In article <Czdvr.33818$_l.8495@newsfe15.iad>, Jerry Avins <jya@ieee.org> wrote:>On 5/23/2012 9:40 AM, Andre wrote: >> On 19.05.2012 02:46, HardySpicer wrote: >>> My A/D samples at 33.33kHz and after processing I am using the sound >>> card to output the audio result. The sound card only accepts 44.1khz, >>> 22.05kHz etc. I am thinking of going 33.1 to 20.05. this doesn't have >>> to be spot on, just approx since it is only for listening to. What is >>> the best way - say >>> >>> 333/220 and use euclids algorithm? >>> >> 333 / 222 is probably much easier... > >Is slide-rule accuracy good enough?In this case we are talking about a Pythagorean comma off in absolute pitch. Unless you have absolute hearing this may be good enough. You're a Forth eh? Always changing the problem to make it easier.> >JerryGroetjes Albert -- -- Albert van der Horst, UTRECHT,THE NETHERLANDS Economic growth -- being exponential -- ultimately falters. albert@spe&ar&c.xs4all.nl &=n http://home.hccnet.nl/a.w.m.van.der.horst
Sample Rate conversion
Started by ●May 18, 2012
Reply by ●May 31, 20122012-05-31
