Response to deterministic and random input present together
Started by rsk ●January 28, 2012
Hi,
I am solving a mechanical vibration problem that has both deterministic and
random signals simultaneously as an input. I would like to know if I can
assume the deterministic signal as random signal and solve the problem as a
system subjected to random input. I mean, can I use PSD of the deerministic
signal and add it to the PSD of random signal and consider the resultant
PSD as the random input signal?
To make myself more clear, let's say I want to find response of a single
degree of freedom system(1D-spring and mass) subjected to
1) force = F x sin wt
2) random force with psd = P, then, can I assume input PSD = P + F^2/2 and
then the output psd = (P + F^2/2)* H^2 where H is the transfer function.
Is this approach correct mathematically? would the resultant motion of the
suspended mass be random? or do I need to solve for deterministic signal
separately and random signal separately? How would the two outcome differ?
Thanks in advance
Rahul
rsk <kalerahul@n_o_s_p_a_m.yahoo.com> wrote:
> I am solving a mechanical vibration problem that has both deterministic and > random signals simultaneously as an input. I would like to know if I can > assume the deterministic signal as random signal and solve the problem as a > system subjected to random input. I mean, can I use PSD of the deerministic > signal and add it to the PSD of random signal and consider the resultant > PSD as the random input signal?
Sometime you might be able to, but most often not.
> To make myself more clear, let's say I want to find response of a single > degree of freedom system(1D-spring and mass) subjected to > 1) force = F x sin wt > 2) random force with psd = P, then, can I assume input PSD = P + F^2/2 and > then the output psd = (P + F^2/2)* H^2 where H is the transfer function.
Well, say the system has a high-Q resonance at w. If you ignore that, and assume that the spectrum is all random, you will miss it. If your deterministic signal has a spectrum similar to a random signal, though, you might be able to do that. Consider that a pseudo-random-number-generator is deterministic, but still looks random. -- glen
On 1/28/12 12:18 PM, glen herrmannsfeldt wrote:
> rsk<kalerahul@n_o_s_p_a_m.yahoo.com> wrote: > >> I am solving a mechanical vibration problem that has both deterministic and >> random signals simultaneously as an input. I would like to know if I can >> assume the deterministic signal as random signal and solve the problem as a >> system subjected to random input. I mean, can I use PSD of the deerministic >> signal and add it to the PSD of random signal and consider the resultant >> PSD as the random input signal? > > Sometime you might be able to, but most often not. > >> To make myself more clear, let's say I want to find response of a single >> degree of freedom system(1D-spring and mass) subjected to >> 1) force = F x sin wt >> 2) random force with psd = P, then, can I assume input PSD = P + F^2/2 and >> then the output psd = (P + F^2/2)* H^2 where H is the transfer function. >
the mechanical system is linear and time-invariant. no? the response of the sum is the sum of the responses. for the deterministic component, you get a closed-form deterministic response. for the random component, you can do it with the PSD or, if you like time-domain, the autocorrelation of the random component. maybe i'm missing something obvious. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Sat, 28 Jan 2012 10:51:56 -0600, rsk wrote:
> Hi, > > I am solving a mechanical vibration problem that has both deterministic > and random signals simultaneously as an input. I would like to know if I > can assume the deterministic signal as random signal and solve the > problem as a system subjected to random input. I mean, can I use PSD of > the deerministic signal and add it to the PSD of random signal and > consider the resultant PSD as the random input signal? > To make myself more clear, let's say I want to find response of a single > degree of freedom system(1D-spring and mass) subjected to 1) force = F x > sin wt > 2) random force with psd = P, then, can I assume input PSD = P + F^2/2 > and then the output psd = (P + F^2/2)* H^2 where H is the transfer > function. > > Is this approach correct mathematically? would the resultant motion of > the suspended mass be random? or do I need to solve for deterministic > signal separately and random signal separately? How would the two > outcome differ?
It depends on what answer you're looking for. You can find the PSD of the deterministic + random signal, keeping in mind that it'll have an impulse at the sine wave frequency. Then you can run that through the transfer function of the system to find the result. But depending on how you do the calculations you might lose the phase relationship between the sine wave at the output and the driving sine wave. But because the character of the impulse is so different from the (presumably spread out) PSD of the random signal, you won't be saving yourself any work over just working out the two answers individually. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On 1/28/2012 11:51 AM, rsk wrote:
> Hi, > > I am solving a mechanical vibration problem that has both deterministic and > random signals simultaneously as an input. I would like to know if I can > assume the deterministic signal as random signal and solve the problem as a > system subjected to random input. I mean, can I use PSD of the deerministic > signal and add it to the PSD of random signal and consider the resultant > PSD as the random input signal? > To make myself more clear, let's say I want to find response of a single > degree of freedom system(1D-spring and mass) subjected to > 1) force = F x sin wt > 2) random force with psd = P, then, can I assume input PSD = P + F^2/2 and > then the output psd = (P + F^2/2)* H^2 where H is the transfer function. > > Is this approach correct mathematically? would the resultant motion of the > suspended mass be random? or do I need to solve for deterministic signal > separately and random signal separately? How would the two outcome differ? > > Thanks in advance > Rahul
Superposition applies if the system is linear, which in your case, probably means that it neither breaks nor undergoes plastic deformation. (If the system doesn't behave elastically, the actual signal, not merely the PSD, will determine the outcome. In that case, you will need something like a Monte Carlo simulation.) If superposition applies, it provides the simplest way to proceed. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Jan 29, 5:51&#4294967295;am, "rsk" <kalerahul@n_o_s_p_a_m.yahoo.com> wrote:
Yes, superposition!
>On Jan 29, 5:51=A0am, "rsk" <kalerahul@n_o_s_p_a_m.yahoo.com> wrote: >> Hi, >> >> I am solving a mechanical vibration problem that has both deterministic
a=
can
as=
deerminist=
resultant
>> PSD as the random input signal? >> To make myself more clear, let's say I want to find response of a
single
>> degree of freedom system(1D-spring and mass) subjected to >> 1) force =3D F x sin wt >> 2) random force with psd =3D P, then, can I assume input PSD =3D P +
F^2/=
>2 and >> then the output psd =3D (P + F^2/2)* H^2 where H is the transfer
function=
>. >> >> Is this approach correct mathematically? would the resultant motion of
th=
>e >> suspended mass be random? or do I need to solve for deterministic
signal
differ=
>? >> >> Thanks in advance >> Rahul > >Yes, superposition! >
When we do testing of mechanical systems that are excited by deterministic signals such as engine sinusoidal force, we need to be careful about collecting the phase information along with the magnitude. For example, forces at the engine mounts need to be known in magnitude and phase from the test so that they can be applied to the vehicle to know the vehicle response. If we need to use mathematical tools such as simulation using Finite Element Method, we take these measured forecs in magnitude and phase and carry out frequency response analysis. We can then find the response at a particular location such as steering or seat. This response will also be output in magnitude and phase by the software. My question is, can we not use PSD analysis using just the magnitude of these forces so that the efforts needed to accurately capture the phase would not be necssary? We can then just use the auto and cross PSDs of these forces at the mounts and carry out response PSD analysis for the vehicle using multiple input-single output methods of signal analysis. If we can, then why is this generally not done? would there be some mathematical reason for not carrying out analysis using PSDs of these deterministic signals? Generally, we use PSDs for random signal analysis only. I have not seen people using PSDs for deterministic signals. Is it because they do not want to deal with RMS output quantities? if so, I guess if we do take auto and cross PSDs of input, we can find peak values from RMS output by multiplying by sqrt(2). This would make the use of "Phase information" unnecessary.
On Jan 28, 9:36&#4294967295;pm, "rsk" <kalerahul@n_o_s_p_a_m.yahoo.com> wrote:
> My question is, can we not use PSD analysis using just the magnitude of > these forces so that the efforts needed to accurately capture the phase > would not be necssary? We can then just use the auto and cross PSDs of > these forces at the mounts and carry out response PSD analysis for the > vehicle using multiple input-single output methods of signal analysis. > If we can, then why is this generally not done? would there be some > mathematical reason for not carrying out analysis using PSDs of these > deterministic signals? Generally, we use PSDs for random signal analysis > only. I have not seen people using PSDs for deterministic signals. Is it > because they do not want to deal with RMS output quantities?
... Your continuous/periodic signals do not possess a Power Spectral Density. They are correctly represented with the Power Spectrum. See the application notes from a major supplier of vibration analysis instrumentation below, particularly page 30 of Bv0031.pdf. Bo0438.pdf Choose your Units! (PWR, PSD, ESD) www.bksv.com/doc/bo0438.pdf Bv0031.pdf Technical review No. 3 - 1987 http://bruel.ru/UserFiles/File/Review3_87.pdf or www.bksv.com/pdf/bv0031.pdf (The bksv.com site seems to request registration.) The article on page 29 this file is "Signal and Units" by Svend Gade and Henrik Herlufsen see page 30 Dale B. Dalrymple
On 1/29/2012 12:36 AM, rsk wrote:
> When we do testing of mechanical systems that are excited by deterministic > signals such as engine sinusoidal force, we need to be careful about > collecting the phase information along with the magnitude. For example, > forces at the engine mounts need to be known in magnitude and phase from > the test so that they can be applied to the vehicle to know the vehicle > response. If we need to use mathematical tools such as simulation using > Finite Element Method, we take these measured forecs in magnitude and phase > and carry out frequency response analysis. We can then find the response at > a particular location such as steering or seat. This response will also be > output in magnitude and phase by the software. > My question is, can we not use PSD analysis using just the magnitude of > these forces so that the efforts needed to accurately capture the phase > would not be necssary? We can then just use the auto and cross PSDs of > these forces at the mounts and carry out response PSD analysis for the > vehicle using multiple input-single output methods of signal analysis. > If we can, then why is this generally not done? would there be some > mathematical reason for not carrying out analysis using PSDs of these > deterministic signals? Generally, we use PSDs for random signal analysis > only. I have not seen people using PSDs for deterministic signals. Is it > because they do not want to deal with RMS output quantities? if so, I guess > if we do take auto and cross PSDs of input, we can find peak values from > RMS output by multiplying by sqrt(2). This would make the use of "Phase > information" unnecessary.
PSD is a statistical measure, most appropriate, as far as I know, for signals about which only statistics are known. As an analogy, compare specifying a color by hue and saturation to giving a detailed spectrum. I find it hard to see how truly random inputs with non-negligible magnitudes arise. Road irregularities possess the quality that only statistics are known, but that's not quite the same as truly random. There might be mathematical pitfalls if the distinction isn't at least kept in mind. Automobile suspensions are rarely linear. Shock absorbers have directional qualities and are usually mounted so that they pivot at the ends when in motion. Often, spring "constants" aren't constant. Whether such nonlinearities make superposition useless can't be guessed from a distance. Good luck! Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Sat, 28 Jan 2012 23:26:33 -0800 (PST), dbd <dbd@ieee.org> wrote:
>On Jan 28, 9:36=A0pm, "rsk" <kalerahul@n_o_s_p_a_m.yahoo.com> wrote: >... >> My question is, can we not use PSD analysis using just the magnitude of >> these forces so that the efforts needed to accurately capture the phase >> would not be necssary? We can then just use the auto and cross PSDs of >> these forces at the mounts and carry out response PSD analysis for the >> vehicle using multiple input-single output methods of signal analysis. >> If we can, then why is this generally not done? would there be some >> mathematical reason for not carrying out analysis using PSDs of these >> deterministic signals? Generally, we use PSDs for random signal analysis >> only. I have not seen people using PSDs for deterministic signals. Is it >> because they do not want to deal with RMS output quantities? >... > >Your continuous/periodic signals do not possess a Power Spectral >Density. They are correctly represented with the Power Spectrum. See >the application notes from a major supplier of vibration analysis >instrumentation below, particularly page 30 of Bv0031.pdf. > >Bo0438.pdf >Choose your Units! (PWR, PSD, ESD) >www.bksv.com/doc/bo0438.pdf > >Bv0031.pdf >Technical review No. 3 - 1987 >http://bruel.ru/UserFiles/File/Review3_87.pdf >or >www.bksv.com/pdf/bv0031.pdf >(The bksv.com site seems to request registration.) >The article on page 29 this file is >"Signal and Units" >by Svend Gade and Henrik Herlufsen >see page 30 > >Dale B. Dalrymple
Nice references, thanks for posting those. And I'd never heard of that company before, but it looks like they know what they're doing! Eric Jacobsen Anchor Hill Communications www.anchorhill.com
