Hello Forum, I have just started studying wavelets and wavelet transform. While the STFT breaks the signal down into equal time duration segments, the wavelet transform uses wavelets that when they have high frequency (compressed) give great time resolution, i.e. short time window. But a wavelet with a low frequency implies a stretched up wavelet and a long time window... It seems that wavelets can do great frequency and time resolution at high frequencies and modest time resolution at lower frequencies... Is that correct? Wavelets are orthogonal to each other. could you remind me the benefit of decomposing a signal in orthogonal basis functions aside from the fact that each basis function gives a zero inner product with another basis function of different frequency? the purpose of all transforms is to find the complex coefficients to give the basis functions for the best reconstruction of the signal... In Fourier theory the basis functions have complex coefficients containing amplitude and phase....do wavelets have phase information? Or just the translation coefficient? thanks, Brett
Wavelets...
Started by ●June 27, 2012
Reply by ●June 27, 20122012-06-27
Am 27.06.2012 18:16, schrieb brettcooper:> It seems that wavelets can do great frequency and time resolution at high > frequencies and modest time resolution at lower frequencies... > Is that correct?The "uncertainty" relation still holds true for wavelets, so you may ask about the support of the wavelet functions in time or frequency domain. Compared to a Fourier basis - where the basis functions have all the same support in the frequency domain, wavelets have a relatively small domain for lower frequencies (thus better resolution) and a larger domain (lower resolution) for higher frequencies. This implies that time resolution is just the inverse of that.> Wavelets are orthogonal to each other.No, not necessarily. Wavelets can be both orthogonal and non-orthogonal. Actually, the latter are the more interesting since non-orthgonal wavelets may have more interesting symmetries than orthogonal ones.> could you remind me the benefit of > decomposing a signal in orthogonal basis functions aside from the fact that > each basis function gives a zero inner product with another basis function > of different frequency?That is an interesting property because it implies that you can implement a wavelet analysis by means of an inner product with the synthesis functions. For non-orthogonal filters, the relation between analysis and synthesis filters is not so simple.> In Fourier theory the basis functions have complex coefficients containing > amplitude and phase....do wavelets have phase information? Or just the > translation coefficient?I don't quite understand how one could define "phase" without having a planar wave and thus a Fourier decomposition, thus I don't quite see how this concept carries over directly. Still, if you have complex signals, you could define the "phase" in the same way, namely by representing the wavelet coefficients (from the wavelet analysis) as r * exp(i\phi), where \phi would be the phase. But it is not exactly the same type of "phase shift = transition in time domain" as you know it for Fourier. Greetings, Thomas
Reply by ●June 28, 20122012-06-28
Thanks Thomas. I just read this online: "....Short Term Fourier Transform (STFT) - provides both time and frequency information, but resolves all frequencies equally...." I get that. "...Wavelet transform - provides good time resolution and poor frequency resolution at high frequencies and good frequency resolution and poor time resolution at low frequencies. Useful approach when signal at hand has high frequency components for short duration and low frequency components for long duration as in ECG....." So a compressed, high frequency wavelets automatically have a shorter duration, hence a good time resolution... but why do they have poor frequency resolution? Vice versa for the low frequency wavelets... Poor frequency resolution means that we need wavelets of more frequencies to suitably describe a certain event in the signal. Is it because short duration events are usually more complicated in shape than long duration events (smooth changes)? for example, a chirp signal with increasing frequency: I feel that the wavelet transform should work equally well at low and high frequencies... Also, in communication theory, a carrier is FM modulated and demodulated to get the instantaneous frequency (Which is related to the transmitted message). Do they use wavelets to extract the instantaneous frequency out of the modulated signal? If not, how do they do it? Brett
On Thursday, June 28, 2012 9:14:01 AM UTC-5, brettcooper wrote:> Thanks Thomas. > > I just read this online: "....Short Term Fourier Transform (STFT) - > provides both time and frequency information, but resolves all frequencies > equally...." > > I get that. > > "...Wavelet transform - provides good time resolution and poor frequency > resolution at high frequencies and good frequency resolution and poor time > resolution at low frequencies. Useful approach when signal at hand has high > frequency components for short duration and low frequency components for > long duration as in ECG....." > > So a compressed, high frequency wavelets automatically have a shorter > duration, hence a good time resolution... but why do they have poor > frequency resolution? Vice versa for the low frequency wavelets... > > Poor frequency resolution means that we need wavelets of more frequencies > to suitably describe a certain event in the signal. Is it because short > duration events are usually more complicated in shape than long duration > events (smooth changes)? > > for example, a chirp signal with increasing frequency: I feel that the > wavelet transform should work equally well at low and high frequencies... > > Also, in communication theory, a carrier is FM modulated and demodulated to > get the instantaneous frequency (Which is related to the transmitted > message). Do they use wavelets to extract the instantaneous frequency out > of the modulated signal? If not, how do they do it? > > BrettGo to Google.com type in TIME FREQUENCY UNCERTAINITY PRINCIPAL
Am 28.06.2012 16:14, schrieb brettcooper:> Thanks Thomas.> "...Wavelet transform - provides good time resolution and poor frequency > resolution at high frequencies and good frequency resolution and poor time > resolution at low frequencies. Useful approach when signal at hand has high > frequency components for short duration and low frequency components for > long duration as in ECG....." > > So a compressed, high frequency wavelets automatically have a shorter > duration, hence a good time resolution... but why do they have poor > frequency resolution? Vice versa for the low frequency wavelets...Because you have a fundamental inequality between time resolution and frequency resolution that forbids you to have both at the same time. Actually, it is the same inequality in physics where the "frequency space" is also the "momentum space" of quantum particles, and the "time space" is the "position space" of the particle, where the Fourier transform transforms between the two representations. It is there (in physics) called the "uncertainty relation" because it implies that you cannot measure both the position *and* the momentum of a quantum particle sharply. The same relation holds in signal processing as well, simply because the mathematical transformation is the same: To define a frequency sharply, you need an infinitely extended "planar wave", i.e. f(x) = exp(i k x), which has a fixed 'k', but is obviously extended all over the space. Vice versa, if you want a sharp position in the time domain, the delta "function" (actually, distribution) does that. Its image in the Fourier domain, after Fourier transformation, is of course the plane wave again, \hat{f}(k) = exp(-i k x) where x is now the parameter where the "peak" is and k the argument of the function (the other way around than above). It is hence infinitely extended in 'k' (frequency, momentum) space, but located in the time domain. Wavelets are compromises between the two extreme, neither localized in time nor in the frequency domain.> Poor frequency resolution means that we need wavelets of more frequencies > to suitably describe a certain event in the signal.How many basis functions you need is entirely up to the signal you want to describe. One cannot say, in general, you need "more" or "less". It is the nature of the signal that tells you. If the signal is a slightly distorted plane wave, a Fourier representation would be more suitable.> Is it because short > duration events are usually more complicated in shape than long duration > events (smooth changes)?Signals of short duration have a more complex spectrum, i.e. have a less sharp frequency distribution. Shorter signals = "more overtones", and "purer signals" require longer samplings, i.e. are not localized in time domain.> for example, a chirp signal with increasing frequency: I feel that the > wavelet transform should work equally well at low and high frequencies...That cannot be answered in general. For such a signal, i.e. a slow variation in the time domain, I would believe that a Fourier description is more adequate. I don't think one can compute the spectrum of such a signal explicitly, but I haven't tried either. An approximation would be feasible.> Also, in communication theory, a carrier is FM modulated and demodulated to > get the instantaneous frequency (Which is related to the transmitted > message). Do they use wavelets to extract the instantaneous frequency out > of the modulated signal? If not, how do they do it?Sorry, I don't think I got this question. Wavelets are not a tool for FM modulation, at least I wouldn't know how to apply them to this problem without thinking more carefully about it. Wavelets are, just to give one example, a good model to describe natural images. JPEG 2000 uses for example a wavelet decomposition to describe the image data. It is here a good model since the frequency resolution of wavelets gets lower for high frequencies and higher at low frequencies, which is very much how the eye-brain visual system behaves. So it is a reasonably good model of how we "see" the world. So long, Thomas
Reply by ●June 29, 20122012-06-29
>Thanks Thomas. > >I just read this online: "....Short Term Fourier Transform (STFT) - >provides both time and frequency information, but resolves allfrequencies>equally...." > >I get that. > >"...Wavelet transform - provides good time resolution and poor frequency >resolution at high frequencies and good frequency resolution and poortime>resolution at low frequencies. Useful approach when signal at hand hashigh>frequency components for short duration and low frequency components for >long duration as in ECG....." > >So a compressed, high frequency wavelets automatically have a shorter >duration, hence a good time resolution... but why do they have poor >frequency resolution? Vice versa for the low frequency wavelets... > >Poor frequency resolution means that we need wavelets of more frequencies >to suitably describe a certain event in the signal. Is it because short >duration events are usually more complicated in shape than long duration >events (smooth changes)? > >for example, a chirp signal with increasing frequency: I feel that the >wavelet transform should work equally well at low and high frequencies... > >Also, in communication theory, a carrier is FM modulated and demodulatedto>get the instantaneous frequency (Which is related to the transmitted >message). Do they use wavelets to extract the instantaneous frequency out >of the modulated signal? If not, how do they do it? > >Brett >http://en.wikipedia.org/wiki/Wavelet_packet_decomposition
Thank you again.... i guess I got confused with the fact that a FM modulated signal, with the concept of instantaneous frequency, can have a specific single frequency at every instant in time (that is its instantaneous freq.) But the Fourier transform of a FM modulated signal clearly shows a wide bandwidth.... The concept of frequency has multiple definitions. for instance, a pure sinusoid with a Gaussian envelope forms a finite time durations signal with a nonzero frequency bandwidth... But the interzero distance in this signal is constant, i.e. the instantaneous frequency is one and constant while the Fourier frequency is not just one but a whole bandwidth... Brett
