Cryptography: serial-link validation
Started by Tim Wescott ●March 8, 2012
I'm not even sure of the correct term to use.
I want to build some security into a product that uses a pair of
controllers communicating by RS-232.  I'd like the "slave" controller to
require the "master" controller to perform some sort of validation before
the slave will respond with any but the most basic of keep-alive messages.
This whole thing doesn't need to be perfect: it just needs to discourage
all but the serious hackers from breaking into the link.
I'm pretty sure that the best way to do this is to have the slave send a
challenge to the master, and only open up if it gets the correct response.
What's the right place to go to find a good method, or do you have any
suggestions?
My liberal friends think I'm a conservative kook.
My conservative friends think I'm a liberal kook.
Why am I not happy that they have found common ground?
Tim Wescott, Communications, Control, Circuits & Software
http://www.wescottdesign.com
Hello Tim,
if it is possible to store a secret key in both controllers, it could be
done like this:
- the master sends a command to the slave
- the slave stores the command, generates a random number, encrypts it
  and sends the result to the master
- the master decrypts the the random number and sends it back
- if the random number matches, the slave executes the command
As encryption algorithm you could use AES.
Downsides:
- needs bandwidth (2 x 16 bytes)
- the communication (command and the response to it) is not
  secure
But the slave would only execute commands from the master.
HTH
bye. Mike
Tim Wescott wrote:
> I'm not even sure of the correct term to use. > > I want to build some security into a product that uses a pair of > controllers communicating by RS-232. I'd like the "slave" controller to > require the "master" controller to perform some sort of validation before > the slave will respond with any but the most basic of keep-alive messages. > > This whole thing doesn't need to be perfect: it just needs to discourage > all but the serious hackers from breaking into the link. > > I'm pretty sure that the best way to do this is to have the slave send a > challenge to the master, and only open up if it gets the correct response. > > What's the right place to go to find a good method, or do you have any > suggestions?
Schneier's _Applied Cryptography_, once you've allowed for the errata. Off the top of my head, if the command protocol called for adding random salt, and/or a checksum and encrypting, then you might count on valid commands coming only from the real master. Mel.
On 09/03/2012 01:14, Tim Wescott wrote:
> I'm not even sure of the correct term to use. > > I want to build some security into a product that uses a pair of > controllers communicating by RS-232. I'd like the "slave" controller to > require the "master" controller to perform some sort of validation before > the slave will respond with any but the most basic of keep-alive messages. > > This whole thing doesn't need to be perfect: it just needs to discourage > all but the serious hackers from breaking into the link. > > I'm pretty sure that the best way to do this is to have the slave send a > challenge to the master, and only open up if it gets the correct response. > > What's the right place to go to find a good method, or do you have any > suggestions? >
I assume that the master and slave can share some sort of pre-defined key. The slave picks a random number, and sends it to the master. The master applies an encryption function, then sends the encrypted version back. The slave does the same encryption itself, and compares. For the encryption function, I'd recommend a CRC. You probably already have a CRC in the code somewhere anyway, they are easy to code, and they are very good at "messing up" numbers, so that it is practically impossible to predict the patterns. Your encryption function is just a CRC of the random number, the shared key, and some salt (a fixed value shared by all your systems). If you want to encrypt the actual communication, I'd recommend starting with this same process. Then you take the encrypted code (which both sides know) and use that as the seed for a pseudo-random number generator (there are lots of algorithms for these, it doesn't need to be particularly good or random). These pseudo-random numbers are used to make an xor-mask that you apply to the actual data telegrams. Depending on your paranoia, you can pick different lengths of masks, and pick how often you change it (every telegram, every hour, whatever).
On 03/09/2012 10:04 AM, David Brown wrote:
> The slave picks a random number, and sends it to the master. The master > applies an encryption function, then sends the encrypted version back. > The slave does the same encryption itself, and compares. > > For the encryption function, I'd recommend a CRC. You probably already > have a CRC in the code somewhere anyway, they are easy to code, and they > are very good at "messing up" numbers, so that it is practically > impossible to predict the patterns. Your encryption function is just a > CRC of the random number, the shared key, and some salt (a fixed value > shared by all your systems).
A CRC is cryptographically very weak, because CRC(A XOR B) = CRC(A) XOR CRC(B). It's probably good enough for the casual hacker, but it won't stop anybody serious.. I'd recommend using XXTEA instead. See http://en.wikipedia.org/wiki/XXTEA It's very easy to implement, while providing a good level of security.
On 09/03/2012 10:50, Arlet Ottens wrote:
> On 03/09/2012 10:04 AM, David Brown wrote: > >> The slave picks a random number, and sends it to the master. The master >> applies an encryption function, then sends the encrypted version back. >> The slave does the same encryption itself, and compares. >> >> For the encryption function, I'd recommend a CRC. You probably already >> have a CRC in the code somewhere anyway, they are easy to code, and they >> are very good at "messing up" numbers, so that it is practically >> impossible to predict the patterns. Your encryption function is just a >> CRC of the random number, the shared key, and some salt (a fixed value >> shared by all your systems). > > A CRC is cryptographically very weak, because CRC(A XOR B) = CRC(A) XOR > CRC(B). It's probably good enough for the casual hacker, but it won't > stop anybody serious.. >
As far as I understood the OP, it's the casual hacker we are dealing with here. You are right of course that CRC is cryptographically weak, but it is much simpler and faster to implement and execute than cryptographically strong (or "stronger") encryption functions. If it is good enough for the application, then it is good enough. XXTEA, or cryptographic checksums like SHA are obviously much stronger, but are a worse solution if they are not needed.
> I'd recommend using XXTEA instead. See > http://en.wikipedia.org/wiki/XXTEA It's very easy to implement, while > providing a good level of security.
On Thursday, March 8, 2012 7:14:00 PM UTC-5, Tim Wescott wrote:
> I'm not even sure of the correct term to use. >=20 > I want to build some security into a product that uses a pair of=20 > controllers communicating by RS-232. I'd like the "slave" controller to=
=20
> require the "master" controller to perform some sort of validation before=
=20
> the slave will respond with any but the most basic of keep-alive messages=
>=20 > This whole thing doesn't need to be perfect: it just needs to discourage=
=20
> all but the serious hackers from breaking into the link. >=20 > I'm pretty sure that the best way to do this is to have the slave send a=
=20
> challenge to the master, and only open up if it gets the correct response=
>=20 > What's the right place to go to find a good method, or do you have any=20 > suggestions? >=20 > --=20 > My liberal friends think I'm a conservative kook. > My conservative friends think I'm a liberal kook. > Why am I not happy that they have found common ground? >=20 > Tim Wescott, Communications, Control, Circuits & Software > http://www.wescottdesign.com
Hello Tim, I've actually done this with a serial dongle I designed. I implemented RSA = in a pic. You can verify the dongle is there by sending over some random nu= mbers encrypted with your half of the key and the dongle decodes with his h= alf of the key and sends it back to you to verify against the original rand= om numbers you picked. Likewise the dongle verifies you by a similar action= where it picks random numbers and sends them to you encrypted and you have= to decrypt them and send them back.=20 The number crunching takes a few seconds, but it is quite secure if you pic= k large keys. Clay
On Fri, 09 Mar 2012 10:50:51 +0100, Arlet Ottens wrote:
> On 03/09/2012 10:04 AM, David Brown wrote: > >> The slave picks a random number, and sends it to the master. The master >> applies an encryption function, then sends the encrypted version back. >> The slave does the same encryption itself, and compares. >> >> For the encryption function, I'd recommend a CRC. You probably already >> have a CRC in the code somewhere anyway, they are easy to code, and >> they are very good at "messing up" numbers, so that it is practically >> impossible to predict the patterns. Your encryption function is just a >> CRC of the random number, the shared key, and some salt (a fixed value >> shared by all your systems). > > A CRC is cryptographically very weak, because CRC(A XOR B) = CRC(A) XOR > CRC(B). It's probably good enough for the casual hacker, but it won't > stop anybody serious.. > > I'd recommend using XXTEA instead. See > http://en.wikipedia.org/wiki/XXTEA It's very easy to implement, while > providing a good level of security.
I had considered CRC, and it's probably good enough -- but if I can implement something better easily, I will. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Tim Wescott schrieb:
> On Fri, 09 Mar 2012 10:50:51 +0100, Arlet Ottens wrote: >> On 03/09/2012 10:04 AM, David Brown wrote: >> >>> The slave picks a random number, and sends it to the master. The master >>> applies an encryption function, then sends the encrypted version back. >>> The slave does the same encryption itself, and compares. >>> >>> For the encryption function, I'd recommend a CRC. You probably already >>> have a CRC in the code somewhere anyway, they are easy to code, and >>> they are very good at "messing up" numbers, so that it is practically >>> impossible to predict the patterns. Your encryption function is just a >>> CRC of the random number, the shared key, and some salt (a fixed value >>> shared by all your systems). >> >> A CRC is cryptographically very weak, because CRC(A XOR B) = CRC(A) XOR >> CRC(B). It's probably good enough for the casual hacker, but it won't >> stop anybody serious.. >> >> I'd recommend using XXTEA instead. See >> http://en.wikipedia.org/wiki/XXTEA It's very easy to implement, while >> providing a good level of security. > > I had considered CRC, and it's probably good enough -- but if I can > implement something better easily, I will.
Basically, you are searching for a MAC (message authentication code). You can build a weak one using CRC or you can replace CRC by a cryptographic hash function like MD5 or SHA. SHA-256 can be implemented straight forward from the NIST paper in less than 100 lines of C code. If you don't have enough space for the whole MAC in your protocol, you can truncate it (while losing a bit of security). Markus
I don't think that makes sense. What's the point of "protecting" the connection if the only thing an attacker would need is to sniff into the link _after_ it's been authenticated? Just about the bare minimum level of security worth having would require 1) some half-decent crypto and robust (P)RNG to authenticate endpoints 2) based on 1), generate and exchange random keys for the main data transfer 3) using the keys from 2), encrypt _all_ sensitive data using a cypher focussed on throughput (a "stream cypher") 4) for long-running connections, go back to 2) or even 1) every once in a while Serious choices would be RSA or DH for 1), DES or AES for 3) If you want to keep it simple, MD5 for 1), XOR for 3)
