Hi, I have a problem, I have a oversampled (OSR =16) Digital Signal, prior to downsampling a filter is used, a 16 Tap BandpassFIR filter wich also have a Window. 1. Is there a document or approch how to calculate mathematically the resolution / Accuracy after the Filter, the Window and after the Decimation. (Filterquantisation ?) What errrors come from the Window ?? What role does the Window play (The FIR BAndpass is used to fit the signals frequncy to allow downsampling I suppose) But for what use a window ? I would be happy about some help ! Thaks Sascha
Help Understanding - Decimation, Anti-Alias and Accuracy !
Started by ●December 17, 2003
Reply by ●December 17, 20032003-12-17
"Sascha" <Sascha-78@web.de> wrote in message news:fbc8cc04.0312170828.59845f50@posting.google.com...> Hi, > > > I have a problem, I have a oversampled (OSR =16) Digital Signal, prior > to downsampling a filter is used, a 16 Tap BandpassFIR filter wich > also have a Window. > > 1. Is there a document or approch how to calculate mathematically the > resolution / Accuracy after the Filter, the Window and after the > Decimation. (Filterquantisation ?) What errrors come from the Window > ?? > > What role does the Window play (The FIR BAndpass is used to fit the > signals frequncy to allow downsampling I suppose) But for what use a > window ?Sascha, Let's see if this doesn't help: First, let's just stick with the window question. The resolution / accuracy question is quite another matter and you'll need to do some work to arrive at reasonable answers. This is very much dependent on your implementation and can't be dealt with at a more abstract level really. Let's assume that the filter is operating in the time domain - so you have no overlap-save process associated with using fft/ifft frequency domain multiplicative filtering. Then we'll also assume that the data comes in a continuous stream out of the filter. The next step in the process is critical. If you are going to select a "chunk" or "temporal epoch" of the data for some sort of processing - for example for processing by a finite-length fft - then you are perforce using a *rectangular* window (the sequence of samples is unweighted) that has a corresponding sin(f)/f type of frequency convolution associated with it. sin(f)/f introduces large spectral leakage componenets and is sometimes unacceptable. So, instead of staying with the effects of the rectangular window, another window is multiplied onto the data segment to get smaller spectral leakage. There's plenty of literature on the subject. Fred Fred
