Big endian settings for XDS560 POD
Started by mani November 25, 2003
Hi,
  I have installed the Code Composer studio Ver 2.2 for TMS470Rxx and
when I try to connect the target in big endian I am unable to download
the code in big endian mode. I am using the XDS560 POD emulator model.
The following steps are being followed to set up the CCS.
1)       File-->select import option--> ARM7XDS560 with the big endian
selected in the list box below
2)       When u start running the CCS(Code composer studio) ,when I
try to download the .out file it gives error message it gives a
message that the endianness with the target does not match.Has anyone
faced this problem and if so can u give  me a solution?
Regards
Bala
What is the target that you are trying to download the code on. If it's
OMAP,
ARM processor is little endian and you cannot change the endianness.
You have to use the little-endian mode.
Hemant
"mani" <indian_spindoctor@yahoo.com> wrote in message
news:1c84265c.0311250904.554dadc6@posting.google.com...
> Hi, > > I have installed the Code Composer studio Ver 2.2 for TMS470Rxx and > when I try to connect the target in big endian I am unable to download > the code in big endian mode. I am using the XDS560 POD emulator model. > The following steps are being followed to set up the CCS. > > 1) File-->select import option--> ARM7XDS560 with the big endian > selected in the list box below > 2) When u start running the CCS(Code composer studio) ,when I > try to download the .out file it gives error message it gives a > message that the endianness with the target does not match.Has anyone > faced this problem and if so can u give me a solution? > > > > Regards > Bala
