On Sat, 4 Aug 2012 20:21:36 -0500, "Youdidnt buildthat" <invalid@invalid.com> wrote: [Snipped by Lyons]> >not so. >the crc is too short, > out of a codeword set 2^128 (128 bits) and a crc of 16 bits 2^16 , you will >have the same crc generated for 128/16 or 8 codewords > >> -- >> ponchoHello Poncho, I haven't read this complete thread. But remember, if someone does build a reliable CRC system, they didn't build that. Some one else made that happen. [-Rick-]
CRC codes
Started by ●August 2, 2012
Reply by ●August 5, 20122012-08-05
On 08/05/2012 10:58 AM, Rick Lyons wrote:> On Sat, 4 Aug 2012 20:21:36 -0500, "Youdidnt buildthat" > <invalid@invalid.com> wrote: > > [Snipped by Lyons] >> >> not so. >> the crc is too short, >> out of a codeword set 2^128 (128 bits) and a crc of 16 bits 2^16 , you will >> have the same crc generated for 128/16 or 8 codewords >> >>> -- >>> poncho > > Hello Poncho, > I haven't read this complete thread. > But remember, if someone does build a reliable > CRC system, they didn't build that. Some one > else made that happen. > > [-Rick-] > >I was under the impression that CRCs are generally designed and used to detect errors, for example in packets sent over the Internet ... I was looking for strong evidence that advanced error-correcting codes were used in hard drives. Hitachi produces enterprise-class hard-drives, which tend to pack more GB per square inch, spin faster and have lower error rates. From this piece from 2008, one learns that they produced dense packing based in part on LDPC codes (low-density parity check codes): < http://techon.nikkeibp.co.jp/english/NEWS_EN/20080804/155945/ > . --- More recently, they've done production od drives that use LDPC codes: From the spec. document for Deskstar 5K3000 & Ultrastar 5K3000 hard disk drives: "576 bit LDPC in 512 byte format" --> "Deskstar 5K3000 (3TB) and Ultrastar 5K3000 OEM Specification" --> http://www.hgst.com/tech/techlib.nsf/products/Ultrastar_5K3000 For the Ultrastar 5K3000, they give a mean time before failure of ~= 2.0 million hours. But enterprise-class disk drives are more expensive ... David Bernier
Reply by ●August 6, 20122012-08-06
In <jvffng$rpf$1@speranza.aioe.org>, on 08/03/2012 at 03:14 AM, glen herrmannsfeldt <gah@ugcs.caltech.edu> said:>As far as I know, they originated as part of tape coding, and then >carried over to disk drives.Early tape drives used longitudinal and vertical parity bits for error checking. AFAIK the first use of a CRC was in data communications during the mid 1960's. -- Shmuel (Seymour J.) Metz, SysProg and JOAT <http://patriot.net/~shmuel> Unsolicited bulk E-mail subject to legal action. I reserve the right to publicly post or ridicule any abusive E-mail. Reply to domain Patriot dot net user shmuel+news to contact me. Do not reply to spamtrap@library.lspace.org
