What's under the hood??
Started by Mauritz Jameson ●April 3, 2012
Hey,
I just watched a demo of this amp profiler...I guess it's a kind of
system identification algorithm running under the hood? Any guesses as
to what type of algorithm is used to identify the amp transfer
function?
Demo:
http://www.youtube.com/watch?v=NyPgBzqKlUs
Thanks
On 4/3/2012 10:10 AM, Mauritz Jameson wrote:
> Hey, > > I just watched a demo of this amp profiler...I guess it's a kind of > system identification algorithm running under the hood? Any guesses as > to what type of algorithm is used to identify the amp transfer > function?
My guess about what he does isn't worth writing down. Just know that, since the amps being profiled in general are nonlinear, there is no transfer function as textbooks define it, Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
> My guess about what he does isn't worth writing down. Just know that, > since the amps being profiled in general are nonlinear, there is no > transfer function as textbooks define it,
Are you saying that you can't come up with a qualified guess? Yeah, I figured that the amp system is non-linear..but maybe it can be approximated by a linear system ? And if not, what type of algorithm do you use for estimating the non-linear function which maps input to output?
On 4/3/2012 1:01 PM, Mauritz Jameson wrote:
> >> My guess about what he does isn't worth writing down. Just know that, >> since the amps being profiled in general are nonlinear, there is no >> transfer function as textbooks define it, > > Are you saying that you can't come up with a qualified guess?
Sure I can guess, but my guess is not demonstrably better than yours. Nonlinear circuits don't have a transfer _function_, but they do have a transfer _characteristic_. Transfer characteristics don't support superposition because of nonlinearity, but in many cases they are independent of frequency over a range of interest. Many transfer characteristics can be adequately approximated by equations, and all can have their essences captured (frequency dependencies and power-supply droop aside) in a LUT.
> Yeah, I figured that the amp system is non-linear..but maybe it can be > approximated by a linear system ? And if not, what type of algorithm do > you use for estimating the non-linear function which maps input to > output?
You measure the input/output transfer characteristic using a variety of amplitudes and frequencies and go from there. You probably want to sample the output at 16 or 32 sample per cycle. From what you learn, you construct a model that lets you compute (volts out)/(volts in) for any input signal. Auxiliary algorithms can simulate power droop during long loud passages. The innovation lies not so much not in what to do as in how to do it. As far as I am personally moved, it has no interest. I learned electronics in the 50's building (later designing) home hi-fi sound systems. The whole point was minimizing distortion and other nonlinearities. I generally prefer the sound of acoustic guitar both because I don't need to wear my gunnery-range ear protectors and because the barbaric distortion that many guitarists like is absent. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:
> On 4/3/2012 10:10 AM, Mauritz Jameson wrote: >> Hey, >> >> I just watched a demo of this amp profiler...I guess it's a kind of >> system identification algorithm running under the hood? Any guesses as >> to what type of algorithm is used to identify the amp transfer >> function? > > My guess about what he does isn't worth writing down. Just know that, > since the amps being profiled in general are nonlinear, there is no > transfer function as textbooks define it, > > Jerry
People do use the term "transfer function" to describe "graphs of input-vs-output". They even talk about "nonlinear transfer functions." I don't know if being around guitar amps causes this, or if it's simple terminology abuse. -- Les Cargill
> I don't know if being around guitar amps causes this, or if it's simple > terminology abuse. > > -- > Les Cargill
Hahahaha...That's funny Les. Put your glasses on and read my question again.
Les Cargill <lcargill99@comcast.com> writes:
> Jerry Avins wrote: >> On 4/3/2012 10:10 AM, Mauritz Jameson wrote: >>> Hey, >>> >>> I just watched a demo of this amp profiler...I guess it's a kind of >>> system identification algorithm running under the hood? Any guesses as >>> to what type of algorithm is used to identify the amp transfer >>> function? >> >> My guess about what he does isn't worth writing down. Just know that, >> since the amps being profiled in general are nonlinear, there is no >> transfer function as textbooks define it, >> >> Jerry > > > People do use the term "transfer function" to describe "graphs > of input-vs-output". They even talk about "nonlinear transfer > functions." > > I don't know if being around guitar amps causes this, or if it's simple > terminology abuse.
Yeah, I read transfer function and thought "output vs input." I guess context auto-corrected my interpreter to think of that meaning versus the linear system one. Or maybe it's just abuse, as you say. Al Sharpton, where are you now? :) -- Randy Yates DSP/Firmware Engineer 919-577-9882 (H) 919-720-2916 (C)
> >> I don't know if being around guitar amps causes this, or if it's simple >> terminology abuse. >> >> -- >> Les Cargill > > Hahahaha...That's funny Les. Put your glasses on and read my question > again. > > >
I couldn't make it two minutes through the guy's schpeil. I have No Idea What He's On About. Sorry. It's just a lousy video; the product could be fantastic, but I'd never guess that from the video. For guitar amp modelling: 1) There's convolution. It works well enough. I don't know how he could possibly have done a deconvolution like that. 2) There's waveshaping. it's... okay, in places. Look up FuncShaper. It about covers it. Anything else is probably proprietary. -- Les Cargill
That sort of terminology abuse is unfortunately common. I'm probably guilty of it myself from time to time. I don't really appreciate the quibble about a Dirac delta not being a function, so I speak of delta functions. I'm quite familiar with those graphs of input vs. output from the days when I designed audio and RF tube amplifiers. It was natural to call them transfer characteristics because they were derived from sets of curves called plate characteristics. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Tue, 3 Apr 2012 07:10:53 -0700 (PDT), Mauritz Jameson
<mjames2393@gmail.com> wrote:
>Hey, > >I just watched a demo of this amp profiler...I guess it's a kind of >system identification algorithm running under the hood? Any guesses as >to what type of algorithm is used to identify the amp transfer >function? > >Demo: >http://www.youtube.com/watch?v=NyPgBzqKlUs >Thanks
There have been a number of papers published on using Volterra series to model non-linear amplifiers. They have also been used to add that Tube amp sound to digital amplifiers. You might start there for a better understanding? I have read a number of papers on measurement methods used to create a Volterra model of an unknown amplifier. Here's a good reference. http://www.amazon.com/Volterra-Wiener-Theories-Nonlinear-Systems/dp/1575242834/ref=sr_1_2?ie=UTF8&qid=1334521232&sr=8-2 Mark DeArman
