On Sun, 01 Jul 2012 19:01:44 -0400, robert bristow-johnson wrote:> On 7/1/12 1:04 PM, alb wrote: >> On 7/1/2012 6:36 PM, robert bristow-johnson wrote: >>> i have absolutely no idea what processor this runs on,>>On 7/1/12 5:49 PM, Tim Wescott wrote: >> >> > >> A light went on: >> >> Often the amount of stuff you have to save for an ISR is greater than >> the amount of stuff you have to save for an ordinary function call. >> >> Most modern C compilers let you declare a function to be the target of >> an interrupt. The syntax isn't standardized -- for some it's "void >> interrupt foo()", for some it's something like "void foo() attribute >> ("__interrupt__")", etc. But it boils down to letting the compiler >> know that it's an interrupt service routine, so that it can do the >> extra saves & restores. >> >> > Tim, i'm sure the stub of code that connects to the C functions (that > don't need to save/restore certain "scratch" registers and that sometime > return values in registers) from the interrupt vector. i imagine that > code takes care of what needs to be saved and restored.Actually, since other's pointed it out, there's a race condition in main vs. the serial ISR, where he's writing a value out to hardware and then updating status. That's certainly a much better candidate for the problem. Mine was an "if", that one is a "when". -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
[cross-post] nested interrupts
Started by ●July 1, 2012
Reply by ●July 1, 20122012-07-01
On 7/1/12 8:05 PM, Tim Wescott wrote:> > Actually, since other's pointed it out, there's a race condition in main > vs. the serial ISR, where he's writing a value out to hardware and then > updating status. >i couldn't figure out what Niklas meant by "state". if it's a shared variable, then you get "death by shared variable". is that it? how do you do this? you have a hierarchy of interrupt sources, each having a unique interrupt priority. there is an interrupt priority mask (this might be the nasty shared variable) that is set to the level of the interrupt being serviced. only higher interrupt levels can interrupt this ISR. perhaps an interrupt level of zero means it's the "main program" that anything can interrupt. this fits precisely what i mean by "nested". now, that interrupt priority mask is usually set by hardware. now, if that level is not programmable and if you want a device with ostensibly lower priority to act as if it's a higher priority and interrupt an ISR that the stupid SHArC says is higher, then, i suppose you have to manually bump the mask down in the ISR you want to be lowered priority. if you were to always bump the priority mask to, say, zero and deal with this arbitration in software with your own pseudo-mask, then there might be shared variable trouble. what happens in an ISR when the first thing you do after saving/switching necessary registers, you bump the pseudo-mask to the "correct" interrupt level, disable interrupts of lower priority, then bump the *real* mask to zero and do the interrupt? that should work, shouldn't it? now upon completion you undo this in the same order (why not reverse order is puzzling). set the pseudo-mask to zero, then enable interrupts of lower priority in descending order. that's a problem. you might never get to your RTI instruction. the only way i see to securely avoid a race condition is for the interrupt mask to be part of the status register and for that to be restored, along with the instruction pointer (or "program counter") in the Return from Interrupt instruction. and, in servicing the interrupt, for the mask to be set to the priority level of the particular device before the first instruction is executed. this is why i really think that the SHArC was sorta underdesigned, or at least has an oversight, compared to the then venerable Motorola 56K or 68K. assignable priority levels is pretty important, a basic necessity, in my opinion. On 7/1/12 5:49 PM, Tim Wescott wrote:> > And finally, if you can get by without nested interrupts -- don't use > them.i was gonna say that in the world of latched priority level and assignable interrupt priorities and of semiphores, it shouldn't be too hard to make it bullet proof. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Sun, 01 Jul 2012 21:11:53 -0400, robert bristow-johnson wrote:> On 7/1/12 8:05 PM, Tim Wescott wrote: >> >> Actually, since other's pointed it out, there's a race condition in >> main vs. the serial ISR, where he's writing a value out to hardware and >> then updating status. >> >> > i couldn't figure out what Niklas meant by "state". if it's a shared > variable, then you get "death by shared variable". is that it?<snip> It's the variable that Al calls 'state'. In his main loop he loads a byte into the transmitter, _then_ sets 'state' to TRANSMIT. In the ISR, he checks to see if there are any more bytes to transmit, and sets 'state' to DONE. If he pokes the hardware with the last byte in the queue and gets an interrupt before his program gets to "state = TRANSMIT", then the ISR can set state to 'DONE', return, and have the (correct) value overwritten by the (incorrect) value 'TRANSMIT'. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
Reply by ●July 2, 20122012-07-02
Tim Wescott wrote:> On Sun, 01 Jul 2012 21:11:53 -0400, robert bristow-johnson wrote: > >> On 7/1/12 8:05 PM, Tim Wescott wrote: >>> >>> Actually, since other's pointed it out, there's a race conditionin>>> main vs. the serial ISR, where he's writing a value out tohardware and>>> then updating status. >>> >>> >> i couldn't figure out what Niklas meant by "state". if it's ashared>> variable, then you get "death by shared variable". is that it? > > <snip> > > It's the variable that Al calls 'state'. In his main loop he loadsa> byte into the transmitter, _then_ sets 'state' to TRANSMIT. In theISR,> he checks to see if there are any more bytes to transmit, and sets > 'state' to DONE. > > If he pokes the hardware with the last byte in the queue and gets an > interrupt before his program gets to "state = TRANSMIT", then theISR can> set state to 'DONE', return, and have the (correct) valueoverwritten by> the (incorrect) value 'TRANSMIT'.I've had good luck with that technique, except setting and clearing the transmit-interrupt enable instead of a state variable. I don't know whether the ADSP processor permits that. Mel.
On 02/07/12 01:27, alb wrote:> Dear all, > > I would like to understand more about nested interrupts since it looks > to me they break my code and I'm not sure why. > > I have three 'items' in my software: a serial port, a fifo and a timer. > The serial port is an external hardware that sends back an interrupt > when it's free to send another byte, so I decided to have an interrupt > service routine (ISR) that reads from the fifo and puts the byte into > the serial port. With this choice the main program should start the > first byte transmission from the fifo and then everything is handled by > the ISR. Therefore the code looks like this: > >> int main() { >> ... >> while(1) { >> write_to_fifo(data); >> if (state != TRANSMITTING) { >> if (read_from_fifo(&byte) == OK) { >> write_to_sport(byte); >> state = TRANSMITTING; >> } >> } >> } >> } > > the variable 'state' is needed in order to prevent the main to write > into the serial port while the ISR is already doing this. > The ISR would look like the following: >> >> void isr_sport(int signal) { >> >> if (read_from_fifo(&byte) == OK) write_to_sport(byte); >> else state == DONE; >> } >The fifo is shared between main and the ISR. You are not preventing the ISR triggering while inserting more data into the fifo. This would result in a race condition.
On 7/1/2012 8:19 PM, Niklas Holsti wrote: [...]>>> int main() { >>> ... >>> while(1) { >>> write_to_fifo(data); >>> if (state != TRANSMITTING) { >>> if (read_from_fifo(&byte) == OK) { >>> write_to_sport(byte); > > At this point you have a race between main() and isr_sport(): both will > assign something to "state". Normally main() will no doubt have time to > execute the assignment below, before isr_sport() is called, but if > something else interrupts main() at this point, isr_sport() may reach > its statement "state = DONE" first, which means that main() then > overwrites DONE with TRANSMITTING in "state", and the logic fails. >got your point about the race condition, but let me dig a little further here. At the point you mentioned the isr_sport is not running, since there's no transmission going on. The only interrupt that may kick in is the timer ISR. If this is true then the you are still right that there's a race condition, since the isr_sport will be run *after* (lower priority) the isr_timer() and maybe set the 'state' to DONE, which will be overwritten by the main() once it is resumed, which will then wait forever. If all this is true though then I should have this problem even without interrupt nesting.>>> state = TRANSMITTING; >>> } >>> } >>> } >>> } >> >> the variable 'state' is needed in order to prevent the main to write >> into the serial port while the ISR is already doing this. >> The ISR would look like the following: >>> >>> void isr_sport(int signal) { >>> >>> if (read_from_fifo(&byte) == OK) write_to_sport(byte); >>> else state = DONE; >>> } >>[...]>> If the 'interrupt nesting' is disabled everything works as expected, but >> if it is enabled something breaks. After some bytes transmitted to the >> serial port the program simply runs through the main, as if the 'state' >> variable was not set to DONE when the ISR emptied the fifo. > > This symptom can result from the race condition above. >I was indeed fascinated by the explanation, but it seems the problem is not *only* there.> I'm not sure how the dependence on interrupt nesting arises. Perhaps, > when nesting is disabled, and the serial-port interrupt is signalled > while the timer interrupt is being handled, one or a few instructions in > main() are executed between the return from the timer interrupt handler > and before the serial-port handler is executed. This might give main() > enough time to execute its "state" assignment before isr_sport() runs. >In principle higher priority interrupt should vector immediately and lower priority interrupt should be handled "right after" but I should check in the assembler to really understand what is done.> To remove the race, move the assignment "state = TRANSMITTING" before > the write_to_sport(), in main().It did not help, still the same signature.> > By the way, check that you have declared "state" as volatile. >why? in the event of 'state' been optimized away then it should never work, right?
On 7/1/2012 8:26 PM, Reinhardt Behm wrote: [...]> > You have not shown, if somewhere interrupts are disabled.In the runtime header after the processor vectored to the interrupt table the interrupts are disabled temporarily. This is from the assembler runtime header:> * Interrupt vector for high priority timer interrupt: */ > ___lib_TMZOI: BIT CLR MODE1 0x1000; /*Disable interrupts */ > DM(I7,M7)=I13; /*Save I13 (scratch reg)*/ > I13=DM(___lib_int_table+4*6+5); /*addr of dispatch to jump to*/ > BIT SET MODE2 0x80000; /*Freeze cache */ > DM(I7,M7)=I15; /*Save another scratch reg*/ > JUMP (M13, I13) (DB); /*Jump to dispatcher */ > I15=___lib_int_table+4*6; /*Int slot next_mask */ > I13=dm(___lib_int_table+4*6+2); /*read addr of handler */ > > /* Interrupt vector for external interrupts:*/ > ___lib_IRQ3I: BIT CLR MODE1 0x1000; /*Disable interrupts */ > DM(I7,M7)=I13; /*Save I13 (scratch reg)*/ > I13=DM(___lib_int_table+5*6+5); /*addr of dispatch to jump to*/ > BIT SET MODE2 0x80000; /*Freeze cache */ > DM(I7,M7)=I15; /*Save another scratch reg*/ > JUMP (M13, I13) (DB); /*Jump to dispatcher */ > I15=___lib_int_table+5*6; /*Int slot next_mask */ > I13=dm(___lib_int_table+5*6+2); /*read addr of handler */ >You can see the 'BIT CLR MODE1 0x1000' instruction disable the interrupts. Then, somewhere else in the interrupt dispatcher, the interrupts are enabled again.> I see one possible race condition: > > if (state != TRANSMITTING) { > if (read_from_fifo(&byte) == OK) { > write_to_sport(byte); > ----the isr_sport() will be called in within ~500us after the write_to_sport(), since this is the amount of time the UART will take to transmit the first byte and be ready for the second one. But if the isr_timer() kicks in at this stage than it is possible that before the ISR is completed the serial port will complete the transmission and send an interrupt which will then be waiting for the isr_timer() to be complete. This may happen and can break the logic even without nested interrupt.> isr_sport() is triggered and sets state=DONE > ---- > state = TRANSMITTING; > > > Without the timer running this will probably never happen. But the timer ISR > might just step in after write_to_port and consume CPU time.correct. But then the problem should be also present if nesting is not enabled.> > The simplest way out of this is to disable interrupts before > write_to_sport() and enable them after state = TRANSMITTING; >This is in principle doable but I would like to find a more general solution which would avoid bumping in this situation again. Something maybe addressable at the desing level rather then the implementation one.
On 7/1/2012 7:53 PM, Lanarcam wrote: [...]> I haven't seen any flaw in either your code or your concept. > It would be useful to have the assembly code, particularly > that of the ISR and the pre and post ISR code to come up > with something. >I do not want to barf lots of assembler code in here, I'm trying to rationalize the flow and maybe post part of it. This will help me understand the logic a bit better, since I should say that I do not know this part very well. As I understand the processor jumps to the interrupt vector table (with some latency) and then from that moment on is all taken care by the runtime library which is wrapping my ISR with pushing and popping registers on the stack. As soon as I have dug enough into the code I will post it here.
On 7/1/2012 11:49 PM, Tim Wescott wrote: [...]> > A light went on: > > Often the amount of stuff you have to save for an ISR is greater than > the amount of stuff you have to save for an ordinary function call. > > Most modern C compilers let you declare a function to be the target > of an interrupt. The syntax isn't standardized -- for some it's > "void interrupt foo()", for some it's something like "void foo() > attribute ("__interrupt__")", etc. But it boils down to letting the > compiler know that it's an interrupt service routine, so that it can > do the extra saves & restores. >In this case this is done with an "extension" in the signal.h. The prototype is the following: void interrupt(int signal, void (*func)(int)); where func is the service routine for the signal. I expect all the registers pushing and popping is done in there. This is how I can associate a service routine to an interrupt. Certainly I may need to look into the actual code to see what the compiler and the library are really doing there. [...]> > And finally, if you can get by without nested interrupts -- don't use > them. >few lines above the previous paragraph you stated:> It may be that you were just lucking out without nested interrupts, > and were constantly exposing yourself to trouble and the other shoe > just never dropped. >and I share the same fear, that is why, even if I don't need to use nested interrupt I want to understand what is going on before this problem will byte me harder down the road when going back will be more tedious and frustrating. p.s.: apologies for reordering your post, but it helped the flow of discussion.
On 12-07-02 13:37 , alb wrote:> On 7/1/2012 8:19 PM, Niklas Holsti wrote: > [...] >>>> int main() { >>>> ... >>>> while(1) { >>>> write_to_fifo(data); >>>> if (state != TRANSMITTING) { >>>> if (read_from_fifo(&byte) == OK) { >>>> write_to_sport(byte); >> >> At this point you have a race between main() and isr_sport(): both will >> assign something to "state". Normally main() will no doubt have time to >> execute the assignment below, before isr_sport() is called, but if >> something else interrupts main() at this point, isr_sport() may reach >> its statement "state = DONE" first, which means that main() then >> overwrites DONE with TRANSMITTING in "state", and the logic fails. >> > > got your point about the race condition, but let me dig a little further > here. At the point you mentioned the isr_sport is not running, since > there's no transmission going on.The point I meant was just after the statement write_to_sport(byte); I assumed that this statement writes "byte" to the serial port, and that (as usual for output ports) writing has the side effect of starting the transmission of the byte. (If this is not so, your code does not show how and where the serial transmission is started.) Since the serial port is now transmitting, isr_sport() will be called when the byte is transmitted and the serial-port interrupt occurs. In this sense, main() and isr_sport() are concurrent at this point. If you don't really know how fast things go (because of other interrupts or delays that can happen), either main() or isr_sport() can reach its assignment to "state" first. That is a race.> The only interrupt that may kick in is > the timer ISR.No, the serial-port interrupt can also occur, because you started transmission by writing the byte to the serial port. *When* the interrupt happens depends on the speed of the serial port. Without the timer interrupt, the transmission of the byte will no doubt take so long that main() has time to assign "state = TRANSMITTING" before isr_sport() is called by the interrupt, and all is well. If the timer interrupt (or something else) delays main() for a sufficient time between write_to_sport(byte) and "state = TRANSMITTING", the serial interrupt will occur between those two statements of main(). If this leads to isr_sport() being executed between these two statements, and if isr_sport() assigns "state = DONE", the assignments to "state" happen in the wrong order.> If this is true then the you are still right that there's a race > condition, since the isr_sport will be run *after* (lower priority) the > isr_timer() and maybe set the 'state' to DONE, which will be overwritten > by the main() once it is resumed, which will then wait forever.Yep.> If all this is true though then I should have this problem even without > interrupt nesting.Maybe, maybe not. As I said, without interrupt nesting I'm guessing that when the timer-interrupt handler executes return-from-interrupt, control returns to the main() function for a couple of instructions (the 21020 has a deep pipeline with two branch-delay slots) before the pending serial-port interrupt forces control to isr_sport(). This may give main() enough time between the two ISRs to execute the assignment "state = TRANSMITTING", giving the right order of assignments. Also, the 21020 delays interrupt responses for some multi-cycle instructions, including branch. Since the statement "state = TRANSMITTING" is the last statement in a loop body, it is quite likely that the compiler puts it in a delay slot of the "return to loop head" branch. This makes it more likely that the assigment is executed between the return from the timer-interrupt handler and the invocation of the serial-port interrupt handler, when interrupt nesting is disabled. I don't know for sure that this is what happens, but it would explain what you see. But for sure your code has a logical race condition at this point.> In principle higher priority interrupt should vector immediatelyThe 21020 User Manual has diagrams showing several cycles for interrupt synchronization and recognition and branching (with delay slots) to the vector. So "immediately" in some sense, yes, but not on the next clock cycle.> and > lower priority interrupt should be handled "right after" but I should > check in the assembler to really understand what is done.It won't be visible in the assembly code, only in the descriptions of the 21020 Program Sequencer HW in the AD documentation. And that description may not be very complete or precise there, either.>> To remove the race, move the assignment "state = TRANSMITTING" before >> the write_to_sport(), in main(). > > It did not help, still the same signature.Hmmm... see below on ordering of assignments.>> By the way, check that you have declared "state" as volatile. >> > > why? in the event of 'state' been optimized away then it should never > work, right?Today the compiler may be kind to you, and not make trouble. Do you want to be surprised tomorrow, after some small, unrelated change to the program? The compiler is free to reorder writes to non-volatile variables, as long as the mathematical effect is OK. If x and y are two non-volatile variables (or if only one of them is volatile) and you write in your C code x = 1; y = 2; the C compiler can translate it to an instruction sequence that first assigns 2 to y and then assigns 1 to x. If x and y are both volatile, the compiler must respect the written order of assignments (and also of reads of the variables). So if "state" is not a volatile variable, moving its assignment statement in the C source code may or may not move it in the assembly code. What is write_to_sport()? Is is a macro or a function? If it is a macro (or a possibly in-lined function) of the form "portvar = byte", you should also declare "portvar" as volatile, to ensure that the order of assignments is as in the C source. And of course you should also make sure that accesses to the FIFO are protected against wrongful concurrent manipulations from main() and isr_sport(), as was suggested in other posts. -- Niklas Holsti Tidorum Ltd niklas holsti tidorum fi . @ .
