I am wondering if any ofyou share my vision of an FPGA (or equivalent) type future. By this I mean programmable hardware. Your PC will be nothing but a massive array of gates on which you download your own custom processor. You use high level languages which compiles direct to silicon and runs 100 times faster than ordinary software. A silicon compiler, full floating point. Suppose we need a modem - just download it. A dual processor - no problem, just download it. Hardy
FPGA's - the future
Started by ●April 11, 2012
Reply by ●April 11, 20122012-04-11
>I am wondering if any ofyou share my vision of an FPGA (or equivalent) >type future. By this I mean programmable hardware. Your PC will be >nothing but a massive array of gates on which you download your own >custom processor. You use high level languages which compiles direct >to silicon and runs 100 times faster than ordinary software. >A silicon compiler, full floating point. Suppose we need a modem - >just download it. A dual processor - no problem, just download it. > > >Hardy >Sounds pretty cool.
On Wed, 11 Apr 2012 14:09:10 -0700 (PDT) HardySpicer <gyansorova@gmail.com> wrote:> I am wondering if any ofyou share my vision of an FPGA (or equivalent) > type future. By this I mean programmable hardware. Your PC will be > nothing but a massive array of gates on which you download your own > custom processor. You use high level languages which compiles direct > to silicon and runs 100 times faster than ordinary software. > A silicon compiler, full floating point. Suppose we need a modem - > just download it. A dual processor - no problem, just download it. > > > HardyI don't think you'll ever manage to get programmable hardware to be as fast as fixed hardware. Right now I've got an Intel processor in my machine running at 3.6 GHz. The fastest FPGAs I can buy max out at a few hundred MHz, and even that's for very little logic between register stages. A typical soft processor's even worse, you're lucky to get 300 MHz. And that's on thousands of dollars of high end FPGA. Notice that FPGAs are in fact going the other direction. Less programmability, farther from the regular "sea of gates", more dedicated resources like DSP blocks, hard processors, PCIe transceivers, etc. At a given process node, programmable hardware has to lack performance relative to dedicated hardware. At that point you're hoping you can make it up in parallel, but parallel complicates most problems far more than it helps them. -- Rob Gaddi, Highland Technology -- www.highlandtechnology.com Email address domain is currently out of order. See above to fix.
On Apr 12, 9:17=A0am, Rob Gaddi <rga...@technologyhighland.invalid> wrote:> On Wed, 11 Apr 2012 14:09:10 -0700 (PDT) > > HardySpicer <gyansor...@gmail.com> wrote: > > I am wondering if any ofyou share my vision of an FPGA (or equivalent) > > type future. By this I mean programmable hardware. Your PC will be > > nothing but a massive array of gates on which you download your own > > custom processor. You use high level languages which compiles direct > > to silicon and runs 100 times faster than ordinary software. > > A silicon compiler, full floating point. Suppose we need a modem - > > just download it. A dual processor - no problem, just download it. > > > Hardy > > I don't think you'll ever manage to get programmable hardware to be as > fast as fixed hardware. =A0Right now I've got an Intel processor in my > machine running at 3.6 GHz. =A0The fastest FPGAs I can buy max out at a > few hundred MHz, and even that's for very little logic between register > stages. =A0A typical soft processor's even worse, you're lucky to get 300 > MHz. =A0And that's on thousands of dollars of high end FPGA. > > Notice that FPGAs are in fact going the other direction. =A0Less > programmability, farther from the regular "sea of gates", more > dedicated resources like DSP blocks, hard processors, PCIe > transceivers, etc. > > At a given process node, programmable hardware has to lack performance > relative to dedicated hardware. =A0At that point you're hoping you can > make it up in parallel, but parallel complicates most problems far more > than it helps them. > > -- > Rob Gaddi, Highland Technology --www.highlandtechnology.com > Email address domain is currently out of order. =A0See above to fix.I agree but as with micro technology, the principle remains the same whilst the technology gets smaller and faster. It may never be as fast but the versatility is a trade off provided it can be done fast enough to be useable. When compiled, a silicon program is always faster than software. Hardy
Hi Hardy, On 11-04-12 23:09, HardySpicer wrote:> I am wondering if any ofyou share my vision of an FPGA (or equivalent) > type future. By this I mean programmable hardware. Your PC will be > nothing but a massive array of gates on which you download your own > custom processor. You use high level languages which compiles direct > to silicon and runs 100 times faster than ordinary software. > A silicon compiler, full floating point. Suppose we need a modem - > just download it. A dual processor - no problem, just download it.Do you mean open source hardware FPGA IP-cores? Something like this? http://opencores.org/> HardyCheerio! Kr. Bonne.
On Wed, 11 Apr 2012 14:17:47 -0700, Rob Gaddi <rgaddi@technologyhighland.invalid> wrote:>On Wed, 11 Apr 2012 14:09:10 -0700 (PDT) >HardySpicer <gyansorova@gmail.com> wrote: > >> I am wondering if any ofyou share my vision of an FPGA (or equivalent) >> type future. By this I mean programmable hardware. Your PC will be >> nothing but a massive array of gates on which you download your own >> custom processor. You use high level languages which compiles direct >> to silicon and runs 100 times faster than ordinary software. >> A silicon compiler, full floating point. Suppose we need a modem - >> just download it. A dual processor - no problem, just download it. >> >> >> Hardy > >I don't think you'll ever manage to get programmable hardware to be as >fast as fixed hardware.Or as cheap or as low-power. With power consumption being an ever-growing concern this alone may drive. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On 4/11/2012 2:09 PM, HardySpicer wrote:> I am wondering if any ofyou share my vision of an FPGA (or equivalent) > type future. By this I mean programmable hardware. Your PC will be > nothing but a massive array of gates on which you download your own > custom processor. You use high level languages which compiles direct > to silicon and runs 100 times faster than ordinary software. > A silicon compiler, full floating point. Suppose we need a modem - > just download it. A dual processor - no problem, just download it.Interconnect (within the silicon) eats your lunch if you want to treat the array as "generic silicon". A processor achieves lots of efficiency (and redundancy!) by exploiting geometries of particular features -- register files, ALUs, etc. -- that free the layout from trying to accommodate "anyTHING, anyWHERE". And, as geometries get smaller and smaller, there is a HUGE role for "extra stuff" on the die to cover a certain "defect expectation".
On Wed, 11 Apr 2012 14:09:10 -0700, HardySpicer wrote:> I am wondering if any ofyou share my vision of an FPGA (or equivalent) > type future. By this I mean programmable hardware. Your PC will be > nothing but a massive array of gates on which you download your own > custom processor. You use high level languages which compiles direct to > silicon and runs 100 times faster than ordinary software. A silicon > compiler, full floating point. Suppose we need a modem - just download > it. A dual processor - no problem, just download it.I don't think it'll happen in my lifetime. I think that FPGAs will be a valuable way to address niche products for a long time to come -- but if they were all that good for general purpose logic (much less computing), PC motherboards would use FPGAs instead of hard-wired chipsets. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
Reply by ●April 12, 20122012-04-12
HardySpicer <gyansorova@gmail.com> wrote:> I am wondering if any ofyou share my vision of an FPGA (or equivalent) > type future. By this I mean programmable hardware. Your PC will be > nothing but a massive array of gates on which you download your own > custom processor.Is sounds nice, but doesn't seem likely. Maybe 40 years ago, we had microprogammed processors with writable control store, to allow adding new instructions. A nice feature, but rarely used.> You use high level languages which compiles direct > to silicon and runs 100 times faster than ordinary software.I might believe a small FPGA such that one could load logic optimal to the problem at hand. Presumably it would have to be part of the context, saved and restored, though maybe with enough to avoid too much swapping. (That is, more than one program could be running, each with its own custom logic block.)> A silicon compiler, full floating point. Suppose we need a modem - > just download it. A dual processor - no problem, just download it.Floating point is especially inefficient in most FPGAs. I do believe that FPGAs are nice for legacy processors. You could build a nice box that could emulate popular machines from the 1970's, 1980's, and even 1990's. I have thought about a board with a medium to large FPGA, with an ISA, PCI, Sbus, Apple II bus, S-100, NuBus, and maybe more, slot. (One of each.) Also, parallel, two serial, VGA, PS/2 keyboard and mouse, IDE, and floppy port. That would allow one machine to emulate a large number of older systems. (The whole system, not just processor.) -- glen
On Apr 13, 1:28�am, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> HardySpicer <gyansor...@gmail.com> wrote: > > I am wondering if any ofyou share my vision of an FPGA (or equivalent) > > type future. By this I mean programmable hardware. Your PC will be > > nothing but a massive array of gates on which you download your own > > custom processor. > > Is sounds nice, but doesn't seem likely. > > Maybe 40 years ago, we had microprogammed processors with writable > control store, to allow adding new instructions. A nice feature, > but rarely used. > > > You use high level languages which compiles direct > > to silicon and runs 100 times faster than ordinary software. > > I might believe a small FPGA such that one could load logic optimal > to the problem at hand. Presumably it would have to be part of > the context, saved and restored, though maybe with enough to > avoid too much swapping. (That is, more than one program could be > running, each with its own custom logic block.) > > > A silicon compiler, full floating point. Suppose we need a modem - > > just download it. A dual processor - no problem, just download it. > > Floating point is especially inefficient in most FPGAs. > > I do believe that FPGAs are nice for legacy processors. You could > build a nice box that could emulate popular machines from the 1970's, > 1980's, and even 1990's. I have thought about a board with a medium > to large FPGA, with an ISA, PCI, Sbus, Apple II bus, S-100, NuBus, > and maybe more, slot. (One of each.) Also, parallel, two serial, > VGA, PS/2 keyboard and mouse, IDE, and floppy port. > > That would allow one machine to emulate a large number of older > systems. (The whole system, not just processor.) > > -- glenThat's a great idea which to me tells me we are around 20 years behind where we could be. We need faster FPGA programming and devices etc. surely new technologies will emerge in time. Hardy
