basic bpsk bandwidth question
Started by recoder ●March 7, 2012
Dear All,
 Assume that we have 1kbps data, if we BPSK modulate it on a 2 khz
carrier  with 2 period per bit, we have a 1 khz wide signal centered
at 2 khz so the 3 dB bandwidth of the signal is 1 khz.
 If we increase the carrier to 4 khz with 2 period per bit, we have a
data speed of 2 kbps and a 1khz wide signal centered at 4 khz.The 3 db
bandwidth is still 1 khz for 2 kbps.
 Can you point out my error?
On 3/7/2012 9:13 AM, recoder wrote:
> Dear All, > Assume that we have 1kbps data, if we BPSK modulate it on a 2 khz > carrier with 2 period per bit, we have a 1 khz wide signal centered > at 2 khz so the 3 dB bandwidth of the signal is 1 khz.
Phase-shift keying is not AM. You need to understand "modulation index". Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Mar 7, 9:13=A0am, recoder <kurtulmeh...@gmail.com> wrote:
> Dear All, > =A0Assume that we have 1kbps data, if we BPSK modulate it on a 2 khz > carrier =A0with 2 period per bit, we have a 1 khz wide signal centered > at 2 khz so the 3 dB bandwidth of the signal is 1 khz.
> =A0Can you point out my error?
Err, *how* do you get 1 kbps binary data into a 500 Hz bandwidth? BPSK modulation doubles the bandwidth of the baseband BPSK pulse and centers it at the carrier frequency.
On Wed, 7 Mar 2012 06:13:22 -0800 (PST), recoder
<kurtulmehtap@gmail.com> wrote:
>Dear All, > Assume that we have 1kbps data, if we BPSK modulate it on a 2 khz >carrier with 2 period per bit, we have a 1 khz wide signal centered >at 2 khz so the 3 dB bandwidth of the signal is 1 khz.
Sounds right to me.
> If we increase the carrier to 4 khz with 2 period per bit, we have a >data speed of 2 kbps and a 1khz wide signal centered at 4 khz.The 3 db >bandwidth is still 1 khz for 2 kbps. > Can you point out my error?
The period of the carrier at 4kHz is half that of the carrier at 2kHz, so the symbol rate has doubled. This doubles the 3dB bandwidth of the signal. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On Wed, 07 Mar 2012 06:13:22 -0800, recoder wrote:
> Dear All, > Assume that we have 1kbps data, if we BPSK modulate it on a 2 khz > carrier with 2 period per bit, we have a 1 khz wide signal centered at > 2 khz so the 3 dB bandwidth of the signal is 1 khz. > If we increase the carrier to 4 khz with 2 period per bit, we have a > data speed of 2 kbps and a 1khz wide signal centered at 4 khz.The 3 db > bandwidth is still 1 khz for 2 kbps. > Can you point out my error?
Which one? If you have 1kbps data, BPSK modulated on a 2kHz carrier, (with, by the definitions so far has 2 carrier periods per bit), then you have a signal that's far wider than 1kHz. It's not really centered at 2kHz any more, because the sidelobes on the BPSK subtract between 1kHz and 2kHz, but add between 2kHz and 3kHz. I'm too damn lazy to compute where the 3dB down points are, but they're not at 1.5kHz and 2.5kHz, at least not simultaneously. Moreover, when you do your modulation at such a low proportion of the carrier frequency, the relative phase of the switching point matters -- switch phase at the zero crossings of the carrier and you'll have less high-frequency content in your signal than if you switch phase at the maxima. Again, I'm too damn lazy to do the math, but those sharp corners when you switch at the maxima have to count for something. If you scale the whole problem up in frequency by a factor of two, then you have 2kHz BPSK modulation, so of course your 3dB down points (wherever they were to start with) will be twice as far apart in frequency as they were before. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
On Thu, 08 Mar 2012 01:35:46 -0600, Tim Wescott
<tim@seemywebsite.please> wrote:
>On Wed, 07 Mar 2012 06:13:22 -0800, recoder wrote: > >> Dear All, >> Assume that we have 1kbps data, if we BPSK modulate it on a 2 khz >> carrier with 2 period per bit, we have a 1 khz wide signal centered at >> 2 khz so the 3 dB bandwidth of the signal is 1 khz. >> If we increase the carrier to 4 khz with 2 period per bit, we have a >> data speed of 2 kbps and a 1khz wide signal centered at 4 khz.The 3 db >> bandwidth is still 1 khz for 2 kbps. >> Can you point out my error? > >Which one? > >If you have 1kbps data, BPSK modulated on a 2kHz carrier, (with, by the >definitions so far has 2 carrier periods per bit), then you have a signal >that's far wider than 1kHz. It's not really centered at 2kHz any more, >because the sidelobes on the BPSK subtract between 1kHz and 2kHz, but add >between 2kHz and 3kHz. I'm too damn lazy to compute where the 3dB down >points are, but they're not at 1.5kHz and 2.5kHz, at least not >simultaneously.
I'm not quite sure what you're thinking, but what he described is consistent with a 1kHz symbol frequency on a 2kHz center frequency. For BPSK, QPSK, QAM, or most single-carrier modulations the 3dB bandwidth is essentially the symbol rate (depending only a little bit on how the filtering is done).
>Moreover, when you do your modulation at such a low proportion of the >carrier frequency, the relative phase of the switching point matters -- >switch phase at the zero crossings of the carrier and you'll have less >high-frequency content in your signal than if you switch phase at the >maxima. Again, I'm too damn lazy to do the math, but those sharp corners >when you switch at the maxima have to count for something.
If one generates the BPSK signal at baseband and then mixes it up to fc, one has the same BPSK baseband signal (with 3dB bandwidth essentially equal to the symbol rate), translated to fc. It doesn't really matter how high or low fc is, it just translates the signal spectrum to that frequency. 2kHz is not at all impractical for a center frequency for a BPSK signal with a 1kHz symbol rate.
>If you scale the whole problem up in frequency by a factor of two, then >you have 2kHz BPSK modulation, so of course your 3dB down points >(wherever they were to start with) will be twice as far apart in >frequency as they were before.
When he kept the constraint that the symbol period was two cycles of the carrier frequency it doubled the symbol rate when the carrier frequency was doubled. Doubling the symbol rate doubles the 3dB bandwidth of the signal. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On Mar 8, 12:13=A0pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote:
> > If one generates the BPSK signal at baseband and then mixes it up to > fc, one has the same BPSK baseband signal (with 3dB bandwidth > essentially equal to the symbol rate), translated to fc. =A0 =A0It doesn'=
t
> really matter how high or low fc is, it just translates the signal > spectrum to that frequency. =A0 2kHz is not at all impractical for a > center frequency for a BPSK signal with a 1kHz symbol rate.
Eric: If the 3dB bandwidth of a signal at baseband is fs Hz, then, for those who believe in negative frequencies, the baseband spectrum extends from -fs Hz to +fs Hz (at least in the 3dB sense). When modulated on to a carrier at fc Hz, the 3 dB signal bandwidth extends from fc - fs to fc + fs (and from -fc-fs to -fc+fs) so that the modulated signal has a 3dB bandwidth of 2fs, not fs. So, if a passband 1 kbps BPSK signal with 3dB bandwidth of 1kHz is desired, the baseband BPSK signal needs to have a 3dB bandwidth of 500 Hz in the ordinary sense of amplitude modulation x(t)cos(2 pi fc t) which translates the baseband spectrum to be centered at the carrier frequency fc. Or you can say that the baseband 1 kbps BPSK signal really has 3 dB bandwidth 1 kHz, but we are going to use single sideband modulation to create a passband signal of 3dB bandwidth 1 kHz centered at frequency fc, which is quite different from the amplitude modulation described above. In particular, the carrier frequency corresponding to this SSB modulation would be fc-500 and not fc, right? So, could you describe in a little more detail exactly what the 1 kbps baseband BPSK signal x(t) with 500 Hz 3dB bandwidth looks like so that x(t)cos(2 pi fc t) gives a BPSK signal with 3dB bandwidth 1 kHz centered at fc Hz, or the modulation process for creating the SSB signal? Dilip Sarwate
On Thu, 8 Mar 2012 09:55:41 -0800 (PST), dvsarwate
<dvsarwate@yahoo.com> wrote:
>On Mar 8, 12:13=A0pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote: > >> >> If one generates the BPSK signal at baseband and then mixes it up to >> fc, one has the same BPSK baseband signal (with 3dB bandwidth >> essentially equal to the symbol rate), translated to fc. =A0 =A0It doesn'= >t >> really matter how high or low fc is, it just translates the signal >> spectrum to that frequency. =A0 2kHz is not at all impractical for a >> center frequency for a BPSK signal with a 1kHz symbol rate. > > >Eric: > >If the 3dB bandwidth of a signal at baseband is fs Hz, >then, for those who believe in negative frequencies, the >baseband spectrum extends from -fs Hz to +fs Hz >(at least in the 3dB sense). When modulated on to a >carrier at fc Hz, the 3 dB signal bandwidth extends >from fc - fs to fc + fs (and from -fc-fs to -fc+fs) so that >the modulated signal has a 3dB bandwidth of 2fs, not fs. >So, if a passband 1 kbps BPSK signal with 3dB bandwidth >of 1kHz is desired, the baseband BPSK signal needs to >have a 3dB bandwidth of 500 Hz in the ordinary sense >of amplitude modulation x(t)cos(2 pi fc t) which translates >the baseband spectrum to be centered at the carrier >frequency fc. > >Or you can say that the baseband 1 kbps BPSK signal >really has 3 dB bandwidth 1 kHz, but we are going to >use single sideband modulation to create a passband >signal of 3dB bandwidth 1 kHz centered at frequency fc, >which is quite different from the amplitude modulation >described above. In particular, the carrier frequency >corresponding to this SSB modulation would be fc-500 >and not fc, right? > >So, could you describe in a little more detail exactly >what the 1 kbps baseband BPSK signal x(t) with 500 Hz >3dB bandwidth looks like so that x(t)cos(2 pi fc t) gives >a BPSK signal with 3dB bandwidth 1 kHz centered at >fc Hz, or the modulation process for creating the SSB >signal? > >Dilip Sarwate > >
I'll give it a shot. The short answer is that it's not SSB. The 3dB "bandwidth" of a BPSK signal with a symbol rate (and therefore bit rate) of 1kHz to a comm guy like me is 1 kHz, even when it's at baseband (centered at DC). BPSK and QPSK signals differ only by the presence or absence of the "imaginary" or "Q" or "orthogonal" second channel, which does not affect the bandwidth, only the symmetry, or lack thereof, of the occupied signal spectrum. So most comm guys, I would argue, don't consider the BW of a BPSK signal to be one-sided at baseband, even though it's symmetric about DC, because that's the ONLY time it would arguably have the narrower bandwidth. It would also mean that BSPK would be treated (or thought of) differently than it's close cousins QPSK and QAM, and there's no real reason to treat it differently, even though it's essentially real-valued. Also, like QPSK, when the BPSK signal spectrum is mixed to an IF frequency, 2 kHz in the first example, it is usually a complex mix so that the two-sided bandwidth is preserved. Again, this is the same as would be done with a QPSK or QAM signal (or essentially any comm signal with a quadrature component). The BPSK signal isn't treated differently even though it does not have the associated quadrature component. Since the "real" part of the output of the complex upconversion is taken as the ultimate transmit signal that actually goes out the antenna, for BPSK this boils down to a simple DSB upconversion as could be done in an AM system. The output is similarly a DSB, symmetric, two-sided signal spectrum. So a transmitter that only ever transmits BPSK doesn't need a complex upconverter, since it boils down to the same as DSB AM upconversion. The only real difference in this case is that at very low center frequencies (e.g., less than ~500Hz+rolloff margin for the 1kHz symbol rate), the DSB system would have a negative-frequency image that would inferfere with the desired signal, while a complex upconverter would not. My understanding is that the OP's system has a symbol (bit) rate of 1kHz, so the baseband signal extends from -500 to +500 Hz. Mixing that to 2kHz, either with a complex mix or a real DSB mix, results in a signal extending from 1.5kHz to 2.5kHz, still with 1kHz 3dB BW. In the OP's second case the center frequency is 4kHz, but the symbol rate is held to two periods of the carrier frequency, or Tsym = 2/4kHz, so that the symbol rate is now 2kHz. The bit rate doubles and the signal bandwidth doubles with the doubling of the symbol rate. If the symbol rate were held constant in time, rather than constant in carrier period intervals, the bandwidth and bit rate would be held to 1kHz. I suspect it was a test or homework problem because it requires one to think about the relationship between the carrier frequency and symbol state stated in the problem. There usually isn't such a relationship, so it seems like a test or homework problem to me. It's a reasonably clever one, too, IMHO. It seems to have tripped up the OP at least a little bit. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On Mar 8, 7:27=A0pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote:
Eric:
Thanks for taking the time to write such a detailed answer.
Unfortunately, I still have some questions and hope that
you will indulge me further because there are still some
gaps in my understanding of the issues.
Let us ignore the OP's question and the 2 kHz carrier versus
the 4 kHz carrier and any associated problems that might be
caused by the low carrier frequency.  You say
> The 3dB "bandwidth" of a BPSK signal with a symbol rate (and therefore > bit rate) of 1kHz to a comm guy like me is 1 kHz, even when it's at > baseband (centered at DC).
I think there is a trivial typo and that you meant to say that a BPSK signal with symbol rate and bit rate of 1 kbps (not 1 kHz) at baseband (that is, a center frequency of 0 Hz or DC) has a 1 kHz bandwidth. To me, your statement also says that the spectrum of the baseband BPSK signal extends from -1 kHz to +1 kHz. But to you and presumably most other comm guys, it means that the the spectrum extends only from -500 Hz to +500 Hz since you say later that
could be done in an AM system. The output is similarly a DSB, symmetric, two-sided signal spectrum. If the passband BPSK signal at center frequency fc Hz (and let's not drag in the OP's 2 kHz or 4kHz here) also has a bandwidth of 1 kHz, then its baseband signal must be extending from -500 Hz to +500 Hz only in order that the passband signal x(t)cos(2 pi fc t) will extend from fc-500 Hz to fc+500 Hz for a passband bandwidth of 1 kHz. (There is a mirror image at negative frequency -fc Hz that is irrelevant to this discussion). This follows from the Fourier transform of x(t)cos(2 pi fc t), plain vanilla DSB-SC modulation, is (1/2)[X(f - fc) + X(f + fc)] where X(f-fc) is the translation of the baseband spectrum X(f) to be centered at fc.
> My understanding is that the OP's system has a symbol (bit) rate of > 1kHz, so the baseband signal extends from -500 to +500 Hz.
So, could you please tell me with symbols and equations rather than in words and generalities, a formula that can be used to figure out what x(t) is during a one-millisecond interval (say from t =3D -0.0005 to t =3D +0.0005) during which time interval, the BPSK signal transmits one bit? Since this is (antipodal) BPSK, perhaps the formula will include something like (-1)^(b)p(t) where b is the bit (0 or 1) so that (-1)^b evaluates to +1 or -1 giving antipodality and p(t) will be the baseband pulse. It would be very helpful if you could tell me the time domain shape of p(t), and the Fourier transform P(f) would be helpful too. The reason for asking for all this, and hoping that you will be kind enough to reply with the desired formula is that there seems to be a disconnect between the meaning of bandwidth of baseband digital signals and low-frequency analog audio signals. An audio signal has spectrum extending out to 20 kHz (and to -20 KHz too) and is said to have a bandwidth of 20 kHz (which is why CDs use sampling at 44.1 kHz, somewhat larger than twice the highest frequency) but a 1 kbps baseband BPSK signal has a bandwidth of 1 kHz but its spectrum extends out to only 500 Hz (and to - 500 Hz). Thus, bandwidth seems to mean different things depending on whether we are talking of analog signals or digitally modulated signals. Dilip Sarwate
On Thu, 8 Mar 2012 19:37:16 -0800 (PST), dvsarwate
>On Mar 8, 7:27=A0pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote: > >Eric: > >Thanks for taking the time to write such a detailed answer. >Unfortunately, I still have some questions and hope that >you will indulge me further because there are still some >gaps in my understanding of the issues. > >Let us ignore the OP's question and the 2 kHz carrier versus >the 4 kHz carrier and any associated problems that might be >caused by the low carrier frequency. You say > >> The 3dB "bandwidth" of a BPSK signal with a symbol rate (and therefore >> bit rate) of 1kHz to a comm guy like me is 1 kHz, even when it's at >> baseband (centered at DC). > >I think there is a trivial typo and that you meant to say >that a BPSK signal with symbol rate and bit rate of >1 kbps (not 1 kHz) at baseband (that is, a center >frequency of 0 Hz or DC) has a 1 kHz bandwidth.
Generally the symbol rate is expressed in Hz (or baud, for the more picky), so in this case with 1 bit/symbol when talking about the symbol rate and bit rate in the same breath one could use either bps or Hz. IMHO, of course.
>To >me, your statement also says that the spectrum of the >baseband BPSK signal extends from -1 kHz to +1 kHz. >But to you and presumably most other comm guys, it >means that the the spectrum extends only from -500 Hz >to +500 Hz since you say later that > >>for BPSK this boils down to a simple DSB upconversion as >could be done in an AM system. The output is similarly a DSB, >symmetric, two-sided signal spectrum. > >If the passband BPSK signal at center frequency fc Hz >(and let's not drag in the OP's 2 kHz or 4kHz here) also >has a bandwidth of 1 kHz, then its baseband signal must >be extending from -500 Hz to +500 Hz only in order that >the passband signal x(t)cos(2 pi fc t) will extend from >fc-500 Hz to fc+500 Hz for a passband bandwidth of 1 kHz. >(There is a mirror image at negative frequency -fc Hz that >is irrelevant to this discussion). This follows from the Fourier >transform of x(t)cos(2 pi fc t), plain vanilla DSB-SC modulation, >is (1/2)[X(f - fc) + X(f + fc)] where X(f-fc) is the translation >of the baseband spectrum X(f) to be centered at fc. > >> My understanding is that the OP's system has a symbol (bit) rate of >> 1kHz, so the baseband signal extends from -500 to +500 Hz. > >So, could you please tell me with symbols and equations >rather than in words and generalities, a formula that >can be used to figure out what x(t) is during a >one-millisecond interval (say from t =3D -0.0005 to t =3D +0.0005) >during which time interval, the BPSK signal transmits >one bit? Since this is (antipodal) BPSK, perhaps >the formula will include something like (-1)^(b)p(t) where b >is the bit (0 or 1) so that (-1)^b evaluates to +1 or -1 >giving antipodality and p(t) will be the baseband pulse. >It would be very helpful if you could tell me the time >domain shape of p(t), and the Fourier transform P(f) >would be helpful too.
I think there's a quicker answer that I can give below, plus it's late in the day and at the moment I'm too lazy to dig up the formal equations. I can say, though, that the expressions for BPSK and QPSK are the same with the exception that QPSK has two copies of the BPSK representation, summed with one of them with a coefficient of 'j'. QAM is just QPSK with additional, independent, amplitude terms on both the real and imaginary (or, if you're a comm guy, the in-phase and quadrature) components. The time domain shape of the pulses varies widely, from rectangular pulses to root-raised cosine to all manner of things in between and elsewise. That's always a system engineering decision to choose between one of the infinite number of possible pulse shapes, assuming it's not specified for standard compliance or something.
>The reason for asking for all this, and hoping that >you will be kind enough to reply with the desired >formula is that there seems to be a disconnect >between the meaning of bandwidth of baseband >digital signals and low-frequency analog audio >signals. An audio signal has spectrum extending out >to 20 kHz (and to -20 KHz too) and is said to have >a bandwidth of 20 kHz (which is why CDs use >sampling at 44.1 kHz, somewhat larger than twice >the highest frequency) but a 1 kbps baseband BPSK >signal has a bandwidth of 1 kHz but its spectrum >extends out to only 500 Hz (and to - 500 Hz). Thus, >bandwidth seems to mean different things depending >on whether we are talking of analog signals or digitally >modulated signals. > >Dilip Sarwate
Yes, the terms are used differently here, for the case of a signal "at baseband", to a digital comm guy, or an audio signal. There's a good reason for this, I think. The audio signal sitting between 0 and y Hz lives there natively, occurs there naturally, is consumed there, and if generally processed there (within that frequency range). So the primary area of interest, in all phases of generation, processing, and consumption, occur within that band and with general disregard for the frequency components mirrored on the negative side of DC. Audio signals are often thought of and processed as real-valued. Comm signals, on the other hand, may be generated at baseband, but live much of their lives elsewhere at IF or RF and even other exotic frequencies, where the bandwidth of the signal exists independently far away from DC. In order to be consistent, the "bandwidth" of the signal is generally taken to be determined by the 3dB points on the rolloff on either side of the center frequency. When the signal is generated at baseband, or mixed back down there in a receiver, measuring "bandwidth" from DC to the positive-frequency 3dB rolloff point becomes inconsistent with the "bandwidth" that the signal had at IF or RF. Also, since comm signals are routinely and, these days, almost always processed at baseband with both real and imaginary components (even when it's BPSK), the baseband signal is NOT assumed to be symmetric about DC. It will be for a pristine BPSK signal generated in a modulator, but in a demodulator it often won't be due to channel distortion, interference, and all manner of evil and abuse that may have befallen it on it's way through the dark forests of the channel. Any higher-order modulation will have independent information in each of the in-phase and quadrature channels, so even with the possibility that BPSK might be symmetric the general thinking and processing for comm is done with the assumption that the baseband spectrum cannot be assumed to be symmetric about DC except under special circumstances. So, yeah, a comm guy will measure "bandwidth" from -fx to +fx at baseband, and an audio guy will have no reason to do that and plenty of reason not to. It is, however, just a matter of translating zero Herz to where one is most comfortable. For many, including comm people, having zero Hz (or, for those so inclined, zero rad/sec) in the middle of the spectrum of interest is often very natural and desirable. I think for anybody who routinely deals with analytic signals this may be the case. For others it might be more natural to keep the frequency origin comfortably far to the left, so that no negative frequencies have to be imagined or dealt with, all signals are real-valued, and the direct connection to related physical phenomena is kept as close as possible. Or something like that. ;) Eric Jacobsen Anchor Hill Communications www.anchorhill.com
