On Wed, 11 Apr 2012 07:53:43 -0700 (PDT), Bret Cahill <BretCahill@peoplepc.com> wrote:>> >>> > Depends on what you want from the matched filter >> >> >>> I want to do the classical thing. >> >> >>But supposing matched filtering could be adapted for another use where >> >>it was better than another popular filter, say, a Wiener filter? >> >> > Supposing you can drive a screw into a piece of wood faster with a >> > hammer than a screwdriver, =A0does that mean it's a better method? >> >> Eric, have you ever considered philosophy as a career? :) > >He dodged the issue so he might work out as a GOP political >"philosopher." > >Match filtering, or, if the additional deconvolution step is new, >"Matched Filtering/Magnitude Recovery" utilizes all of the phase angle >info as well as the PSD info and is, therefore, better than any other >filter as far as recovering the magnitude of the original signal."Matched" filtering can use all of the phase info, too, and very often does. You still seem to have a lot of misconceptions about what matched filtering is, what it does, and how it does it. What you've been describing is not matched filtering.>Matched filtering/signal recovery also seems to be a better way to >recover square waves out of noise than screwing around with triangle >shaped convolutions.The triangle-shaped convolution output *IS* the result of matched filtering against a square-wave input. If you get anything else out, it wasn't a matched filtering process. Your whole notion of "recovering the original waveform" is NOT a matched filtering process or objective in any usual sense. This has been pointed out to you multiple times. You're the one that cited Charan's tutorial page on matched filtering. You should take the time to actually understand it. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
Iterative Match Filterings
Started by ●April 3, 2012
Reply by ●April 11, 20122012-04-11
> >> >>> > Depends on what you want from the matched filter > > >> >>> I want to do the classical thing. > > >> >>But supposing matched filtering could be adapted for another use where > >> >>it was better than another popular filter, say, a Wiener filter? > > >> > Supposing you can drive a screw into a piece of wood faster with a > >> > hammer than a screwdriver, =A0does that mean it's a better method? > > >> Eric, have you ever considered philosophy as a career? :) > > >He dodged the issue so he might work out as a GOP political > >"philosopher." > > >Match filtering, or, if the additional deconvolution step is new, > >"Matched Filtering/Magnitude Recovery" utilizes all of the phase angle > >info as well as the PSD info and is, therefore, better than any other > >filter as far as recovering the magnitude of the original signal. > > "Matched" filtering can use all of the phase info, too, and very often > does.That's why I've been calling it "match filtering."> You still seem to have a lot of misconceptions about what > matched filtering is, what it does, and how it does it.> What you've been describing is not matched filtering.If there's some umbrella term for any filter that utilizes phase angle info as well as power spectrum info I'd probably use it. If not then I'll stick to using the only term where that holds.> >Matched filtering/signal recovery also seems to be a better way to > >recover square waves out of noise than screwing around with triangle > >shaped convolutions. > > The triangle-shaped convolution output *IS* the result of matched > filtering against a square-wave input.And that is exactly what I get before the deconvolution.> If you get anything else out, > it wasn't a matched filtering process.A match filter output, however, is a necessary intermediate step to get the final deconvolution.> Your whole notion of > "recovering the original waveform" is NOT a matched filtering process > or objective in any usual sense.At a minimum the first steps are identical to match filtering. Maybe another term reflecting the origins of the filter would be acceptable, i.e., "Match Filtering Plus" or "Matched Filtering/Signal Recovery." Not that I'm humble or anything but the "Bret Filter" doesn't explain it very well. That's why "North filter" never caught on. Bret Cahill
Reply by ●April 15, 20122012-04-15
> > Anyone who says deconvolution isn't complicated demonstrably does not > > have the first clue about the subject of signal processing. Convolution > > is easy but deconvolution is usually a very difficult inverse problem. > > Well, linear deconvolution isn't complicated,But, hey, a dunce wanted to sound like he knew something about math.> but it also often > gives less than useful results.And it often gives useful results. In any event, from the beginning the complete process of recovering the original signal should have been considered. Apparently this is something new as well as easy. Bret Cahill
On Apr 15, 1:52�pm, Bret Cahill <Bret_E_Cah...@yahoo.com> wrote:> > > Anyone who says deconvolution isn't complicated demonstrably does not > > > have the first clue about the subject of signal processing. Convolution > > > is easy but deconvolution is usually a very difficult inverse problem. > > > Well, linear deconvolution isn't complicated, > > But, hey, a dunce wanted to sound like he knew something about math. > > > but it also often > > gives less than useful results. > > And it often gives useful results. > > In any event, from the beginning the complete process of recovering > the original signal should have been considered. > > Apparently this is something new as well as easy. > > Bret CahillNobody has ever thought of it before. Let me cover it up before someone steals your idea...
Reply by ●April 17, 20122012-04-17
> > Anyone who says deconvolution isn't complicated demonstrably does not > > have the first clue about the subject of signal processing. Convolution > > is easy but deconvolution is usually a very difficult inverse problem.> Well, linear deconvolution isn't complicated,But, hey, a dunce wanted to sound like he knew something about math.> but it also often > gives less than useful results.And it often gives useful results. In any event, from the beginning the complete process of recovering the original signal should have been considered. Apparently this is something new as well as easy. Bret Cahill
On Apr 17, 1:24�pm, Bret Cahill <Bret_E_Cah...@yahoo.com> wrote:> > > Anyone who says deconvolution isn't complicated demonstrably does not > > > have the first clue about the subject of signal processing. Convolution > > > is easy but deconvolution is usually a very difficult inverse problem. > > Well, linear deconvolution isn't complicated, > > But, hey, a dunce wanted to sound like he knew something about math. >We get it, you are a genius, and everyone else are dunces.> > but it also often > > gives less than useful results. > > And it often gives useful results. > > In any event, from the beginning the complete process of recovering > the original signal should have been considered. > > Apparently this is something new as well as easy. > > Bret Cahill
In comp.dsp brent <bulegoge@columbus.rr.com> wrote: (snip on deconvolution)>> But, hey, a dunce wanted to sound like he knew something about math.http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dstripbooks&field-keywords=0486453251 It seems that it is available on June 20th. (Moon day, maybe that isn't a coincidence.) -- glen
> >> But, hey, a dunce wanted to sound like he knew something about math. > > http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dstripbooks&... > > It seems that it is available on June 20th.Apparently there is no disagreement on the following: 1. What is and has been called "matched filtering" for 7 decades doesn't recover the original signal, just the convolution. 2. The recovery of the original signal from the output of a matched filter is easy as all you need to do is take the square root of the convolution in the frequency domain, in excel IMSQRT of the FFT of the (output in the time domain). 3. There was never any reason for North not to consider trying to recover the original signal back in 1943 other than the distraction of a war. 4. There are many reasons to consider recovering the original signal. a. the "matched" part of the filtering may be treated as a distinct step that may be separate from the low pass filtering effect of the convolution. b. operations such as squelching the signal when the signal's 1st derivative exceeds a threshold are easy. c. it elegantly recovers a square / binary wave with screwing around with triangles. d. it's mathematically correct. Bret Cahill
On Apr 17, 3:56�pm, Bret Cahill <Bret_E_Cah...@yahoo.com> wrote:> > Apparently there is no disagreement on the following:Apparently not...
