On 4/4/2012 4:24 PM, Bret Cahill wrote:>> Because if you ain't applying a filter to the purpose for which it is >> designed > > If you can't figure out how to use convolutions and match filtering to > determine magnitudes of noisy signalsIsn't that what I said that it's *for*? Well, no, I didn't say anything about matched filters AND convolutions. I think of filtering *as* a convolution so I wouldn't generally say AND in that context. If course, amplitude is usually relative because one doesn't know the channel attenuation. If you have a stable channel then you might calibrate it. You seem to be arguing about something but I can't figure out what it is..... I'd be willing but in this case I take little responsibility for that. Fred
Iterative Match Filterings
Started by ●April 3, 2012
Reply by ●April 4, 20122012-04-04
Reply by ●April 5, 20122012-04-05
> >> Because if you ain't applying a filter to the purpose for which it is > >> designed > > > If you can't figure out how to use convolutions and match filtering to > > determine magnitudes of noisy signals you need to start a thread > > entitled "A Scholarly Enumeration of Filters & Their Purposes." > > (A): �_I_ can.You'll need to _demonstrate_ that with your post "A Scholarly Enumeration of Filters & Their Purposes." Bret Cahill
> Instead of just taking the convolution of a signal with the reference > or kernel once and then taking the square root in the frequency > domain, why not match filter with the reference again and again to > recover the original clean signal? > > Well, you _can_ do that if a wave form is all you want, but you can > get that from the ref. alone _anyway_. > > If you want to keep the original magnitude of the signal, however, and > if the kernel is a different magnitude than the original signal, then > you will only be working your way back to the kernel with each > iteration. > > The solution here is to convolve the signal with the kernel and then > the kernel with the kernel and then comparing the magnitudes of those > two convolutions. > > Apply that factor to correct the magnitude of the filtered signal.Or, if match filtering, square the magnitude of the match filtered signal and divide that by the magnitude of the kernel match filtered with itself. Bret Cahill
On 05/04/2012 00:24, Bret Cahill wrote:>> Because if you ain't applying a filter to the purpose for which it is >> designed > > If you can't figure out how to use convolutions and match filtering to > determine magnitudes of noisy signals you need to start a thread > entitled "A Scholarly Enumeration of Filters& Their Purposes." > > Maybe you can get it in Wikipedia! > > Bret CahillWiki is a bit weak on iterative deconvolution algorithms. The sort of thing you are asking about, or rather a version that actually works in practice was invented in 1974 by Hogbom as the CLEAN algorithm for radio astronomy. His original paper is online at: http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/clean_hogbom.pdf Variants of this algorithm are still used today in aperture synthesis although I prefer other deconvolution algorithms myself. -- Regards, Martin Brown
> >> Because if you ain't applying a filter to the purpose for which it is > >> designed > > > If you can't figure out how to use convolutions and match filtering to > > determine magnitudes of noisy signals you need to start a thread > > entitled "A Scholarly Enumeration of Filters& �Their Purposes." > > > Maybe you can get it in Wikipedia! > > > Bret Cahill > > Wiki is a bit weak on iterative deconvolution algorithms. > > The sort of thing you are asking about, or rather a version that > actually works in practice was invented in 1974 by Hogbom as the CLEAN > algorithm for radio astronomy. His original paper is online at: > > http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/clean... > > Variants of this algorithm are still used today in aperture synthesis > although I prefer other deconvolution algorithms myself.In match filtering the deconvolution step to recover the original [filtered]wave form isn't complicated. Just take the square root in the frequency domain, IMSQRT in Excel. Of course, if the magnitude of the kernel is different than the magnitude of the signal -- the general case -- then the magnitude of the recovered signal will be the sqrt of the product of the 2 magnitudes. If you want to get the original magnitude of the signal just square the mag. of the filtered signal and then divide by the mag. of the kernel, or, to keep errors equal, divide by the kernel match filtered with itself. This was done 7 decades ago, wasn't it? Bret Cahill
On 05/04/2012 15:37, Bret Cahill wrote:>>>> Because if you ain't applying a filter to the purpose for which it is >>>> designed >> >>> If you can't figure out how to use convolutions and match filtering to >>> determine magnitudes of noisy signals you need to start a thread >>> entitled "A Scholarly Enumeration of Filters& Their Purposes." >> >>> Maybe you can get it in Wikipedia! >> >>> Bret Cahill >> >> Wiki is a bit weak on iterative deconvolution algorithms. >> >> The sort of thing you are asking about, or rather a version that >> actually works in practice was invented in 1974 by Hogbom as the CLEAN >> algorithm for radio astronomy. His original paper is online at: >> >> http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/clean... >> >> Variants of this algorithm are still used today in aperture synthesis >> although I prefer other deconvolution algorithms myself. > > In match filtering the deconvolution step to recover the original > [filtered]wave form isn't complicated. Just take the square root in > the frequency domain, IMSQRT in Excel.Anyone who says deconvolution isn't complicated demonstrably does not have the first clue about the subject of signal processing. Convolution is easy but deconvolution is usually a very difficult inverse problem.> Of course, if the magnitude of the kernel is different than the > magnitude of the signal -- the general case -- then the magnitude of > the recovered signal will be the sqrt of the product of the 2 > magnitudes. > > If you want to get the original magnitude of the signal just square > the mag. of the filtered signal and then divide by the mag. of the > kernel, or, to keep errors equal, divide by the kernel match filtered > with itself. > > This was done 7 decades ago, wasn't it?Your description is so vague and woolly that it is impossible to determine what "this" you are referring to. If you mean noise adaptive Kalman filtering then it was actually first discovered in the 1880's by Thiele but published in Danish so no-one noticed it at all. His bad luck - he also explained Brownian motion well before Einstein. He came up recently in one of the periodic netkooks antisemitic rants against Einstein which flare up in sci.physics from time to time. http://groups.google.com/group/sci.physics/msg/586291ff896f9fd8?hl=en Only belatedly is poor Thiele's earlier work getting any recognition. http://en.wikipedia.org/wiki/Thorvald_Thiele Kalman filters are a heck of a lot of work to implement using pen and pencil in the days before digital computers. He was too far ahead of his time to get any recognition for his breakthrough in this field. -- Regards, Martin Brown
> >>>> Because if you ain't applying a filter to the purpose for which it is > >>>> designed > > >>> If you can't figure out how to use convolutions and match filtering to > >>> determine magnitudes of noisy signals you need to start a thread > >>> entitled "A Scholarly Enumeration of Filters& � �Their Purposes." > > >>> Maybe you can get it in Wikipedia! > > >>> Bret Cahill > > >> Wiki is a bit weak on iterative deconvolution algorithms. > > >> The sort of thing you are asking about, or rather a version that > >> actually works in practice was invented in 1974 by Hogbom as the CLEAN > >> algorithm for radio astronomy. His original paper is online at: > > >>http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/clean... > > >> Variants of this algorithm are still used today in aperture synthesis > >> although I prefer other deconvolution algorithms myself. > > > In match filtering the deconvolution step to recover the original > > [filtered]wave form isn't complicated. �Just take the square root in > > the frequency domain, IMSQRT in Excel. > > Anyone who says deconvolution isn't complicated demonstrably does not > have the first clue about the subject of signal processing.The issue here is the special kind of convolution used in match filtering. If you want to change the issue to convolutions generally feel free to start another thread.> Convolution > is easy but deconvolution is usuallyYea, _usually_. Does this include the convolution of a function with itself? Remember, no dodging.> a very difficult inverse problem.Unless the convolution is of a signal with a kernel or a kernel with itself. In that case the deconvolution just requires taking the square root in the frequency domain.> > Of course, if the magnitude of the kernel is different than the > > magnitude of the signal -- the general case -- then the magnitude of > > the recovered signal will be the sqrt of the product of the 2 > > magnitudes.> > If you want to get the original magnitude of the signal just square > > the mag. of the filtered signal and then divide by the mag. of the > > kernel, or, to keep errors equal, divide by the kernel match filtered > > with itself. > > > This was done 7 decades ago, wasn't it? > > Your description is so vague and woolly thatthat anyone with an even a junior level applied math background should be able to show it on Excel. WARNING: THIS MAY ALREADY BE ON A LINK SOMEWHERE! STOP DIGGING AND START GOOGLING! Bret Cahill
On Thu, 5 Apr 2012 09:27:23 -0700 (PDT), Bret Cahill <BretCahill@peoplepc.com> wrote:>> >>>> Because if you ain't applying a filter to the purpose for which it i= >s >> >>>> designed >> >> >>> If you can't figure out how to use convolutions and match filtering t= >o >> >>> determine magnitudes of noisy signals you need to start a thread >> >>> entitled "A Scholarly Enumeration of Filters& =A0 =A0Their Purposes." >> >> >>> Maybe you can get it in Wikipedia! >> >> >>> Bret Cahill >> >> >> Wiki is a bit weak on iterative deconvolution algorithms. >> >> >> The sort of thing you are asking about, or rather a version that >> >> actually works in practice was invented in 1974 by Hogbom as the CLEAN >> >> algorithm for radio astronomy. His original paper is online at: >> >> >>http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/clean..= >. >> >> >> Variants of this algorithm are still used today in aperture synthesis >> >> although I prefer other deconvolution algorithms myself. >> >> > In match filtering the deconvolution step to recover the original >> > [filtered]wave form isn't complicated. =A0Just take the square root in >> > the frequency domain, IMSQRT in Excel. >> >> Anyone who says deconvolution isn't complicated demonstrably does not >> have the first clue about the subject of signal processing. > >The issue here is the special kind of convolution used in match >filtering.Do you mean matched filtering or is "match" filtering something different? If you mean matched filtering then no special kind of convolution is needed. You need to clarify what you mean. You're getting flak back because the way you're describing things doesn't make much sense. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
In comp.dsp Martin Brown <|||newspam|||@nezumi.demon.co.uk> wrote: (snip)> Anyone who says deconvolution isn't complicated demonstrably does not > have the first clue about the subject of signal processing. Convolution > is easy but deconvolution is usually a very difficult inverse problem.Well, linear deconvolution isn't complicated, but it also often gives less than useful results. As usual, the non-linear case is more complicated than the linear case. I have previously recommended "Deconvolution of Images and Spectra" by Jansson. Rumors are that it is now available in an affordable paperback reprint. Otherwise it is pretty expensive. -- glen
> >> >>>> Because if you ain't applying a filter to the purpose for which it i= > >s > >> >>>> designed > > >> >>> If you can't figure out how to use convolutions and match filtering t= > >o > >> >>> determine magnitudes of noisy signals you need to start a thread > >> >>> entitled "A Scholarly Enumeration of Filters& =A0 =A0Their Purposes." > > >> >>> Maybe you can get it in Wikipedia! > > >> >>> Bret Cahill > > >> >> Wiki is a bit weak on iterative deconvolution algorithms. > > >> >> The sort of thing you are asking about, or rather a version that > >> >> actually works in practice was invented in 1974 by Hogbom as the CLEAN > >> >> algorithm for radio astronomy. His original paper is online at: > > >> >>http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/clean..= > >. > > >> >> Variants of this algorithm are still used today in aperture synthesis > >> >> although I prefer other deconvolution algorithms myself. > > >> > In match filtering the deconvolution step to recover the original > >> > [filtered]wave form isn't complicated. =A0Just take the square root in > >> > the frequency domain, IMSQRT in Excel. > > >> Anyone who says deconvolution isn't complicated demonstrably does not > >> have the first clue about the subject of signal processing. > > >The issue here is the special kind of convolution used in match > >filtering. > > Do you mean matched filtering or is "match" filtering something > different?North filter. Bret Cahill
