[cross-post] nested interrupts
Started by alb July 1, 2012
Dear all,
I would like to understand more about nested interrupts since it looks
to me they break my code and I'm not sure why.
I have three 'items' in my software: a serial port, a fifo and a timer.
The serial port is an external hardware that sends back an interrupt
when it's free to send another byte, so I decided to have an interrupt
service routine (ISR) that reads from the fifo and puts the byte into
the serial port. With this choice the main program should start the
first byte transmission from the fifo and then everything is handled by
the ISR. Therefore the code looks like this:
> int main() { > ... > while(1) { > write_to_fifo(data); > if (state != TRANSMITTING) { > if (read_from_fifo(&byte) == OK) { > write_to_sport(byte); > state = TRANSMITTING; > } > } > } > }
the variable 'state' is needed in order to prevent the main to write into the serial port while the ISR is already doing this. The ISR would look like the following:
> > void isr_sport(int signal) { > > if (read_from_fifo(&byte) == OK) write_to_sport(byte); > else state == DONE; > }
When the fifo will be empty the ISR will change the state to DONE such that main can start a new transmission again. This flow works perfectly as expected but now I decided to add a timer interrupt which is simply incrementing my 'system time' variable, nothing else. If the 'interrupt nesting' is disabled everything works as expected, but if it is enabled something breaks. After some bytes transmitted to the serial port the program simply runs through the main, as if the 'state' variable was not set to DONE when the ISR emptied the fifo. My simple 'naive' model for this is that while the serial port ISR was running it was interrupted by the timer interrupt (higher priority) but once the timer ISR was completed, instead of returning to the serial port ISR it returned directly to the main, missing the instruction to change the state. At this point there's no chance for the ISR to change the 'state' variable and the main will wait forever a never changing state. But is this 'possible'? I started looking at the assembler for the interrupt dispatcher and interrupt handling routines but still didn't manage to find a potential flaw (even though I admit I did not fully understand everything there). Any suggestion or pointer is more than welcome. Thanks a lot, Al p.s.: the target is an ADSP21020 and the compiler is g21k. -- A: Because it fouls the order in which people normally read text. Q: Why is top-posting such a bad thing? A: Top-posting. Q: What is the most annoying thing on usenet and in e-mail?
On 07/01/2012 03:27 PM, alb wrote:
>> >> void isr_sport(int signal) { >> >> if (read_from_fifo(&byte) == OK) write_to_sport(byte); >> else state == DONE; >> } >
Try 'state = DONE' instead.
On 7/1/2012 4:19 PM, Arlet Ottens wrote:
> On 07/01/2012 03:27 PM, alb wrote: >>> >>> void isr_sport(int signal) { >>> >>> if (read_from_fifo(&byte) == OK) write_to_sport(byte); >>> else state == DONE; >>> } >> > > Try 'state = DONE' instead.
Ok, that was a typo when posting, my apologies. But as I mentioned, the logic works for some time until the 'clash' with the timer interrupt.
On 7/1/12 11:21 AM, alb wrote:
> On 7/1/2012 4:19 PM, Arlet Ottens wrote: >> On 07/01/2012 03:27 PM, alb wrote: >>>> >>>> void isr_sport(int signal) { >>>> >>>> if (read_from_fifo(&byte) == OK) write_to_sport(byte); >>>> else state == DONE; >>>> } >>> >> >> Try 'state = DONE' instead. > > Ok, that was a typo when posting, my apologies. But as I mentioned, the > logic works for some time until the 'clash' with the timer interrupt.
i have absolutely no idea what processor this runs on, but to do nested interrupts without too much trouble, you need to have incremental priority levels for the interrupts, where only a higher priority interrupt source may interrupt another process. some processors allow you to assign the priority of your choice to each interrupt source. of course, for each interrupt, you must fully save and restore every register that is used in the interrupt and that the "status register" or "condition code register" or whatever they call it, must be restored exactly. then the last issue is the system stack. if you have lotsa nested interrupts, your stack (where you're saving all these registers) will get deeper and deeper. make sure that neither the stack tramples over some other in-use memory nor that some other process accidentally tramples over the stack. other than that, everything should work transparently with no difference *except* for time. any process that is interrupted will get back to doing its job and will pick up exactly where it left off, *except* it's at a later time than would be if it were not interrupted. sometimes, in a real-time embedded system, that delay in time kills you if the process is reading or writing I/O and the outside world is unhappy about the delay. that's all the advice i can throw at you. it's been 2 decades since i had to worry about nested interrupts. chips have evolved/changed since then, but the principles are the same. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
it is in the p.s. of the OP: ADSP21020 with g21k compiler.
> but to do nested > interrupts without too much trouble, you need to have incremental > priority levels for the interrupts, where only a higher priority > interrupt source may interrupt another process. some processors allow > you to assign the priority of your choice to each interrupt source.
In the case of the processor I'm using the priority is fixed but I have a choice to use a high priority interrupt or low priority for the timer. In this case I'm using the high priority timer interrupt.
> > of course, for each interrupt, you must fully save and restore every > register that is used in the interrupt and that the "status register" or > "condition code register" or whatever they call it, must be restored > exactly.
This part is done by the library and this is where I fear something is not properly working.
> > then the last issue is the system stack. if you have lotsa nested > interrupts, your stack (where you're saving all these registers) will > get deeper and deeper. make sure that neither the stack tramples over > some other in-use memory nor that some other process accidentally > tramples over the stack.
I understand that the 'system stack' may be critical but here there should not be any problem since there's nothing going deeper than two interrupt calls. Maybe I should check what the interrupt call does at the assembler level and make sure that everything is in place.
> > other than that, everything should work transparently with no difference > *except* for time. any process that is interrupted will get back to > doing its job and will pick up exactly where it left off, *except* it's > at a later time than would be if it were not interrupted. sometimes, in > a real-time embedded system, that delay in time kills you if the process > is reading or writing I/O and the outside world is unhappy about the delay. >
No issue on delays, that's why I can even live without nested interrupt and wait for the current interrupt is served before serving the next one. The point is that I would like to understand the reason for such a strange behavior since I fear that it will byte me back later if I don't pin it down at this stage.
> that's all the advice i can throw at you. it's been 2 decades since i > had to worry about nested interrupts. chips have evolved/changed since > then, but the principles are the same. >
The processor and the toolchain I'm working with is exactly 2 decades old...
Le 01/07/2012 15:27, alb a �crit :
> Dear all, > > I would like to understand more about nested interrupts since it looks > to me they break my code and I'm not sure why. > > I have three 'items' in my software: a serial port, a fifo and a timer. > The serial port is an external hardware that sends back an interrupt > when it's free to send another byte, so I decided to have an interrupt > service routine (ISR) that reads from the fifo and puts the byte into > the serial port. With this choice the main program should start the > first byte transmission from the fifo and then everything is handled by > the ISR. Therefore the code looks like this: > >> int main() { >> ... >> while(1) { >> write_to_fifo(data); >> if (state != TRANSMITTING) { >> if (read_from_fifo(&byte) == OK) { >> write_to_sport(byte); >> state = TRANSMITTING; >> } >> } >> } >> } > > the variable 'state' is needed in order to prevent the main to write > into the serial port while the ISR is already doing this. > The ISR would look like the following: >> >> void isr_sport(int signal) { >> >> if (read_from_fifo(&byte) == OK) write_to_sport(byte); >> else state == DONE; >> } > > When the fifo will be empty the ISR will change the state to DONE such > that main can start a new transmission again. > > This flow works perfectly as expected but now I decided to add a timer > interrupt which is simply incrementing my 'system time' variable, > nothing else. > If the 'interrupt nesting' is disabled everything works as expected, but > if it is enabled something breaks. After some bytes transmitted to the > serial port the program simply runs through the main, as if the 'state' > variable was not set to DONE when the ISR emptied the fifo. > > My simple 'naive' model for this is that while the serial port ISR was > running it was interrupted by the timer interrupt (higher priority) but > once the timer ISR was completed, instead of returning to the serial > port ISR it returned directly to the main, missing the instruction to > change the state. At this point there's no chance for the ISR to change > the 'state' variable and the main will wait forever a never changing state. > > But is this 'possible'? I started looking at the assembler for the > interrupt dispatcher and interrupt handling routines but still didn't > manage to find a potential flaw (even though I admit I did not fully > understand everything there). > > Any suggestion or pointer is more than welcome. > Thanks a lot, >
I haven't seen any flaw in either your code or your concept. It would be useful to have the assembly code, particularly that of the ISR and the pre and post ISR code to come up with something.
At this point you have a race between main() and isr_sport(): both will assign something to "state". Normally main() will no doubt have time to execute the assignment below, before isr_sport() is called, but if something else interrupts main() at this point, isr_sport() may reach its statement "state = DONE" first, which means that main() then overwrites DONE with TRANSMITTING in "state", and the logic fails.
>> state = TRANSMITTING; >> } >> } >> } >> } > > the variable 'state' is needed in order to prevent the main to write > into the serial port while the ISR is already doing this. > The ISR would look like the following: >> >> void isr_sport(int signal) { >> >> if (read_from_fifo(&byte) == OK) write_to_sport(byte); >> else state = DONE; >> } > > When the fifo will be empty the ISR will change the state to DONE such > that main can start a new transmission again. > > This flow works perfectly as expected but now I decided to add a timer > interrupt which is simply incrementing my 'system time' variable, > nothing else. > If the 'interrupt nesting' is disabled everything works as expected, but > if it is enabled something breaks. After some bytes transmitted to the > serial port the program simply runs through the main, as if the 'state' > variable was not set to DONE when the ISR emptied the fifo.
This symptom can result from the race condition above. I'm not sure how the dependence on interrupt nesting arises. Perhaps, when nesting is disabled, and the serial-port interrupt is signalled while the timer interrupt is being handled, one or a few instructions in main() are executed between the return from the timer interrupt handler and before the serial-port handler is executed. This might give main() enough time to execute its "state" assignment before isr_sport() runs. To remove the race, move the assignment "state = TRANSMITTING" before the write_to_sport(), in main(). By the way, check that you have declared "state" as volatile. -- Niklas Holsti Tidorum Ltd niklas holsti tidorum fi . @ .
On Sunday 01 July 2012 15:27 alb wrote:
> Dear all, > > I would like to understand more about nested interrupts since it looks > to me they break my code and I'm not sure why. > > I have three 'items' in my software: a serial port, a fifo and a timer. > The serial port is an external hardware that sends back an interrupt > when it's free to send another byte, so I decided to have an interrupt > service routine (ISR) that reads from the fifo and puts the byte into > the serial port. With this choice the main program should start the > first byte transmission from the fifo and then everything is handled by > the ISR. Therefore the code looks like this: > >> int main() { >> ... >> while(1) { >> write_to_fifo(data); >> if (state != TRANSMITTING) { >> if (read_from_fifo(&byte) == OK) { >> write_to_sport(byte); >> state = TRANSMITTING; >> } >> } >> } >> } > > the variable 'state' is needed in order to prevent the main to write > into the serial port while the ISR is already doing this. > The ISR would look like the following: >> >> void isr_sport(int signal) { >> >> if (read_from_fifo(&byte) == OK) write_to_sport(byte); >> else state == DONE; >> } > > When the fifo will be empty the ISR will change the state to DONE such > that main can start a new transmission again. > > This flow works perfectly as expected but now I decided to add a timer > interrupt which is simply incrementing my 'system time' variable, > nothing else. > If the 'interrupt nesting' is disabled everything works as expected, but > if it is enabled something breaks. After some bytes transmitted to the > serial port the program simply runs through the main, as if the 'state' > variable was not set to DONE when the ISR emptied the fifo. > > My simple 'naive' model for this is that while the serial port ISR was > running it was interrupted by the timer interrupt (higher priority) but > once the timer ISR was completed, instead of returning to the serial > port ISR it returned directly to the main, missing the instruction to > change the state. At this point there's no chance for the ISR to change > the 'state' variable and the main will wait forever a never changing > state. > > But is this 'possible'? I started looking at the assembler for the > interrupt dispatcher and interrupt handling routines but still didn't > manage to find a potential flaw (even though I admit I did not fully > understand everything there). > > Any suggestion or pointer is more than welcome. > Thanks a lot, > > Al > > p.s.: the target is an ADSP21020 and the compiler is g21k. >
You have not shown, if somewhere interrupts are disabled. I see one possible race condition: if (state != TRANSMITTING) { if (read_from_fifo(&byte) == OK) { write_to_sport(byte); ---- isr_sport() is triggered and sets state=DONE ---- state = TRANSMITTING; Without the timer running this will probably never happen. But the timer ISR might just step in after write_to_port and consume CPU time. The simplest way out of this is to disable interrupts before write_to_sport() and enable them after state = TRANSMITTING; -- Reinhardt Behm rb@rbehm.de
On Sun, 01 Jul 2012 12:36:02 -0400, robert bristow-johnson wrote:
> On 7/1/12 11:21 AM, alb wrote: >> On 7/1/2012 4:19 PM, Arlet Ottens wrote: >>> On 07/01/2012 03:27 PM, alb wrote: >>>>> >>>>> void isr_sport(int signal) { >>>>> >>>>> if (read_from_fifo(&byte) == OK) write_to_sport(byte); else >>>>> state == DONE; >>>>> } >>>> >>>> >>> Try 'state = DONE' instead. >> >> Ok, that was a typo when posting, my apologies. But as I mentioned, the >> logic works for some time until the 'clash' with the timer interrupt. > > i have absolutely no idea what processor this runs on, but to do nested > interrupts without too much trouble, you need to have incremental > priority levels for the interrupts, where only a higher priority > interrupt source may interrupt another process. some processors allow > you to assign the priority of your choice to each interrupt source. > > of course, for each interrupt, you must fully save and restore every > register that is used in the interrupt and that the "status register" or > "condition code register" or whatever they call it, must be restored > exactly.
A light went on: Often the amount of stuff you have to save for an ISR is greater than the amount of stuff you have to save for an ordinary function call. Most modern C compilers let you declare a function to be the target of an interrupt. The syntax isn't standardized -- for some it's "void interrupt foo()", for some it's something like "void foo() attribute ("__interrupt__")", etc. But it boils down to letting the compiler know that it's an interrupt service routine, so that it can do the extra saves & restores. It may be that you were just lucking out without nested interrupts, and were constantly exposing yourself to trouble and the other shoe just never dropped. So -- dig through the processor's documentation on its interrupt response, and look at the compiler's assembly output to see if it seems to be saving away enough stuff on each function call. If not, dig through the compiler's documentation to see how to tell it that an ISR is an ISR. And finally, if you can get by without nested interrupts -- don't use them. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
On 7/1/12 1:04 PM, alb wrote:
> On 7/1/2012 6:36 PM, robert bristow-johnson wrote: >> i have absolutely no idea what processor this runs on, > > it is in the p.s. of the OP: ADSP21020 with g21k compiler. > >> but to do nested >> interrupts without too much trouble, you need to have incremental >> priority levels for the interrupts, where only a higher priority >> interrupt source may interrupt another process. some processors allow >> you to assign the priority of your choice to each interrupt source. > > In the case of the processor I'm using the priority is fixed but I have > a choice to use a high priority interrupt or low priority for the timer.
i remember that. TIMER was the only one that could do that. and i remember being disgusted that there were some devices that we needed at a higher priority and couldn't implement it directly.
> In this case I'm using the high priority timer interrupt. >
okay, what other peripherals do you have hooked up and what are their relative priorities? and, then, about how often are these different interrupts expected to hit? if you have a low-priority interrupt that is expected to hit at, say, 48 kHz, and there is a higher priority interrupt that is connected to a user control (and it has a long and complicated ISR, but one that doesn't need instant attention). you could have a situation where this naturally high-priority device is held hostage to this naturally low-priority device which is fixed in the DSP at a higher level priority.
>> >> of course, for each interrupt, you must fully save and restore every >> register that is used in the interrupt and that the "status register" or >> "condition code register" or whatever they call it, must be restored >> exactly. > > This part is done by the library and this is where I fear something is > not properly working. >
>On 7/1/12 5:49 PM, Tim Wescott wrote: >
> > A light went on: > > Often the amount of stuff you have to save for an ISR is greater than the > amount of stuff you have to save for an ordinary function call. > > Most modern C compilers let you declare a function to be the target of an > interrupt. The syntax isn't standardized -- for some it's "void > interrupt foo()", for some it's something like "void foo() attribute > ("__interrupt__")", etc. But it boils down to letting the compiler know > that it's an interrupt service routine, so that it can do the extra saves > & restores. >
Tim, i'm sure the stub of code that connects to the C functions (that don't need to save/restore certain "scratch" registers and that sometime return values in registers) from the interrupt vector. i imagine that code takes care of what needs to be saved and restored. there is one thing about the 210xx in that it has an alternate register set. we used that in a sorta inverted way. we used the "alternate set" as the regular set (that most of the C code was using) and the "normal set" was used for these ISRs that didn't need to save/restore (they owned the registers they used). the reason why was because it was easier to clear the interrupt enable bit and the bits for those alternate register sets with a single AND at the beginning of the interrupt and then restore as a final OR instruction before the RTI (or whatever it's called). the only restriction was that any C code called by these interrupts (that flipped some of the alternate register sets) could not have register local variables. but none of those ISRs were there to run C code. anyway, if you can make use of the alternate register set for all of your ISRs, and commit some registers, you might not need to do any save/restore.
> > And finally, if you can get by without nested interrupts -- don't use > them. >
>> then the last issue is the system stack. if you have lotsa nested >> interrupts, your stack (where you're saving all these registers) will >> get deeper and deeper. make sure that neither the stack tramples over >> some other in-use memory nor that some other process accidentally >> tramples over the stack. > > I understand that the 'system stack' may be critical but here there > should not be any problem since there's nothing going deeper than two > interrupt calls. Maybe I should check what the interrupt call does at > the assembler level and make sure that everything is in place. > >> >> other than that, everything should work transparently with no difference >> *except* for time. any process that is interrupted will get back to >> doing its job and will pick up exactly where it left off, *except* it's >> at a later time than would be if it were not interrupted. sometimes, in >> a real-time embedded system, that delay in time kills you if the process >> is reading or writing I/O and the outside world is unhappy about the delay. >> > > No issue on delays, that's why I can even live without nested interrupt > and wait for the current interrupt is served before serving the next > one. The point is that I would like to understand the reason for such a > strange behavior since I fear that it will byte me back later if I don't > pin it down at this stage. > >> that's all the advice i can throw at you. it's been 2 decades since i >> had to worry about nested interrupts. chips have evolved/changed since >> then, but the principles are the same. >> > > The processor and the toolchain I'm working with is exactly 2 decades old...
well, that was about as long ago that i had been working on a SHArC. it was ADSP21062 version 0.6 . lotsa bugs in the tools and some ugly (and therefore useless) designs in the instruction set and architecture of the SHArC. the MANT instruction (i think that's what it was called), is useless since it didn't return a float. it makes it more difficult to do math and you can get a float version of a fractional number with a conversion and subtraction. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
