Hi every one I am doing work on narrow band phase shift beamforming (frequency domain) and after doing various simulations, i decided to varify beamformer practically. I was able to get data from an acoustic linear array of 24 elements spaced 0.17m apart. The omni directional source was placed at various bearings w.r.t linear array and was transmitting 4.4KHz CW pulses of 200ms duration . The linear array sensors were simulataneously sampled at 48 Ksamp/s/channel. Both linear array and source were deployed at 5-6m depth whereas total average bottom depth at trial locatin was 12m. The distance b/w array and source was approx. 700m. The problem i face is that beamformer shows peaks of nearly equal strength at two or more well separated bearings (at approximately same range) instead of one(where actual source was located). I dont know whether problem is with my beamformer or with array data or with environmental conditions (multipaths or reflections from surface/bottom due to lesser depths) If some one has done work on narrow band phase shift beam forming and is kind enough to help me, he may contact me on email(abrahamnick73@yahoo.com) to get array data (as i don't know how to attach it here in this post), process the data and send me results in form of time vs bearing plot so that i can compare it with mine and reach some conclusion. Thanks Best Regards
phase shift beamformer
Started by ●April 26, 2012
