>On 2/1/2012 7:10 PM, steveu wrote: >>> On 1/29/2012 3:58 PM, glen herrmannsfeldt wrote: >>>> Jerry Avins<jya@ieee.org> wrote: >>>> >>>> (snip, someone wrote) >>>>>> In my measurement system I'm bound to acquire only one cycle of the >> sine >>>>>> wave so I've got only 62500 samples (I'm doing spectroscopy >> measurements >>>>>> on soil samples). For the noise, I apply a digital low pass filter >>>>>> implemented on the oscilloscope. >>>>>> Sometimes happens that one of the sine wave I record is distorted,so>> I >>>>>> must look for the phase shift between the fundamentals of the two >>>>>> signals. Do you think the zero-crossing method is good even in this >>>>>> situation? >>>> >>>>> Harmonics can (and usually will) displace the zero crossing. >>>> >>>> Without actually drawing them, it seems to me that even harmonics >>>> move the crossing and odd ones don't. Some types of distortion >>>> only create odd harmonics. >>> >>> Odd harmonics that cross zero when the fundamental does don't shiftthe>>> crossings for the obvious reason that superposition applies. Anysignal,>>> harmonic or not, that has non-zero magnitude when the fundamental >>> crosses zero, shifts the composite zero crossing. >> >> If the harmonics are strong you may have far more zero crossings thanyou>> expected. Zero crossings are a pretty woolly test for finding eitherthe>> pitch or the phase of the fundamental. > >If a "harmonic" introduces several extra zero crossings, I consider that >the dominant frequency and the lowest, a subharmonic. That's probably an >idiosyncratic view.http://2d.coppice.org/tone+tenth.png shows a fundamental + its 10th harmonic at 30% of the amplitude of the fundamental. I think that makes the fundamental dominant, yet I see 2 positive and 2 negative zero crossing in each cycle of that fundamental. Steve
Enhancing resolution of an oversampled signal
Started by ●January 28, 2012
Reply by ●February 8, 20122012-02-08
On 2/8/2012 5:08 AM, steveu wrote:>> On 2/1/2012 7:10 PM, steveu wrote: >>>> On 1/29/2012 3:58 PM, glen herrmannsfeldt wrote: >>>>> Jerry Avins<jya@ieee.org> wrote: >>>>> >>>>> (snip, someone wrote) >>>>>>> In my measurement system I'm bound to acquire only one cycle of the >>> sine >>>>>>> wave so I've got only 62500 samples (I'm doing spectroscopy >>> measurements >>>>>>> on soil samples). For the noise, I apply a digital low pass filter >>>>>>> implemented on the oscilloscope. >>>>>>> Sometimes happens that one of the sine wave I record is distorted, > so >>> I >>>>>>> must look for the phase shift between the fundamentals of the two >>>>>>> signals. Do you think the zero-crossing method is good even in this >>>>>>> situation? >>>>> >>>>>> Harmonics can (and usually will) displace the zero crossing. >>>>> >>>>> Without actually drawing them, it seems to me that even harmonics >>>>> move the crossing and odd ones don't. Some types of distortion >>>>> only create odd harmonics. >>>> >>>> Odd harmonics that cross zero when the fundamental does don't shift > the >>>> crossings for the obvious reason that superposition applies. Any > signal, >>>> harmonic or not, that has non-zero magnitude when the fundamental >>>> crosses zero, shifts the composite zero crossing. >>> >>> If the harmonics are strong you may have far more zero crossings than > you >>> expected. Zero crossings are a pretty woolly test for finding either > the >>> pitch or the phase of the fundamental. >> >> If a "harmonic" introduces several extra zero crossings, I consider that >> the dominant frequency and the lowest, a subharmonic. That's probably an >> idiosyncratic view. > > http://2d.coppice.org/tone+tenth.png shows a fundamental + its 10th > harmonic at 30% of the amplitude of the fundamental. I think that makes the > fundamental dominant, yet I see 2 positive and 2 negative zero crossing in > each cycle of that fundamental.Note that I wrote "Several extra", not simply "extra". Nevertheless, I agree that my view is a bit odd, and it should be clarified when it matters. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
