Iterative Match Filterings
Started by Bret Cahill ●April 3, 2012
On Thu, 5 Apr 2012 16:46:11 -0700 (PDT), Bret Cahill
<BretCahill@peoplepc.com> wrote:
>> >> >>>> Because if you ain't applying a filter to the purpose for which it i= >> >s >> >> >>>> designed >> >> >> >>> If you can't figure out how to use convolutions and match filtering t= >> >o >> >> >>> determine magnitudes of noisy signals you need to start a thread >> >> >>> entitled "A Scholarly Enumeration of Filters& =A0 =A0Their Purposes." >> >> >> >>> Maybe you can get it in Wikipedia! >> >> >> >>> Bret Cahill >> >> >> >> Wiki is a bit weak on iterative deconvolution algorithms. >> >> >> >> The sort of thing you are asking about, or rather a version that >> >> >> actually works in practice was invented in 1974 by Hogbom as the CLEAN >> >> >> algorithm for radio astronomy. His original paper is online at: >> >> >> >>http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/clean..= >> >. >> >> >> >> Variants of this algorithm are still used today in aperture synthesis >> >> >> although I prefer other deconvolution algorithms myself. >> >> >> > In match filtering the deconvolution step to recover the original >> >> > [filtered]wave form isn't complicated. =A0Just take the square root in >> >> > the frequency domain, IMSQRT in Excel. >> >> >> Anyone who says deconvolution isn't complicated demonstrably does not >> >> have the first clue about the subject of signal processing. >> >> >The issue here is the special kind of convolution used in match >> >filtering. >> >> Do you mean matched filtering or is "match" filtering something >> different? > >North filter. >
Far more commonly known as a "matched filter", which requires no special kind of convolution, only the ordinary, mundane kind. There's no deconvolution involved. You need to explain what you really mean, if you can. I suspect you're confused about it. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On Apr 5, 5:48&#4294967295;pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote:
> On Thu, 5 Apr 2012 16:46:11 -0700 (PDT), Bret Cahill > > > > > > <BretCah...@peoplepc.com> wrote: > >> >> >>>> Because if you ain't applying a filter to the purpose for which it i= > >> >s > >> >> >>>> designed > > >> >> >>> If you can't figure out how to use convolutions and match filtering t= > >> >o > >> >> >>> determine magnitudes of noisy signals you need to start a thread > >> >> >>> entitled "A Scholarly Enumeration of Filters& =A0 =A0Their Purposes." > > >> >> >>> Maybe you can get it in Wikipedia! > > >> >> >>> Bret Cahill > > >> >> >> Wiki is a bit weak on iterative deconvolution algorithms. > > >> >> >> The sort of thing you are asking about, or rather a version that > >> >> >> actually works in practice was invented in 1974 by Hogbom as the CLEAN > >> >> >> algorithm for radio astronomy. His original paper is online at: > > >> >> >>http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/clean..= > >> >. > > >> >> >> Variants of this algorithm are still used today in aperture synthesis > >> >> >> although I prefer other deconvolution algorithms myself. > > >> >> > In match filtering the deconvolution step to recover the original > >> >> > [filtered]wave form isn't complicated. =A0Just take the square root in > >> >> > the frequency domain, IMSQRT in Excel. > > >> >> Anyone who says deconvolution isn't complicated demonstrably does not > >> >> have the first clue about the subject of signal processing. > > >> >The issue here is the special kind of convolution used in match > >> >filtering. > > >> Do you mean matched filtering or is "match" filtering something > >> different? > > >North filter. > > Far more commonly known as a "matched filter",
How long did it take you to figure that out?
> which requires no > special kind of convolution, only the ordinary, mundane kind. &#4294967295;There's > no deconvolution involved.
How is the original waveform recovered with a North Filter? Bret Cahill
On Thu, 5 Apr 2012 20:51:49 -0700 (PDT), Bret Cahill
>On Apr 5, 5:48=A0pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote: >> On Thu, 5 Apr 2012 16:46:11 -0700 (PDT), Bret Cahill >> >> >> >> >> >> <BretCah...@peoplepc.com> wrote: >> >> >> >>>> Because if you ain't applying a filter to the purpose for whic= >h it i=3D >> >> >s >> >> >> >>>> designed >> >> >> >> >>> If you can't figure out how to use convolutions and match filte= >ring t=3D >> >> >o >> >> >> >>> determine magnitudes of noisy signals you need to start a threa= >d >> >> >> >>> entitled "A Scholarly Enumeration of Filters& =3DA0 =3DA0Their = >Purposes." >> >> >> >> >>> Maybe you can get it in Wikipedia! >> >> >> >> >>> Bret Cahill >> >> >> >> >> Wiki is a bit weak on iterative deconvolution algorithms. >> >> >> >> >> The sort of thing you are asking about, or rather a version that >> >> >> >> actually works in practice was invented in 1974 by Hogbom as the= > CLEAN >> >> >> >> algorithm for radio astronomy. His original paper is online at: >> >> >> >> >>http://www.astro.rug.nl/~vdhulst/SignalProcessing/Project1_data/c= >lean..=3D >> >> >. >> >> >> >> >> Variants of this algorithm are still used today in aperture synt= >hesis >> >> >> >> although I prefer other deconvolution algorithms myself. >> >> >> >> > In match filtering the deconvolution step to recover the original >> >> >> > [filtered]wave form isn't complicated. =3DA0Just take the square = >root in >> >> >> > the frequency domain, IMSQRT in Excel. >> >> >> >> Anyone who says deconvolution isn't complicated demonstrably does n= >ot >> >> >> have the first clue about the subject of signal processing. >> >> >> >The issue here is the special kind of convolution used in match >> >> >filtering. >> >> >> Do you mean matched filtering or is "match" filtering something >> >> different? >> >> >North filter. >> >> Far more commonly known as a "matched filter", > >How long did it take you to figure that out?
Far longer than it should have. What you've been describing isn't a matched filtering process, so perhaps you can understand the confusion among the readers about what you're talking about.
>> which requires no >> special kind of convolution, only the ordinary, mundane kind. =A0There's >> no deconvolution involved. > >How is the original waveform recovered with a North Filter?
You need to be clear what you mean by "original waveform". Matched filters are used for all sorts of tasks, from distance measuring (in radar, sonar, etc.) to recovering modulated data (in a communication system) to all sorts of other things. In a communication system the "original waveform" might be the modulated data, but that doesn't really translate well to a radar. Only you seem to know what you mean, and you need to provide something better than gibberish if you want others to contribute meaningfully to whatever questions you might have. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On 4/5/12 11:51 PM, Bret Cahill wrote:
> On Apr 5, 5:48 pm, eric.jacob...@ieee.org (Eric Jacobsen) wrote: >> On Thu, 5 Apr 2012 16:46:11 -0700 (PDT), Bret Cahill >> >>>> Do you mean matched filtering or is "match" filtering something >>>> different? >> >>> North filter. >> >> Far more commonly known as a "matched filter", > > How long did it take you to figure that out? > >> which requires no >> special kind of convolution, only the ordinary, mundane kind. There's >> no deconvolution involved. > > How is the original waveform recovered with a North Filter?
Bret, can you stick with the common semantic? before today, i have never heard of a "North filter". i am assuming from Eric's response and yours, that it is synonymous with "matched filter". a matched filter is not about recovering an original waveform. it is about *detecting* it (among some other "original waveforms") in the presence of noise or other crap that might obscure it. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
> >>>> Do you mean matched filtering or is "match" filtering something > >>>> different? > > >>> North filter. > > >> Far more commonly known as a "matched filter", > > > How long did it take you to figure that out? > > >> which requires no > >> special kind of convolution, only the ordinary, mundane kind. &#4294967295;There's > >> no deconvolution involved. > > > How is the original waveform recovered with a North Filter? > > Bret, can you stick with the common semantic? &#4294967295;before today, i have > never heard of a "North filter".
Is anyone still whining about "match filter" or "matched filter", both of which google up tens of thousands of on point hits in less time than it takes to play trifling word games.
> i am assuming from Eric's response and > yours, that it is synonymous with "matched filter".
http://en.wikipedia.org/wiki/Matched_filter Scroll down to the match filter recovery of the binary signal Bret Cahill
> What you've been describing isn't a > matched filtering process,
It works just fine on Excel, the recovery of the original signal waveform as well as the method outlined in the OP to recover the original amplitude. So unless there is some other filter out there that does what I'm doing, it's time to claim this puppy in a method patent. EXTRA CREDIT: If you multiply the FFTs of a noisy signal and its kernel on the SPICE electronics simulator -- this is faster and easier than Excel -- what would this represent? a. a match filter b. a wiener filter c. a kalman filter Bret Cahill
On 4/6/12 2:03 PM, Bret Cahill wrote:
>>>>>> Do you mean matched filtering or is "match" filtering something >>>>>> different? >> >>>>> North filter. >> >>>> Far more commonly known as a "matched filter", >> >>> How long did it take you to figure that out? >> >>>> which requires no >>>> special kind of convolution, only the ordinary, mundane kind. There's >>>> no deconvolution involved. >> >>> How is the original waveform recovered with a North Filter? >> >> Bret, can you stick with the common semantic? before today, i have >> never heard of a "North filter". > > Is anyone still whining about "match filter" or "matched filter", both > of which google up tens of thousands of on point hits in less time > than it takes to play trifling word games. > >> i am assuming from Eric's response and >> yours, that it is synonymous with "matched filter". > >> a matched filter is not about recovering an original waveform. > > http://en.wikipedia.org/wiki/Matched_filter > > Scroll down to the match filter recovery of the binary signal >
it's about detection. if you think that example is about producing a signal, rather than determining if a 0 or 1 had been transmitted, then you're mistaken. also, Wikipedia should not be taken as authoritative, even though sometimes it can be useful. and that wikipedia article is horrendously written (as well as the article on instantaneous phase/frequency). i might suggest finding a good communications textbook. maybe one by A Bruce Carlson or another by Haykin. finally, you need to learn to be nice when asking for help. if you know-it-all, then you don't need any advice or insight from me. g'bye. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Fri, 6 Apr 2012 11:21:02 -0700 (PDT), Bret Cahill
>> What you've been describing isn't a >> matched filtering process, > >It works just fine on Excel, the recovery of the original signal >waveform as well as the method outlined in the OP to recover the >original amplitude. So unless there is some other filter out there >that does what I'm doing, it's time to claim this puppy in a method >patent.
Knock yourself out, but if you call it a matched filter or describe it as a matched filtering process you'll just be confusing people.
>EXTRA CREDIT: > >If you multiply the FFTs of a noisy signal and its kernel on the SPICE >electronics simulator -- this is faster and easier than Excel -- what >would this represent? > >a. a match filter > >b. a wiener filter > >c. a kalman filter > > >Bret Cahill
As so many others have said, you have a problem communicating. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
> >>>>>> Do you mean matched filtering or is "match" filtering something > >>>>>> different? > > >>>>> North filter. > > >>>> Far more commonly known as a "matched filter", > > >>> How long did it take you to figure that out? > > >>>> which requires no > >>>> special kind of convolution, only the ordinary, mundane kind. &#4294967295;There's > >>>> no deconvolution involved. > > >>> How is the original waveform recovered with a North Filter? > > >> Bret, can you stick with the common semantic? &#4294967295;before today, i have > >> never heard of a "North filter". > > > Is anyone still whining about "match filter" or "matched filter", both > > of which google up tens of thousands of on point hits in less time > > than it takes to play trifling word games. > > >> i am assuming from Eric's response and > >> yours, that it is synonymous with "matched filter". > > >> a matched filter is not about recovering an original waveform. > > >http://en.wikipedia.org/wiki/Matched_filter > > > Scroll down to the match filter recovery of the binary signal > > it's about detection.
In that example the "detection" of the signal requires recovering the original waveform.
> if you think that example is about producing a > signal, rather than determining if a 0 or 1 had been transmitted, then > you're mistaken.
You think any convolution of a square wave form with its kernel could look like _that_?
You think an authoritative article is necessary for an _example_? Maybe you think the author put that nonsense in because he wanted to help out anyone trying to mislead on how match filtering can be used for wave form recovery? Bret Cahill
> >> What you've been describing isn't a > >> matched filtering process,
> >It works just fine on Excel, the recovery of the original signal > >waveform as well as the method outlined in the OP to recover the > >original amplitude. &#4294967295;So unless there is some other filter out there > >that does what I'm doing, it's time to claim this puppy in a method > >patent.
> Knock yourself out, but if you call it a matched filter or describe it > as a matched filtering process you'll just be confusing people.
Humor. I'd love to flatter myself into thinking I discovered a new signal processing filter. After all, I've been saying all along that there is low hanging fruit all over the place in engineering applications. But the reality is fundamentally new filters from a mathematics POV are very rare. They figured out everything related to convolutions in signal processing decades ago.
> >EXTRA CREDIT: > > >If you multiply the FFTs of a noisy signal and its kernel on the SPICE > >electronics simulator -- this is faster and easier than Excel -- what > >would this represent? > > >a. &#4294967295;a match filter > > >b. &#4294967295;a wiener filter > > >c. &#4294967295;a kalman filter > > >Bret Cahill > > As so many others have said, you have a problem communicating.
Can you think of more than one interpretation of what was posted above? Bret Cahill
