Sirs, In one of the books, I am reading, as a part of DFT duality properties, it is mentioned that: - a point in frequency domain is equivalent to siusoid in time domain - a point in time domain is equivalent to sinusoid in frequency domain While I am able to appreciate the first point that a point in frequency domain is equivalent to sinusoid in time domain (all the information in time domain is concentrated in a single frequency). I am unable to clearly understand point 2 as to how a point in time domain can result in multitude of frequencies in the frequency domain. How a single point can be decomposed into many frequencies. Thanks ...
time domain and frequency domain
Started by ●July 17, 2012
Reply by ●July 17, 20122012-07-17
On Tue, 17 Jul 2012 10:56:38 -0500 "manishp" <58525@dsprelated> wrote:> Sirs, > > In one of the books, I am reading, as a part of DFT duality properties, it > is mentioned that: > - a point in frequency domain is equivalent to siusoid in time domain > - a point in time domain is equivalent to sinusoid in frequency domain > > While I am able to appreciate the first point that a point in frequency > domain is equivalent to sinusoid in time domain (all the information in > time domain is concentrated in a single frequency). > > I am unable to clearly understand point 2 as to how a point in time domain > can result in multitude of frequencies in the frequency domain. How a > single point can be decomposed into many frequencies. > > Thanks ... > >Because that single point doesn't exist in isolation, it's a single point of non zero amplitude in all of time, extending infinitely in both directions, the rest of which has no amplitude. The basis function in frequency space is the sinewave (well, complex exponential, but...). No sinewave looks like that; a single isolated point in all the void. So instead, what you've got there at t=0 is the result of constructive interference between all possible frequencies, and which sum to zero everywhere else. -- Rob Gaddi, Highland Technology -- www.highlandtechnology.com Email address domain is currently out of order. See above to fix.
On Jul 17, 10:56=A0am, "manishp" <58525@dsprelated> wrote:> In one of the books, I am reading, as a part of DFT duality properties, i=t> is mentioned that: > =A0 - a point in frequency domain is equivalent to siusoid in time domain > =A0 - a point in time domain is equivalent to sinusoid in frequency domai=n Are you sure that it is the DFT =3D Discrete Fourier Transform that you are talking about and not the continuous-time Fourier Transform? There is a difference between the two concepts, and your questions seem to relate more to the continuous-time Fourier Transform than the DFT. So, read your book very very carefully and tell us again which duality properties you are talking about. A DFT transforms one (periodic) sequence of numbers into another (periodic) sequence of numbers and there is nothing sinusoidal about these sequences, in time domain or frequency domain. Dilip Sarwate
dvsarwate <dvsarwate@yahoo.com> wrote: (snip)> Are you sure that it is the DFT = Discrete Fourier Transform that > you are talking about and not the continuous-time Fourier Transform? > There is a difference between the two concepts, and your questions > seem to relate more to the continuous-time Fourier Transform than > the DFT.Well, you can do the continuous Fourier transform on a series of equally spaced delta functions, and get the DFT result. (Especially if the series is periodic with an appropriate period.) One can also consider the continuous-time transform as the limit of the DFT as the sample period goes to zero. You then get the Fourier transform pair: discrete <--> periodic Applied twice, you get: discrete periodic <--> discrete periodic -- glen
"manishp" <58525@dsprelated> writes:> Sirs, > > In one of the books, I am reading, as a part of DFT duality properties, it > is mentioned that: > - a point in frequency domain is equivalent to siusoid in time domain > - a point in time domain is equivalent to sinusoid in frequency domain > > While I am able to appreciate the first point that a point in frequency > domain is equivalent to sinusoid in time domain (all the information in > time domain is concentrated in a single frequency). > > I am unable to clearly understand point 2 as to how a point in time domain > can result in multitude of frequencies in the frequency domain. How a > single point can be decomposed into many frequencies. > > Thanks ...You're talking about the Fourier transform (continuous-time). A point in the time domain has zero energy and no FT. A Dirac delta function in time has an infinite frequency spectrum. To see why, study the sifting property of the Dirac delta function, especially as seen in the (forward) Fourier transform integral. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On 7/17/2012 8:56 AM, manishp wrote:> Sirs, > > In one of the books, I am reading, as a part of DFT duality properties, it > is mentioned that: > - a point in frequency domain is equivalent to siusoid in time domain > - a point in time domain is equivalent to sinusoid in frequency domain > > While I am able to appreciate the first point that a point in frequency > domain is equivalent to sinusoid in time domain (all the information in > time domain is concentrated in a single frequency). > > I am unable to clearly understand point 2 as to how a point in time domain > can result in multitude of frequencies in the frequency domain. How a > single point can be decomposed into many frequencies. > > Thanks ... > >I agree that you must be talking about the Fourier Transform (continuous) instead of the DFT (discrete). I would read the transform equations. They are pretty similar. So similar in fact that you can see how they are almost "the same". They probably are the same when you substitute in simple functions such as those you describe. Can you see the inverse cases: "A sinusoid becomes a Dirac (your "point")"? Actually you would be better off with this: Instead of: "- a point in time domain is equivalent to sinusoid in frequency domain" Consider using: "- a pair of equal, real Diracs in the time domain, equally spaced away from zero time, is equivalent to a real sinusoid in the frequency domain" Once you have that down, you can consider what it means to have but one of those Diracs. - what if the Diracs have the same sign? (you get a cosine) - what if the same Diracs have the opposite sign? (you get +/- a sine) - what if you add the two above together to get one Dirac? (superposition applies so you add their transforms together in frequency). Fred
Reply by ●July 18, 20122012-07-18
dvsarwate <dvsarwate@yahoo.com> wrote:> On Jul 17, 10:56�am, "manishp" <58525@dsprelated> wrote: > >> In one of the books, I am reading, as a part of DFT duality properties, it >> is mentioned that: >> � - a point in frequency domain is equivalent to siusoid in time domain >> � - a point in time domain is equivalent to sinusoid in frequency domain > > Are you sure that it is the DFT = Discrete Fourier Transform that > you are talking about and not the continuous-time Fourier Transform? > There is a difference between the two concepts, and your questions > seem to relate more to the continuous-time Fourier Transform than > the DFT. So, read your book very very carefully and tell us again > which duality properties you are talking about. A DFT transforms > one (periodic) sequence of numbers into another (periodic) > sequence of numbers and there is nothing sinusoidal about these > sequences, in time domain or frequency domain.How to interprete results of octave code given below ;) for i=1:4;l=100; x=zeros(1,l); x(i)=1; subplot(4,1,i); y=fft(x); plot([1,length(y)],[-1,1],'.',real(y),'-',imag(y)); end
>dvsarwate <dvsarwate@yahoo.com> wrote: >> On Jul 17, 10:56�am, "manishp" <58525@dsprelated> wrote: >> >>> In one of the books, I am reading, as a part of DFT duality properties,it>>> is mentioned that: >>> � - a point in frequency domain is equivalent to siusoid in timedomain>>> � - a point in time domain is equivalent to sinusoid in frequencydomain>> >> Are you sure that it is the DFT = Discrete Fourier Transform that >> you are talking about and not the continuous-time Fourier Transform? >> There is a difference between the two concepts, and your questions >> seem to relate more to the continuous-time Fourier Transform than >> the DFT. So, read your book very very carefully and tell us again >> which duality properties you are talking about. A DFT transforms >> one (periodic) sequence of numbers into another (periodic) >> sequence of numbers and there is nothing sinusoidal about these >> sequences, in time domain or frequency domain. > > >How to interprete results of octave code given below ;) > >for i=1:4;l=100; > x=zeros(1,l); > x(i)=1; > subplot(4,1,i); > y=fft(x); > plot([1,length(y)],[-1,1],'.',real(y),'-',imag(y)); >end >you are generating x = [1 0 0 0...] then x [0 1 0 0 ...] then x = [0 0 1 0 ..] then x = [0 0 0 1 0...] then looking at frequency domain. in all cases abs(y) = 1 over all frequencies but phase (angle(y) changes depending on location of impulse. y is real only when x = 1 else it becomes complex corresponding to change of phase. kadhiem
On Jul 17, 3:24=A0pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:> Well, you can do the continuous Fourier transform on a series of > equally spaced delta functions, and get the DFT result. (Especially > if the series is periodic with an appropriate period.)You really like to muddy the waters without contributing anything relevant to the discussion, don't you? Dilip Sarwate
Reply by ●July 19, 20122012-07-19
>On Jul 17, 3:24=A0pm, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote: > >> Well, you can do the continuous Fourier transform on a series of >> equally spaced delta functions, and get the DFT result. (Especially >> if the series is periodic with an appropriate period.) > >You really like to muddy the waters without contributing anything >relevant to the discussion, don't you? > >Dilip SarwateBelow text is from the same book and is mentioned in the context of DFT. "This symmetry between the time and frequency domains is called duality, and gives rise to many interesting properties. For example, a single point in the frequency domain corresponds to a sinusoid in the time domain. By duality, the inverse is also true, a single point in the time domain corresponds to a sinusoid in the frequency domain" Also, thanks for your earlier replies.
