Is there a reason (founded in DSP theory) to resample in stages instead of going directly from one sample rate to another? If so what is the reason? And where can I read about it? For example: When I resample from 8kHz to 48kHz the resulting audio sounds worse compared to the audio I get if I resample in stages from 8kHz to 24kHz to 48kHz. Thanks
Resampling in stages?
Started by ●July 19, 2012
Reply by ●July 19, 20122012-07-19
Yes, it's more efficient, if you measure by the number of multiplications it takes. Intuitively, the impulse response of a direct filter at the high rate looks very regular. One might wonder, whether this could be computed more efficiently. A multi-stage filter does just that. Designed properly, it achieves a similar (but not exactly the same) impulse response that can be computed using shared expressions for adjacent output samples. I wrote a design example on the topic here in my blog: http://www.dsprelated.com/showarticle/156.php In this particular case, use of multiple stages reduces the computational load to 12 % (in other words, 88 % are avoided). And it could be improved further by changing the final stage to CIC or the like.
> Yes, it's more efficient, if you measure by the number of multiplications > it takes.Thank you...However...I was more curious about whether or not there is a reason (founded in DSP theory) why I achieve better audio quality when I resample from 8 -> 24 -> 48 instead of directly from 8 --> 48 ?? My guess is that when you filter in stages you get better stop band suppression, but i'm not sure if that's correct.
>Thank you...However...I was more curious about whether or not there is areason (founded in DSP theory) why I achieve better audio quality when I resample from 8 -> 24 -> 48 instead of directly from 8 --> 48 ?? I think you'll find the reason in your implementation, not DSP theory.
> >> Yes, it's more efficient, if you measure by the number ofmultiplications>> it takes. > >Thank you...However...I was more curious about whether or not there is areason (founded in DSP theory) why I achieve better audio quality when I resample from 8 -> 24 -> 48 instead of directly from 8 --> 48 ??> >My guess is that when you filter in stages you get better stop bandsuppression, but i'm not sure if that's correct.>Whether it is one stage or cascaded stages, the final output depends on your filtering quality that you choose. In all cases ideal interpolation is not possible as it requires +/- infinite samples(an obvious mathematical fiction). breaking up into multistage may help implementation resource. kadhiem
On Thu, 19 Jul 2012 06:00:17 -0700, dspchris2012 wrote:> Is there a reason (founded in DSP theory) to resample in stages instead > of going directly from one sample rate to another? If so what is the > reason? And where can I read about it?As pointed out, it is computationally more efficient.> For example: When I resample from 8kHz to 48kHz the resulting audio > sounds worse compared to the audio I get if I resample in stages from > 8kHz to 24kHz to 48kHz.I can't think of a single reason why decimating in stages should preserve the signal any better than decimating in one thump. If anything, decimating in stages should result in a more complicated spectrum to your decimated result, with more aliasing products running around and causing more trouble. So I rather expect that you're not decimating correctly, and something about doing it in stages is masking the problem to some extent. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
>I can't think of a single reason why decimating in stages should preserve >the signal any better than decimating in one thump. If anything, >decimating in stages should result in a more complicated spectrum to your >decimated result, with more aliasing products running around and causing >more trouble.We're not talking about decimation. We are talking about upsampling and interpolation, i.e.: METHOD #1 1. Upsample by 3 2. Low-pass filter 3. Upsample by 2 4. Low-pass filter versus METHOD #2 1. Upsample by 6 2. Low-pass filter My simulations show that there is more noise in the stop band with method #2 than with method #1 I am using 4 cascaded 2nd order IIR filters (direct form 2 transposed).
On Thu, 19 Jul 2012 12:20:09 -0700, ChrisDSP wrote:>>I can't think of a single reason why decimating in stages should >>preserve the signal any better than decimating in one thump. If >>anything, decimating in stages should result in a more complicated >>spectrum to your decimated result, with more aliasing products running >>around and causing more trouble. > > We're not talking about decimation. We are talking about upsampling and > interpolation, i.e.: > > METHOD #1 > > 1. Upsample by 3 > 2. Low-pass filter > 3. Upsample by 2 > 4. Low-pass filter > > versus > > METHOD #2 > > 1. Upsample by 6 > 2. Low-pass filterD'oh. I missed that.> My simulations show that there is more noise in the stop band with > method #2 than with method #1 > > I am using 4 cascaded 2nd order IIR filters (direct form 2 transposed).If you are restricting yourself to four 2nd-order filters per upsample stage, then when you upsample in two stages you have the benefit of eight poles of filtering, where you only have four in the single-stage case. If that's the case, then the extra filtering you have available in the two-stage case may, indeed, be making all the difference in the world. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
