Hello, I recently got an ADUC831 microconverter board, and am interested in experimenting with DSP applied to an audio input and/or output. A friend who is knowledgeable about these boards recommended "passing audio input through an op-amp to protect the board." His meaning appears to be that I should connect my 1/8 in. jack to an op-amp, and the op-amp to the ADC input, in such a way that if I should inadvertantly overdrive the board, the ($1.50) op-amp will blow first and spare the ($70) board. IOW, that I should use the op-amp as a fancy fuse, and possibly as a clipper circuit at the same time. Is that a standard practice? Can anyone offer pointers on using an op-amp in this way? Alternately, can anyone recommend a better approach? Thanks! Len.
Q: op-amp to protect DSP board?
Started by ●December 13, 2003
Reply by ●December 14, 20032003-12-14
lbudney@pobox.com wrote:> Hello, > > I recently got an ADUC831 microconverter board, and am interested in > experimenting with DSP applied to an audio input and/or output. A > friend who is knowledgeable about these boards recommended "passing > audio input through an op-amp to protect the board." > > His meaning appears to be that I should connect my 1/8 in. jack to an > op-amp, and the op-amp to the ADC input, in such a way that if I > should inadvertantly overdrive the board, the ($1.50) op-amp will blow > first and spare the ($70) board. IOW, that I should use the op-amp as > a fancy fuse, and possibly as a clipper circuit at the same time. > > Is that a standard practice? Can anyone offer pointers on using an > op-amp in this way? Alternately, can anyone recommend a better > approach? > > Thanks! > Len.First off, your approach would mean modifying the board in a way that I would avoid. If I felt that I needed that protection, I would connect my signal to an off-board op-amp and connect its output to the jack. If your source is a microphone, you don't need any protection at all. For other sources, a series resistor might be perfectly adequate. You might also consider back-to-back Zener diodes. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry, Thanks for your reply! Jerry Avins <jya@ieee.org> wrote:> lbudney@pobox.com wrote: >> >> [using an op-amp to protect a DSP board] > > First off, your approach would mean modifying the board in a way that I > would avoid.If I implied that, I apologize. The suggestion was to construct a board with an op-amp, and then use wire-wrap to connect that to the board.> If I felt that I needed that protection, I would connect my > signal to an off-board op-amp and connect its output to the jack.A big part of my question is, "When do you feel you need it?" How about when connecting standard audio devices, such as walkmen or radios, to the board's input? Or speakers to its output?> If your source is a microphone, you don't need any protection at all. For > other sources, a series resistor might be perfectly adequate. You might > also consider back-to-back Zener diodes.What circuit are you envisioning? I thought of using a zener between the input pin and the ground pin as a voltage regulator, but I'm not sure what "back-to-back" means in this context. Upon further searching, I believe my friend's suggestion was to use the op-amp as a voltage follower. Does that by itself do any good? Would a voltage follower preceded by a zener (bridging the + input to the board's ground) be better? Or in that case, is the zener the only useful component anyway? I'm close to designing a circuit as follows, but have no idea if it's on the right track: 1) One line from the jack to the ground pin (using wire-wrap). 2) The other line to two resistors and a zener, forming a T. 3) The zener bridges the jack's leads. 4) Output of the T network to the + input of the op-amp. 5) Op-amp output to the - input and to the board's input. Between the output and the - input, I considered tweaking with a resistor, if necessary, so that the audio device's max output will arrive at maybe 90% of the board's max allowed input. Critique? Thanks! Len.
lbudney@pobox.com (Len Budney) wrote in news:9213c87c.0312140524.68f0af4b@posting.google.com: Chances are very good that you don't need anything. Without seeing the front end circuit, this is a guess: If it makes you feel better, add a 1000 Ohm series resistor to the input. I am assuming that the input impedance might be about 10K. This will attenuate the signal by about 1dB. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com> Jerry, > > Thanks for your reply! > > Jerry Avins <jya@ieee.org> wrote: >> lbudney@pobox.com wrote: >>> >>> [using an op-amp to protect a DSP board] >> >> First off, your approach would mean modifying the board in a way that >> I would avoid. > > If I implied that, I apologize. The suggestion was to construct a > board with an op-amp, and then use wire-wrap to connect that to the > board. > >> If I felt that I needed that protection, I would connect my >> signal to an off-board op-amp and connect its output to the jack. > > A big part of my question is, "When do you feel you need it?" How > about when connecting standard audio devices, such as walkmen or > radios, to the board's input? Or speakers to its output? > >> If your source is a microphone, you don't need any protection at >> all. For other sources, a series resistor might be perfectly >> adequate. You might also consider back-to-back Zener diodes. > > What circuit are you envisioning? I thought of using a zener between > the input pin and the ground pin as a voltage regulator, but I'm not > sure what "back-to-back" means in this context. > > Upon further searching, I believe my friend's suggestion was to use > the op-amp as a voltage follower. Does that by itself do any good? > Would a voltage follower preceded by a zener (bridging the + input to > the board's ground) be better? Or in that case, is the zener the only > useful component anyway? > > I'm close to designing a circuit as follows, but have no idea if it's > on the right track: > > 1) One line from the jack to the ground pin (using wire-wrap). > 2) The other line to two resistors and a zener, forming a T. > 3) The zener bridges the jack's leads. > 4) Output of the T network to the + input of the op-amp. > 5) Op-amp output to the - input and to the board's input. > > Between the output and the - input, I considered tweaking with a > resistor, if necessary, so that the audio device's max output will > arrive at maybe 90% of the board's max allowed input. Critique? > > Thanks! > Len. >-- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Len Budney wrote:> Jerry, > > Thanks for your reply! > > Jerry Avins <jya@ieee.org> wrote: > >>lbudney@pobox.com wrote: >> >>>[using an op-amp to protect a DSP board] >> >>First off, your approach would mean modifying the board in a way that I >>would avoid. > > > If I implied that, I apologize. The suggestion was to construct a > board with an op-amp, and then use wire-wrap to connect that to the > board.No need even to wire wrap. Use a piece of shielded cable with an eighth-inch plug on the end. Anyhow, shielded cable is hard to wire wrap. (With driver impedance low enough, twisted pair might suffice.)>>If I felt that I needed that protection, I would connect my >>signal to an off-board op-amp and connect its output to the jack. > > > A big part of my question is, "When do you feel you need it?" How > about when connecting standard audio devices, such as walkmen or > radios, to the board's input? Or speakers to its output?Use the back of an envelope. The jack is certainly able to handle a typical "line out" signal. That's at least 1 V RMS. It would be poor design if 3-volt peaks could damage it. Look at the codec spec sheet. My guess is that driving the input even to the rails won't hurt if the current is kept low enough. Internally, it's probably clamped to the rails, but maybe not. Look and see. What is the operating impedance of the input to the chip? My guess is that it's in the order of a megohm. Speakers should be connected through a voltage divider. At very high outputs, the audio may be distorted, but a modest output signal overrides the output-stage noise present in all but the best amplifiers. Making the impedance of the voltage might be all the additional protection needed. Too high an impedance, whether of a divider or a stopper resistor, will degrade the highs. A CD player rarely operates on more than 6 volts, so even with an H-bridge driver, the headphone output won't exceed 5 V peak. (10 V P-P: ouch!) The line out will be lower voltage and less distortion. Use that. Assuming that the input is clamped to 5-volts and ground and the source voltage can go as high as ten volts peak, 1 10 K series resistor will limit the input current to 1 ma peak (but you need a bigger resistor to withstand shorts to the power line).>>If your source is a microphone, you don't need any protection at all. For >>other sources, a series resistor might be perfectly adequate. You might >>also consider back-to-back Zener diodes.>> What circuit are you envisioning? I thought of using a zener between > the input pin and the ground pin as a voltage regulator, but I'm not > sure what "back-to-back" means in this context.A Zener breaks down in the reverse direction. In the forward direction, its characteristics are similar to any other semiconductor diode. To get a double knee, you need to connect two anode to anode or cathode to cathode.> Upon further searching, I believe my friend's suggestion was to use > the op-amp as a voltage follower. Does that by itself do any good?Not for large inputs. It may isolate the board from static discharges. But it might not.> Would a voltage follower preceded by a zener (bridging the + input to > the board's ground) be better? Or in that case, is the zener the only > useful component anyway?Probably.> I'm close to designing a circuit as follows, but have no idea if it's > on the right track: > > 1) One line from the jack to the ground pin (using wire-wrap). > 2) The other line to two resistors and a zener, forming a T. > 3) The zener bridges the jack's leads. > 4) Output of the T network to the + input of the op-amp. > 5) Op-amp output to the - input and to the board's input. > > Between the output and the - input, I considered tweaking with a > resistor, if necessary, so that the audio device's max output will > arrive at maybe 90% of the board's max allowed input. Critique?A decent board should be capable of withstanding moderate overload. 90% of "maximum allowable" is probably OK. That ought to be nearly double the maximum for linear operation. The circuit you describe seems liable to hum pickup. Allow for shielding to be added later if it's needed. That means that flying wires won't do. You want the noise floor to be set by quantization. If you aren't careful, hum and noise from the preamp will dominate.> Thanks!You're welcome. Good luck. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●December 15, 20032003-12-15
Len Budney wrote: || || A big part of my question is, "When do you feel you need it?" How || about when connecting standard audio devices, such as walkmen or || radios, to the board's input? Or speakers to its output? || ||| If your source is a microphone, you don't need any protection at ||| all. For other sources, a series resistor might be perfectly ||| adequate. You might also consider back-to-back Zener diodes. || || What circuit are you envisioning? I thought of using a zener between || the input pin and the ground pin as a voltage regulator, but I'm not || sure what "back-to-back" means in this context. || || Upon further searching, I believe my friend's suggestion was to use || the op-amp as a voltage follower. Does that by itself do any good? || Would a voltage follower preceded by a zener (bridging the + input to || the board's ground) be better? Or in that case, is the zener the only || useful component anyway? || || I'm close to designing a circuit as follows, but have no idea if it's || on the right track: || || 1) One line from the jack to the ground pin (using wire-wrap). || 2) The other line to two resistors and a zener, forming a T. || 3) The zener bridges the jack's leads. || 4) Output of the T network to the + input of the op-amp. || 5) Op-amp output to the - input and to the board's input. || || Between the output and the - input, I considered tweaking with a || resistor, if necessary, so that the audio device's max output will || arrive at maybe 90% of the board's max allowed input. Critique? || || Thanks! || Len. That thing with the opamp is not a protection at all, who wants to blow the opamp, it needed to be replaced and probably it could still blow the board. You really need a good protection if you have some automobile environment. There short transients up to 150V can occurr. The simple circuit down will do that. The fuse can be dropped if you use a 10k or don't have a continuous high voltage such as mains to protect from. There should be some big electrolytic caps on the board (100uF) or a 5.6V zener to protect the supply in case it is 5V. VCC VCC + -- | \ - BAS70-04 /\ 5.6V Zener 0.03A fast ^ dual schottky -- once only ____ ___ | | o--|_--_|---|___|--+-----o === fuse 1k...10k | port pin GND - ^ | each port === GND If you want an even better protection without much current flowing you could also use a diode ring which will continuously protect even to mains without a series resistor, but it might induce a few millivolts of offset. Eventually only the resistors will burn out. Again both +/-5V need a zener across like above. +5V | .-. | |10k | | '-' | +-|<-+->|-+ in | | port o-------+ 1N4936 +---+--o | | | +->|-+-|<-+ - | ^4148 .-. | | |10k === | | GND '-' | -5V created by Andy�s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de -- ciao Ban Bordighera, Italy electronic hardware designer
