyservices.com> wrote: > >> >> On the receiver side, the incoming data is auto-correlated with alocally>> stored up-chirp waveform and then defive 2 parameters, one is the signth=>e >> other is a delay information. >> >> Then the incoming data body is convoluted with a Root-Raised-Cosinefilte=>r >> alike waveform shown in this >> link:http://en.wikipedia.org/wiki/Raised-cosine_filter. BUT, my waveform=>is >> just UP-SIDE-DOWN! >> > >If the estimate of the delay parameter is off by a half-period >of the carrier frequency, or if the phase-locked loop (if one >is in use) has locked onto the opposite phase (whether this >can happen does depend on the design and implementation), >then the received waveform would be upside down. Maybe >the bits are differentially encoded at the transmitter to take >into account this possibility, and if so, the demodulator >output bit stream will be the same even if the waveforms >are inverted. > >Dilip Sarwate >Thank you Dilip, Do you think this is a BPSK modulation? Do you have any suggestions for books or documents to dig into it? Thanks Jeff
Reply by ●January 20, 20122012-01-20
On Jan 20, 9:39�am, "zhejunli" <JeffLi@n_o_s_p_a_m.cathedralenergyservices.com> wrote:> Thank you Dilip, > > Do you think this is a BPSK modulation? Do you have any suggestions for > books or documents to dig into it? Thanks > JeffMaybe try www.dsprelated.com or www.dspguru.com or www.dsplog.com to see if they have any information that will help.
Reply by ●January 23, 20122012-01-23
On Jan 19, 4:24�pm, "zhejunli" <JeffLi@n_o_s_p_a_m.cathedralenergyservices.com> wrote:> Hello, > > I'm studying and maintaining an existing tele-communication system. I > guess it's a BPSK modulation but not quite sure. > > The transmitted data is a Chirp(up sweeping frequency)header followed by > modulated data body. > > On the receiver side, the incoming data is auto-correlated with a locally > stored up-chirp waveform and then defive 2 parameters, one is the sign the > other is a delay information. > > Then the incoming data body is convoluted with a Root-Raised-Cosine filter > alike waveform shown in this > link:http://en.wikipedia.org/wiki/Raised-cosine_filter. BUT, my waveform is > just UP-SIDE-DOWN! > > I'm just guessing the Root-Raised-Cosine filter alike waveform is used to > demodulate the data body, by taking use of the 2 parameters derived from > the Chirp header. > > Could you help to answer these questions? > 1. What kind of modulation is this? > 2. Any helpful documents about it? > > Thanks in advance! > > JeffSince this is an existing telecommunication system, there is a good chance it was designed to meet some sort of spec. Perhaps if you tell us what this system does, i.e., pagers, cellphones, satellite, telemetry etc, someone here may know the protocol. You talk about how the received data is convolved with a RRC, but where does this data come from? Is there a modem? Is there a radio? These types of answers will help. Clay
