I want to Execute MATLAB file with TMS320C54X
Started by Unknown October 4, 2004
Hi all,
    I did Image Compression task using SPIHT algorithm with MATLAb 6.5 code.
   Now i want to implement the same with TMS320C54X. How can i do this with
CCS ?
   Can any body help me  ?
   But i do not want to copy the MATLAB Libabry files in to CCS.
   Thanks in advance,
Sathish
"Sathish" <saikumar.mangapuram@de.bosch.com> wrote in message
news:cjrq7o$o8g$1@ns1.fe.internet.bosch.com...
> Hi all, > I did Image Compression task using SPIHT algorithm with MATLAb 6.5 > code. > > Now i want to implement the same with TMS320C54X. How can i do this with > CCS ? > > Can any body help me ? > But i do not want to copy the MATLAB Libabry files in to CCS.
I guess you might start by converting the Matlab files into "C". Then, work to get the converted code running, etc. If the libraries are an issue (which is well imaginable) then you need a new set of library routines that are compatible with the code or change the code to call new/different library routines ...... Fred
Hi Fred Marshall,
     Thank you very much for your suggestion.
Sathish
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> wrote in message
news:0fednbjDZJGPe_zcRVn-hg@centurytel.net...
> > "Sathish" <saikumar.mangapuram@de.bosch.com> wrote in message > news:cjrq7o$o8g$1@ns1.fe.internet.bosch.com... > > Hi all, > > I did Image Compression task using SPIHT algorithm with MATLAb 6.5 > > code. > > > > Now i want to implement the same with TMS320C54X. How can i do this
with
> > CCS ? > > > > Can any body help me ? > > But i do not want to copy the MATLAB Libabry files in to CCS. > > I guess you might start by converting the Matlab files into "C". > Then, work to get the converted code running, etc. > > If the libraries are an issue (which is well imaginable) then you need a
new
code
> to call new/different library routines ...... > > Fred > >
