Hello, I am going to recover the instantaneous frequency f(t) of a chirp signal y(t) using hilbert transform. Here is my MATLAB code: Fs = 1000; % Sampling frequency T = 2; % Signal time duration is 2 seconds. t=0:1/Fs:T; f0 = 50; % Initial frequency is 50hz f1 = 100; % f(t) changes from 50hz to 100Hz in 2 seconds. freq = f0 + (f1-f0)/T*t; y = sin(2*pi*freq.*t); % Chirp signal y(t) figure(1); plot(t, freq); % Spectrum Plot of y(t) N_FFT = 1024; % Number of FFT points y_FFT = fft(y,N_FFT); f = round(Fs*(0:N_FFT/2)/N_FFT); % Frequency scaling figure(2); plot(f, 20*log10(abs(y_FFT(1:N_FFT/2+1)))) % Hilbert tranform for instantaneous frequency recovery output = real(y); output_h = hilbert(output); theta = angle(output_h); ins_freq = angle(conv(ones(1,5),output_h(2:length(output_h)).*conj(output_h(1:length(output_h)-1)))); figure; plot((1:1:length(ins_freq))/Fs, ins_freq*Fs/2/pi) The result I got is different from my initial setting. f(t) should linearly change from 50hz to 100hz in 2seconds but in my result the instantaneous frequency (ins_freq) changes (also linearly) from 50hz to 150hz, i.e. the bandwidth is two times of my initial setting. Could you please point out my error? Thanks a lot!
Instantaneous frequency recovery using hilbert transform
Started by ●October 3, 2004
Reply by ●October 3, 20042004-10-03
"Yan.L" <waters@starhub.net.sg> wrote in message news:df850db4.0410031551.1f99b1ce@posting.google.com...> Could > you please point out my error? Thanks a lot!Your error is to assume that phase = 2*pi*frequency*time; the actual circumstance is that 2*pi*frequency = time derivative of phase. If f(t) = f0+(f1-f0)/(t1-t0)*(t-t0), then phase(t) = 2*pi*(f0+(f1-f0)/(t1-t0)*(t-t0)/2).*(t-t0)+phase0 -- write(*,*) transfer((/17.392111325966148d0,6.5794487871554595D-85, & 6.0134700243160014d-154/),(/'x'/)); end
