Multiple timing offsets
Started by commsignal April 11, 2012
Fred Marshall <fmarshallxremove_the_x@acm.org> wrote:
(snip)
> A lot usually depends on the signal design. > For example, a RAKE receiver is based on a signal design that consists > of sinusoidal "chips" that are at hopping frequencies. The order of the > transmitted frequencies is known at the receiver.
> In this design the same signal is passed through different delay > channels. The idea is to add up all the energy. So it's a little > different than your problem. But it's likely instructive.
I just finished a post related to the question of time domain, and all filters working in that domain. This seems to be a filter that is definitely time domain. An RLC filter could be described in the time domain or, though the appropriate differential operators, the frequency domain.
> All of the received energy is passed through a delay line structure .. > like a FIR filter without the summing being done. The delays match the > frequency change intervals in order to line up all the frequency > components at the same time. Then, there's a bandpass filter for each. > Finally an incoherent or post-dectection sum is computed.
-- glen
