Hi, I have a floating point c code to implement a navigation system algorithm. In order to implement it in the 64x+ fixed point DSP processor, i need to have the code in fixed point. I learnt that there are few processor specific IQmath libraries aiding this purpose. Is it practical to write the code using these libraries or should i manually write codes for each operation by scaling the inputs for each line of the code, in which case i have to create look up table for the trigonometric functions etc which is a harder process to begin with.. Thanks, Divya
floating point to fixed point conversion-in implementation of navigation system algorithm
Started by ●February 13, 2012
Reply by ●February 13, 20122012-02-13
On 2/13/12 11:38 AM, divya_divee wrote:> Hi, > I have a floating point c code to implement a navigation system > algorithm. > In order to implement it in the 64x+ fixed point DSP processor, i need to > have the code in fixed point. I learnt that there are few processor > specific IQmath libraries aiding this purpose. Is it practical to write > the code using these libraries or should i manually write codes for each > operation by scaling the inputs for each line of the code, in which case i > have to create look up table for the trigonometric functions etc which is a > harder process to begin with..i never thought creating a lookup table for a well defined function was a hard process. you can do it in C or MATLAB pretty easily. but lookup tables tak a lot of memory and, of course, have the "granulization error" that can be mitigated with linear interpolation or polynomial interpolation (like Hermite) of higher order than 1. but, if you end up dealing with discontinuities of the lookup table with smooth polynomials, you might want to evaluate these functions with finite order polynomials to begin with. it depends on how big this navigation system is. how many lines of code, how many different functions and files. i have converted floating-point algs to fixed-point many times before (in the field of audio processing), and the biggest problem i have is the numerical sloppiness that floating-point sometimes allows one to get away with. in fixed-point, you need to know your range of numbers and you need to apply the appropriate scaling to put that range of numbers into the range of the fixed-point DSP. all doable. and it takes time to do it right, and if you do it well, it might turn out better and more predictable than the floating-point model it was built on. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Mon, 13 Feb 2012 10:38:32 -0600, divya_divee wrote:> Hi, > I have a floating point c code to implement a navigation system > algorithm. > In order to implement it in the 64x+ fixed point DSP processor, i need > to have the code in fixed point. I learnt that there are few processor > specific IQmath libraries aiding this purpose. Is it practical to write > the code using these libraries or should i manually write codes for each > operation by scaling the inputs for each line of the code, in which case > i have to create look up table for the trigonometric functions etc which > is a harder process to begin with..Zeroth: Who the heck makes the "64+" DSP processor? I should know... What's your specific chip? First, some fixed-point DSP processors aren't too bad at floating point, so you may be able to just run the algorithm as-is. Second, I have some passing familiarity with nav system computations; converting one to fixed point ain't gonna be trivial -- particularly if you're doing matrix inversions. Third, many DSP processors have a sine look-up table tucked away in ROM somewhere; this at least gives you some of those trig functions. Forth, there are some tricks to be played in getting other functions, but it depends on your chip. Analog Devices 21xx parts were best at this -- they had a wide enough instruction word that you could do a MAC against a scalar x^n almost as easily as you could against a vector x[n], which made polynomial approximations easy-peasy. Fifth, nav system algorithms are approximations to begin with, and most of them are optimized to get grant money or to get the project done while the company still has research money. I rather suspect that in order to attain the overall goal of "make a nav system work with a fixed-point DSP" you need to start by designing (or finding) a nav algorithm that is tailored not only to fixed-point-ness in general, but possibly even to that specific processor. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
Tim Wescott <tim@seemywebsite.com> wrote: (snip, someone wrote)>> I have a floating point c code to implement a navigation system >> algorithm. >> In order to implement it in the 64x+ fixed point DSP processor, >> i need to have the code in fixed point.(snip)> Fifth, nav system algorithms are approximations to begin with, > and most of them are optimized to get grant money or to get the > project done while the company still has research money. > I rather suspect that in order to attain the overall goal of > "make a nav system work with a fixed-point DSP" you need to > start by designing (or finding) a nav algorithm that is > tailored not only to fixed-point-ness in general, but possibly > even to that specific processor.It does seem to me that fixed point, with a sufficient word size, is likely a better choice. It is rare to need a navagation system that works from nm to Gm. (That is, nanometers to gigameters.) Even in floating point, one has to be careful when adding and subtracting, not to lose most or all of the significant digits. As you mentioned matrix inversion, (which I snipped), it is very easy for intermediate steps to lose much of the precision. The usual answer is to do it in double precision to get single precision results. If you understand the math, though, keeping the required precision is likely easier in fixed point. -- glen
On 2/13/12 3:15 PM, glen herrmannsfeldt wrote:> Tim Wescott<tim@seemywebsite.com> wrote: > > (snip, someone wrote) >>> I have a floating point c code to implement a navigation system >>> algorithm. >>> In order to implement it in the 64x+ fixed point DSP processor, >>> i need to have the code in fixed point. > > (snip) >> Fifth, nav system algorithms are approximations to begin with, >> and most of them are optimized to get grant money or to get the >> project done while the company still has research money. >> I rather suspect that in order to attain the overall goal of >> "make a nav system work with a fixed-point DSP" you need to >> start by designing (or finding) a nav algorithm that is >> tailored not only to fixed-point-ness in general, but possibly >> even to that specific processor. > > It does seem to me that fixed point, with a sufficient word size, > is likely a better choice. It is rare to need a navagation system > that works from nm to Gm. (That is, nanometers to gigameters.) >i didn't consider matrix inversion (or even just Gaussian elimination). you can get really tiny or large numbers in intermediate states doing that.> Even in floating point, one has to be careful when adding and > subtracting, not to lose most or all of the significant digits.in audio, that's often the cosine problem, where cos(2*pi*f/Fs) is a number so close to 1 (because most of the interesting stuff in happening in the middle or bottom few octaves) that all of the information is in the difference from 1 which falls off the edge, even for floating point.> As you mentioned matrix inversion, (which I snipped), it is very > easy for intermediate steps to lose much of the precision.so, even for floating point, it's a good idea to remake your equations so that the "independent variable" is something in terms of 1-x, if x is expected to be close to 1.> The usual answer is to do it in double precision to get single > precision results. If you understand the math, though, keeping > the required precision is likely easier in fixed point.doing DSP in fixed point sorta imposes a discipline of *really* having to understand the alg and all of the intermediate quantities and states, so you know how big or small they can get. doing it in floating point sometimes gives one the *illusion* that they need not worry about it. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson <rbj@audioimagination.com> wrote: (big snip, then I wrote)>> The usual answer is to do it in double precision to get single >> precision results. If you understand the math, though, keeping >> the required precision is likely easier in fixed point.> doing DSP in fixed point sorta imposes a discipline of *really* having > to understand the alg and all of the intermediate quantities and states, > so you know how big or small they can get. doing it in floating point > sometimes gives one the *illusion* that they need not worry about it.And often in other than DSP, too. Floating point is great for quantities that vary over a large range, but have a similar relative error, and that are mostly mulitplied. For quantities where absolute error is more important, fixed point tends to be a better choice, but also when addition and subtraction are more common than multiply and divide. -- glen
On Mon, 13 Feb 2012 20:15:28 +0000, glen herrmannsfeldt wrote:> Tim Wescott <tim@seemywebsite.com> wrote: > > (snip, someone wrote) >>> I have a floating point c code to implement a navigation system >>> algorithm. >>> In order to implement it in the 64x+ fixed point DSP processor, i need >>> to have the code in fixed point. > > (snip) >> Fifth, nav system algorithms are approximations to begin with, and most >> of them are optimized to get grant money or to get the project done >> while the company still has research money. I rather suspect that in >> order to attain the overall goal of "make a nav system work with a >> fixed-point DSP" you need to start by designing (or finding) a nav >> algorithm that is tailored not only to fixed-point-ness in general, but >> possibly even to that specific processor. > > It does seem to me that fixed point, with a sufficient word size, is > likely a better choice. It is rare to need a navagation system that > works from nm to Gm. (That is, nanometers to gigameters.) > > Even in floating point, one has to be careful when adding and > subtracting, not to lose most or all of the significant digits. As you > mentioned matrix inversion, (which I snipped), it is very easy for > intermediate steps to lose much of the precision. The usual answer is to > do it in double precision to get single precision results. If you > understand the math, though, keeping the required precision is likely > easier in fixed point. > > -- glenI looked into doing a nav solution all in fixed point. I backed away from it. It's not that it couldn't be done -- it's just that the solution itself was not at all trivial, and trying to add fixed- pointedness on top of all that would have just been even more pain. Now, if you had a well-defined nav solution algorithm in hand, and you wanted to convert it to fixed point -- that might be doable. But even so, you'd be tasking yourself with doing some fairly heavy-duty linear algebraic operations all in fixed point. Until you've at least worked out the degree of difficulty to implement an extended Kalman filter in fixed point (which means you absolutely must calculate the covariance matrix on line), I don't think that you're in a position to speak wisely about whether it's practical. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
Reply by ●February 14, 20122012-02-14
Tim Wescott wrote:> On Mon, 13 Feb 2012 10:38:32 -0600, divya_divee wrote: >> I have a floating point c code to implement a navigation system >>algorithm. >>In order to implement it in the 64x+ fixed point DSP processor, i need >>to have the code in fixed point. I learnt that there are few processor >>specific IQmath libraries aiding this purpose. Is it practical to write >>the code using these libraries or should i manually write codes for each >>operation by scaling the inputs for each line of the code, in which case >>i have to create look up table for the trigonometric functions etc which >>is a harder process to begin with.. > > Zeroth: Who the heck makes the "64+" DSP processor?Maybe the OP means a "C64+" DSP which comes with some Texas Instruments SoC's, and I've seen that vague type name in their documents as well. I prefer saying "I code for a C64". Sounds more retro :-)> First, some fixed-point DSP processors aren't too bad at floating point, > so you may be able to just run the algorithm as-is. > > Second, I have some passing familiarity with nav system computations; > converting one to fixed point ain't gonna be trivial -- particularly if > you're doing matrix inversions.I've not done navigation on a DSP yet, just audio, but from what I gather there are algorithms that need the dynamic range of floating point. Things like the computation of a geo-distance, which could be halfway around the globe or just the next door. My company has done navigation on a Blackfin, with emulated floating point.> Third, many DSP processors have a sine look-up table tucked away in ROM > somewhere; this at least gives you some of those trig functions.I wonder why people think predefined trig support is so important for DSP. "Hey, software guy, I have this new DSP for you, which has a CORDIC coprocessor, which can compute arbitrary sine/cosine in just 10 cycles. I heard your MP3 decoder has a cosine transform, that must be wonderful for you!" - "No thanks, all I need is that 64-element array of constants and circular addressing." Stefan
Stefan Reuther <stefan.news@arcor.de> wrote: (snip)> I've not done navigation on a DSP yet, just audio, but from what I > gather there are algorithms that need the dynamic range of floating > point. Things like the computation of a geo-distance, which could be > halfway around the globe or just the next door. My company has done > navigation on a Blackfin, with emulated floating point.It isn't the dynamic range that matters, it is the range of the uncertainty. For more dynamic range, you can add more bits to either one. The positioning accuracy of GPS doesn't depend on how far you are going, but many measurement systems do. In many cases the uncertainty scales with the quantity being measured. The lattice constant (size of the unit cell of the crystal) for silicon, according to physics.nist.gov, is 543.1020504pm, with an uncertainty of 0.0000089pm. About 10 significant digits, or in binary, about 33 significant bits. Now, measure the distance from your house to the house next door, center to center. You would have a hard time even getting two significant digits. I guarantee you can't measure it with an uncertainty approaching 0.0000089pm. There are many cases where small quantities can be measured much more accurately, in both absolute and relative terms. When the uncertainty does not scale with the quantity being measured, fixed point of sufficient precision, is often a better choice. According to Knuth, two types of calculations should always be done in fixed point: financial and typesetting. (He wrote that while working on his TeX typesetting system.) He had an example where they were working with a typesetter that they were told printed at 5333dpi, but the printed output was visibly wrong. When they later found that it was 5333.3333... then everthing came out right. There is currently another thread discussing incoherent and coherent averaging. If the positions are off by 1 in 16000, randomly distributed, then it likely won't be visible. When the errors are not random, as in the case of roundoff, they can be surprisingly visible. In fixed point, you have full control over any rounding, but not, usually, in floating point. TeX uses fixed point for all calculations related to text positioning, floating point for some printed messages that don't affect the printed output. Positioning is done with 32 bit signed floating point with 16 bits after the binary point, with the unit being (1/72.27) inch. As for global positioning, I believe that the uncertainty in GPS is pretty much independent of the distance being measured. -- glen
On Tue, 14 Feb 2012 19:47:02 +0000, glen herrmannsfeldt wrote:> Stefan Reuther <stefan.news@arcor.de> wrote: > > (snip) >> I've not done navigation on a DSP yet, just audio, but from what I >> gather there are algorithms that need the dynamic range of floating >> point. Things like the computation of a geo-distance, which could be >> halfway around the globe or just the next door. My company has done >> navigation on a Blackfin, with emulated floating point. > > It isn't the dynamic range that matters, it is the range of the > uncertainty. For more dynamic range, you can add more bits to either > one. > > The positioning accuracy of GPS doesn't depend on how far you are going, > but many measurement systems do. In many cases the uncertainty scales > with the quantity being measured. > > The lattice constant (size of the unit cell of the crystal) for silicon, > according to physics.nist.gov, is 543.1020504pm, with an uncertainty of > 0.0000089pm. About 10 significant digits, or in binary, about 33 > significant bits. > > Now, measure the distance from your house to the house next door, center > to center. You would have a hard time even getting two significant > digits. I guarantee you can't measure it with an uncertainty approaching > 0.0000089pm. > > There are many cases where small quantities can be measured much more > accurately, in both absolute and relative terms. > > When the uncertainty does not scale with the quantity being measured, > fixed point of sufficient precision, is often a better choice. According > to Knuth, two types of calculations should always be done in fixed > point: financial and typesetting. (He wrote that while working on his > TeX typesetting system.) > > He had an example where they were working with a typesetter that they > were told printed at 5333dpi, but the printed output was visibly wrong. > When they later found that it was 5333.3333... then everthing came out > right. > > There is currently another thread discussing incoherent and coherent > averaging. If the positions are off by 1 in 16000, randomly distributed, > then it likely won't be visible. When the errors are not random, as in > the case of roundoff, they can be surprisingly visible. In fixed point, > you have full control over any rounding, but not, usually, in floating > point. TeX uses fixed point for all calculations related to text > positioning, floating point for some printed messages that don't affect > the printed output. Positioning is done with 32 bit signed floating > point with 16 bits after the binary point, with the unit being (1/72.27) > inch. > > As for global positioning, I believe that the uncertainty in GPS is > pretty much independent of the distance being measured.The problem under review is a navigation system, which means GPS + inertial measurements. The conceptually simplest way to represent positions in this circumstance is in earth-centered, earth-fixed coordinates; when you do that, you end up with the distance between you and the the center of the earth _all the time_. So your dynamic range immediately becomes something like +/-6.4 million meters in any of your three position variables (assuming you want your algorithm to work anywhere on earth), vs. whatever accuracy you want to achieve. So if you're trying for one-meter accuracy and trying to set quantization noise to 1/10th your accuracy, then you're up to needing 26 bits right there. Granted, you can make an approximation around any one spot on earth (the dean's office in your university, or better yet your project advisor) and significantly simplify the algorithm -- but you do so at the cost of making it only work in the vicinity of that spot. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
