On Apr 12, 4:29�pm, HardySpicer <gyansor...@gmail.com> wrote:> On Apr 13, 1:28�am, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote: > > > > > HardySpicer <gyansor...@gmail.com> wrote: > > > I am wondering if any ofyou share my vision of an FPGA (or equivalent) > > > type future. By this I mean programmable hardware. Your PC will be > > > nothing but a massive array of gates on which you download your own > > > custom processor. > > > Is sounds nice, but doesn't seem likely. > > > Maybe 40 years ago, we had microprogammed processors with writable > > control store, to allow adding new instructions. A nice feature, > > but rarely used. > > > > You use high level languages which compiles direct > > > to silicon and runs 100 times faster than ordinary software. > > > I might believe a small FPGA such that one could load logic optimal > > to the problem at hand. Presumably it would have to be part of > > the context, saved and restored, though maybe with enough to > > avoid too much swapping. (That is, more than one program could be > > running, each with its own custom logic block.) > > > > A silicon compiler, full floating point. Suppose we need a modem - > > > just download it. A dual processor - no problem, just download it. > > > Floating point is especially inefficient in most FPGAs. > > > I do believe that FPGAs are nice for legacy processors. You could > > build a nice box that could emulate popular machines from the 1970's, > > 1980's, and even 1990's. I have thought about a board with a medium > > to large FPGA, with an ISA, PCI, Sbus, Apple II bus, S-100, NuBus, > > and maybe more, slot. (One of each.) Also, parallel, two serial, > > VGA, PS/2 keyboard and mouse, IDE, and floppy port. > > > That would allow one machine to emulate a large number of older > > systems. (The whole system, not just processor.) > > > -- glen > > That's a great idea which to me tells me we are around 20 years behind > where we could be. > We need faster FPGA programming and devices etc. surely new > technologies will emerge in time. > > Hardy- Hide quoted text - > > - Show quoted text -And surely new technologies will emerge which will allow solar power to replace gasoline....or not.
FPGA's - the future
Started by ●April 11, 2012
Reply by ●April 12, 20122012-04-12
HardySpicer <gyansorova@gmail.com> wrote: (snip, someone wrote)>> > I am wondering if any ofyou share my vision of an FPGA (or equivalent) >> > type future. By this I mean programmable hardware. Your PC will be >> > nothing but a massive array of gates on which you download your own >> > custom processor.(snip, then I wrote)>> I do believe that FPGAs are nice for legacy processors. You could >> build a nice box that could emulate popular machines from the 1970's, >> 1980's, and even 1990's. I have thought about a board with a medium >> to large FPGA, with an ISA, PCI, Sbus, Apple II bus, S-100, NuBus, >> and maybe more, slot. (One of each.) Also, parallel, two serial, >> VGA, PS/2 keyboard and mouse, IDE, and floppy port.>> That would allow one machine to emulate a large number of older >> systems. (The whole system, not just processor.)> That's a great idea which to me tells me we are around 20 years > behind where we could be. > We need faster FPGA programming and devices etc. surely new > technologies will emerge in time.But as I say, it could have been done 40 years ago with writable control store. A system could have allowed a task to load custom, task specific, microcode that would speed up that task. It never caught on. High-end FPGAs are now getting to the point where tunneling through the gate is significant. That is, the quiescent current is getting high enough to matter. FPGA processors can be much faster than traditional ones when you need to do a very large number of simple operations in parallel. Traditional vector processors are pretty good at doing more complicated parallel processing. (Such as including multiply and divide.) FPGAs don't help so much with those. -- glen
Reply by ●April 13, 20122012-04-13
An FPGA is essentially a large distributed processing unit that can be customized around a problem. You get to use the LUTS, registers, multipliers, and any other building block to build up a customized parallel computing engine. The architecture of say a i7 processor is so different that it's hard to compare the two technologies, at least in my mind. If you have a very specific problem to solve, an FPGA makes sense. If you want a generic computing platform, an FPGA doesn't make a whole lot of sense. However, an FPGA is generic in the sense that the built in logic elements can be connected to fit the task at hand. The "Field Programmable" part of FPGAs, in my mind, is appealing because it's much easier and cheaper to spin an FPGA design than an ASIC. Enough rambling, I guess my point is that the traditional PC CPU is as general/programmable as it gets. FPGAs are targetted to solve a different problem and I do not forsee FPGAs infiltrating the PC market.
Reply by ●April 14, 20122012-04-14
On 4/13/12 9:53 PM, Impoliticus wrote:> An FPGA is essentially a large distributed processing unit that can be > customized around a problem. You get to use the LUTS, registers, > multipliers, and any other building block to build up a customized parallel > computing engine. The architecture of say a i7 processor is so different > that it's hard to compare the two technologies, at least in my mind. If > you have a very specific problem to solve, an FPGA makes sense. If you > want a generic computing platform, an FPGA doesn't make a whole lot of > sense. However, an FPGA is generic in the sense that the built in logic > elements can be connected to fit the task at hand. The "Field > Programmable" part of FPGAs, in my mind, is appealing because it's much > easier and cheaper to spin an FPGA design than an ASIC. > > Enough rambling, I guess my point is that the traditional PC CPU is as > general/programmable as it gets. FPGAs are targetted to solve a different > problem and I do not forsee FPGAs infiltrating the PC market.not being any sort of expert with FPGA, i will say that there was a company i had worked for in the past (name not divulged) that had audio processing products that had a sorta general purpose CPU that did not process audio samples itself (but it did a little more work than just manage the front panel buttons and display) and it was connected to an FPGA that was loaded with its program at power up and never changed while the unit was on. i understood this to be the normal way FPGAs are used. there was one engineer (and he was one of the FPGA engineers) that had been advocating reloading the FPGA with different code (configuring it differently) whenever there was a program change (and they didn't take this guy's advice). this is sorta how we do it with boxes that have a CPU and a few DSPs in it. the DSPs are reloaded with new code each time there is a program change. but i never seen anyone do that with an FPGA, but there seems to be no reason conceptually that it cannot be done. but i'm no FPGA expert, so i dunno what all is involved. i could imagine that a simpler way to do this would be to have a finite set of algorithms to load into the FPGA and, whatever the program with whatever presets it is, it would be one of those countable algorithms or FPGA configurations. it's not a totally general way to do it, but a lot of boxes are like that. they do, like, 1 of 12 things and nothing else. every preset would have, as one parameter, a spec that selects one of the 12 available configurations and the other parameters in the preset are just the values of specific knobs that whatever selected alg or configuration uses. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson <rbj@audioimagination.com> wrote:> On 4/13/12 9:53 PM, Impoliticus wrote: >> An FPGA is essentially a large distributed processing unit that can >> be customized around a problem. You get to use the LUTS, registers, >> multipliers, and any other building block to build up a customized >> parallel computing engine.(snip)>> Enough rambling, I guess my point is that the traditional PC CPU >> is as general/programmable as it gets. FPGAs are targetted to >> solve a different problem and I do not forsee FPGAs >> infiltrating the PC market.> not being any sort of expert with FPGA, i will say that there was a > company i had worked for in the past (name not divulged) that had audio > processing products that had a sorta general purpose CPU that did not > process audio samples itself (but it did a little more work than just > manage the front panel buttons and display) and it was connected to an > FPGA that was loaded with its program at power up and never changed > while the unit was on. i understood this to be the normal way FPGAs are > used.Many FPGAs now are used for what previously would have been done with ASICs. They are fast enough, and without the big NRE cost of ASICs, more affordable.> there was one engineer (and he was one of the FPGA engineers) that had > been advocating reloading the FPGA with different code (configuring it > differently) whenever there was a program change (and they didn't take > this guy's advice). this is sorta how we do it with boxes that have a > CPU and a few DSPs in it. the DSPs are reloaded with new code each time > there is a program change. but i never seen anyone do that with an > FPGA, but there seems to be no reason conceptually that it cannot be > done. but i'm no FPGA expert, so i dunno what all is involved.It is done, but not quite as often as with a fixed configuration. Now, in the not so distant past the ROM code for embedded processors would be expected to be constant, but now people expect updated firmware to be released fairly often. Internet connected blu-ray players will check for new firmware and ask if you want to install it.> i could imagine that a simpler way to do this would be to have a finite > set of algorithms to load into the FPGA and, whatever the program with > whatever presets it is, it would be one of those countable algorithms or > FPGA configurations.Yes, I believe that is the more usual case when there isn't a single configuration. There are people interested in partial reconfiguration, though. In that case, some parts stay constant while other parts of the same FPGA are reloaded with new configuration. I have been interested in designs where most of the logic is fixed, but a small part would be custom configured. For example, look-up tables (ROMs) would be configured with specific values, but the rest of the logic would stay the same. Some years ago, I heard a talk from someone who had Linux running on a PowerPC processor built into an FPGA (that is, as a logic block, not built from programmable logic) which then reconfigured other parts of the same FPGA while it was running.> it's not a totally general way to do it, but a lot > of boxes are like that. they do, like, 1 of 12 things and nothing else. > every preset would have, as one parameter, a spec that selects one of > the 12 available configurations and the other parameters in the preset > are just the values of specific knobs that whatever selected alg or > configuration uses.Yes, to me that makes more sense than some other things that people like to talk about. Some things that make for interesting research projects, but aren't so practical in real problems. I do like the idea of a programmable accelerator attached to a more usual CPU, though. One could, for example, load logic to speed up an FFT when one was doing that, and some other logic for other problems. There are problems where much work can go into profitably optimizing the logic for a specific problem. But not so many such problems. -- glen
On Sat, 14 Apr 2012 00:45:33 -0400, robert bristow-johnson wrote:> On 4/13/12 9:53 PM, Impoliticus wrote: >> An FPGA is essentially a large distributed processing unit that can be >> customized around a problem. You get to use the LUTS, registers, >> multipliers, and any other building block to build up a customized >> parallel computing engine. The architecture of say a i7 processor is >> so different that it's hard to compare the two technologies, at least >> in my mind. If you have a very specific problem to solve, an FPGA >> makes sense. If you want a generic computing platform, an FPGA doesn't >> make a whole lot of sense. However, an FPGA is generic in the sense >> that the built in logic elements can be connected to fit the task at >> hand. The "Field Programmable" part of FPGAs, in my mind, is appealing >> because it's much easier and cheaper to spin an FPGA design than an >> ASIC. >> >> Enough rambling, I guess my point is that the traditional PC CPU is as >> general/programmable as it gets. FPGAs are targetted to solve a >> different problem and I do not forsee FPGAs infiltrating the PC market. > > not being any sort of expert with FPGA, i will say that there was a > company i had worked for in the past (name not divulged) that had audio > processing products that had a sorta general purpose CPU that did not > process audio samples itself (but it did a little more work than just > manage the front panel buttons and display) and it was connected to an > FPGA that was loaded with its program at power up and never changed > while the unit was on. i understood this to be the normal way FPGAs are > used. > > there was one engineer (and he was one of the FPGA engineers) that had > been advocating reloading the FPGA with different code (configuring it > differently) whenever there was a program change (and they didn't take > this guy's advice). this is sorta how we do it with boxes that have a > CPU and a few DSPs in it. the DSPs are reloaded with new code each time > there is a program change. but i never seen anyone do that with an > FPGA, but there seems to be no reason conceptually that it cannot be > done. but i'm no FPGA expert, so i dunno what all is involved. > > i could imagine that a simpler way to do this would be to have a finite > set of algorithms to load into the FPGA and, whatever the program with > whatever presets it is, it would be one of those countable algorithms or > FPGA configurations. it's not a totally general way to do it, but a lot > of boxes are like that. they do, like, 1 of 12 things and nothing else. > every preset would have, as one parameter, a spec that selects one of > the 12 available configurations and the other parameters in the preset > are just the values of specific knobs that whatever selected alg or > configuration uses.My favourite way of doing just that involves PCIe hot plug. The FPGA implements a PCI express interface and looks like just other PCIe peripheral to a host processor and operating system. The processor (via a sidechannel - JTAG over USB in my case although it is also possible to do it via PCIe) reconfigures the FPGA to have a different function. The reprogramming causes the FPGA to "unplug" from the PCIe and this in turn causes the OS to unload the FPGA drivers. After the FPGA reconfiguration is complete (this will take a few seconds for a large part), it reappears on the PCIe and the hot plug event causes the OS to load drivers for the FPGA. The drivers will be different because the PCI configuration registers that are read by the OS reflect the different functionality of the FPGA. N.B. this only works if your PCIe infrastructure supports hot plug properly. Not all PCIe switches will have the full set of control signals. Regards, Allan
robert bristow-johnson wrote:> On 4/13/12 9:53 PM, Impoliticus wrote: >> An FPGA is essentially a large distributed processing unit that can be >> customized around a problem. You get to use the LUTS, registers, >> multipliers, and any other building block to build up a customized >> parallel >> computing engine. The architecture of say a i7 processor is so different >> that it's hard to compare the two technologies, at least in my mind. If >> you have a very specific problem to solve, an FPGA makes sense. If you >> want a generic computing platform, an FPGA doesn't make a whole lot of >> sense. However, an FPGA is generic in the sense that the built in logic >> elements can be connected to fit the task at hand. The "Field >> Programmable" part of FPGAs, in my mind, is appealing because it's much >> easier and cheaper to spin an FPGA design than an ASIC. >> >> Enough rambling, I guess my point is that the traditional PC CPU is as >> general/programmable as it gets. FPGAs are targetted to solve a different >> problem and I do not forsee FPGAs infiltrating the PC market. > > not being any sort of expert with FPGA, i will say that there was a > company i had worked for in the past (name not divulged) that had audio > processing products that had a sorta general purpose CPU that did not > process audio samples itself (but it did a little more work than just > manage the front panel buttons and display) and it was connected to an > FPGA that was loaded with its program at power up and never changed > while the unit was on. i understood this to be the normal way FPGAs are > used. > > there was one engineer (and he was one of the FPGA engineers) that had > been advocating reloading the FPGA with different code (configuring it > differently) whenever there was a program change (and they didn't take > this guy's advice). this is sorta how we do it with boxes that have a > CPU and a few DSPs in it. the DSPs are reloaded with new code each time > there is a program change. but i never seen anyone do that with an FPGA, > but there seems to be no reason conceptually that it cannot be done. but > i'm no FPGA expert, so i dunno what all is involved. >It can be done and is done. Depending on the size of the bitmask going into the FPGA and the speed of the interface over which the FPGA is reprogrammed, it can be rather slow...> i could imagine that a simpler way to do this would be to have a finite > set of algorithms to load into the FPGA and, whatever the program with > whatever presets it is, it would be one of those countable algorithms or > FPGA configurations. it's not a totally general way to do it, but a lot > of boxes are like that. they do, like, 1 of 12 things and nothing else. > every preset would have, as one parameter, a spec that selects one of > the 12 available configurations and the other parameters in the preset > are just the values of specific knobs that whatever selected alg or > configuration uses. >For basic variable parameters, it's better* to use registers between the General Purpose Processor and FPGA, and have the GPP vary them. * in terms of reducing "Please wait" time... -- Les Cargill
On 4/13/2012 6:53 PM, Impoliticus wrote:> An FPGA is essentially a large distributed processing unit that can be > customized around a problem. You get to use the LUTS, registers, > multipliers, and any other building block to build up a customized parallel > computing engine. The architecture of say a i7 processor is so different > that it's hard to compare the two technologies, at least in my mind.FPGA's -- and all similar/predecessor "logic devices" -- try to be general purpose solutions to general LOGIC problems -- from PAL's/PLA's (I can never remember which term appeared first :< ) with simple and-or arrays through CPLD's, ASIC's, FPGA's, etc.> If > you have a very specific problem to solve, an FPGA makes sense. If youExactly.> want a generic computing platform, an FPGA doesn't make a whole lot of > sense.Exactly.> However, an FPGA is generic in the sense that the built in logic > elements can be connected to fit the task at hand. The "Field > Programmable" part of FPGAs, in my mind, is appealing because it's much > easier and cheaper to spin an FPGA design than an ASIC.FPGA's are great for prototyping -- you don't have to spend lots of money each time you "turn the crank". Nor, wait many weeks for the fab to produce new samples for evaluation. *All* programmable logic devices are a win when it comes to implementing "junk logic" -- random bits of logic that you can't buy COTS for your particular application in the same cost/form factor, etc. You can get comparable gate/transistor counts between CPUs and PLD's -- though production quantities will tend to favor the CPU in terms of cost/availability. And, I think the effective gate *utilization* of CPUs is higher (per unit area) than FPGA's since so much of an FPGA is lost to routing costs, etc.> Enough rambling, I guess my point is that the traditional PC CPU is as > general/programmable as it gets. FPGAs are targetted to solve a different > problem and I do not forsee FPGAs infiltrating the PC market.FPGA's let *you* decide on the degree of resource allocation (Si), parallelism, etc. that you want to throw at a problem. A CPU hard-codes that into an "architecture"/programmer model. With CPUs getting *so* much faster and so much more integrated, it's often easier to buy a COTS CPU/SoC and write some code for it than trying to design some VHDL to do the same thing in a PLD. (Also, the skillsets of the developers vary... you can find someone to write a piece of code a lot easier than someone to write the equivalent VHDL!) And, logic designs tend to be a lot less "portable" than "software". If it made sense (OP's comment), the market would already have embraced it.
Reply by ●April 15, 20122012-04-15
On 4/14/12 11:57 AM, Don Y wrote:> > FPGA's -- and all similar/predecessor "logic devices" -- try to be > general purpose solutions to general LOGIC problems -- from PAL's/PLA's > (I can never remember which term appeared first :< )it was PLA for me, and i don't even remember the part numbers. but the *last* sorta thing i ever learned to do with digital electronics was programming a PLA (or PALs, if you're Barney the purple dinosaur) and hook it up to a microprocessor (usually to deal with DRAM refresh and address decoding to chip-select). when FPGAs came out, i was sorta already past getting my feet wet. never did hardware again since, i dunno, 1989.> >> If >> you have a very specific problem to solve, an FPGA makes sense. If you > > Exactly. > >> want a generic computing platform, an FPGA doesn't make a whole lot of >> sense. > > Exactly. > >> However, an FPGA is generic in the sense that the built in logic >> elements can be connected to fit the task at hand. The "Field >> Programmable" part of FPGAs, in my mind, is appealing because it's much >> easier and cheaper to spin an FPGA design than an ASIC.i think, if you're an FPGA jock, you could reprogram it in a similar way that we reprogram DSPs or GPUs or whatever accelerator we hang offa a "GPP".> > FPGA's are great for prototyping -- you don't have to spend lots of > money each time you "turn the crank". Nor, wait many weeks for > the fab to produce new samples for evaluation....>> Enough rambling, I guess my point is that the traditional PC CPU is as >> general/programmable as it gets. FPGAs are targetted to solve a different >> problem and I do not forsee FPGAs infiltrating the PC market.how about the DSP market? does it make sense to hang an FPGA offa a CPU to be your hard-core fire-breathing sample processing machine. especially for high sample rate (like for video or, maybe astronomical signal processing... Clay or glen, what kind of sample rates do these telescope guys have for processing whatever comes offa their radio or infrared or optical telescopes?)> > FPGA's let *you* decide on the degree of resource allocation (Si), > parallelism, etc. that you want to throw at a problem. A CPU > hard-codes that into an "architecture"/programmer model.hard-codes? CPU? i thought that's where things got soft and flabby. (remember, at least in the olden daze, computers were sorta like sex, except what you do is take the software and stick it into the hardware. now it's different, you get both your sex and your software offa the internet. but the difference is usually after downloading software, you're still typing with both hands.)> With CPUs getting *so* much faster and so much more integrated, > it's often easier to buy a COTS CPU/SoC and write some code > for it than trying to design some VHDL to do the same thing > in a PLD. (Also, the skillsets of the developers vary... you > can find someone to write a piece of code a lot easier than > someone to write the equivalent VHDL!)i'm sure that's true.> And, logic designs tend to be a lot less "portable" than "software".well, i dunno. with VHDL or Verilog or whatever it is, can't you reasonably port a block of logic function from one thing to another (assuming both things had sufficient capability)?> If it made sense (OP's comment), the market would already have > embraced it.well, this is what i was wondering about (as an FPGA ignoramous). -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
robert bristow-johnson <rbj@audioimagination.com> writes:> there was one engineer (and he was one of the FPGA engineers) that had > been advocating reloading the FPGA with different code (configuring it > differently) whenever there was a program change (and they didn't takeThis is a little cumbersome, as you will typically reset all your registers etc. to the reset state when re-loading the FPGA. The FPGA vendors are now making this task easier with partial reconfiguration over PCIe etc: http://www.altera.com/devices/fpga/stratix-fpgas/stratix-v/overview/partial-reconfiguration/stxv-part-reconfig.html Then there is Tabula where the FPGA configuration is changed several thousand times per second: http://www.tabula.com/technology/technology.php //Petter -- .sig removed by request.
