Sampling Complex Signal
Started by Walter Wego ●August 5, 2012
Hi,
I know you have to sample above Nyquist or you risk aliases folding into
the passband.
But it if your signal is complex, it seems to me that in a given interval
of time you’ve collected twice the information you would have for a real
signal, or that you’ve effectively doubled your sample rate.
I got that same message when looking through old posts on DSP Related.
I thought that implied that for a basebanded complex signal (for example)
the highest frequency you could correctly reconstruct would be twice that
for a real signal.
But I’m not finding that to be the case in practice, as the Matlab
snippet below shows – the complex signal folds into the passband just as
the real signal does.
While I still have some hair left to tear out, can someone help me
understand where I’m going astray, and why the part 2 of code below gives
the “wrong” result?
Thanks, it’s much appreciated.
Walt
clear all
Fs = 2048;
t  = (0:1/Fs:4-1/Fs);
F1 = 1024+256;
LO = 32;
nyquistfreq = Fs/2
aliasfreq   = Fs-F1
% ----- Part 1 -----
% Create a real, undersampled signal that will fold into passband
x = cos(2*pi*F1*t);
% Calculate the spectrum
NFFT = 1024;
z    = fft(x, NFFT);
Pzz  = abs(z);
% Plot the spectrum
Dec = 1;
f   = ((Fs/2) / Dec) * linspace(0, 1, NFFT/2+1);
figure(100);
plot(f, 2*Pzz(1:1+NFFT/2)/NFFT);
axis([f(1), f(end), 0, 1.01*max(2*Pzz(1:1+NFFT/2)/NFFT)]);
title('Spectrum of Undersampled Real Signal');
% ----- Part 2 -----
% Translate spectrum of original signal (becomes complex in time)
xs = x .* exp(-i*2*pi*LO*t);
NFFT = 1024;
z = fft(xs, NFFT);
Pzz = abs(z);
% Plot the spectrum
Dec = 1;
f = ((Fs/2) / Dec) * linspace(0, 1, NFFT/2+1) + LO;
figure(200);
title('Spectrum of Complex Signal');
>Hi, > >I know you have to sample above Nyquist or you risk aliases folding into >the passband. > >But it if your signal is complex, it seems to me that in a given interval >of time you’ve collected twice the information you would have for a
real
>signal, or that you’ve effectively doubled your sample rate. > >I got that same message when looking through old posts on DSP Related. > >I thought that implied that for a basebanded complex signal (for example) >the highest frequency you could correctly reconstruct would be twice that >for a real signal. > >But I’m not finding that to be the case in practice, as the Matlab >snippet below shows – the complex signal folds into the passband just
as
>the real signal does. > >While I still have some hair left to tear out, can someone help me >understand where I’m going astray, and why the part 2 of code below
gives
>the “wrong” result? > >Thanks, it’s much appreciated. > >Walt > >clear all > >Fs = 2048; >t = (0:1/Fs:4-1/Fs); >F1 = 1024+256; >LO = 32; > >nyquistfreq = Fs/2 >aliasfreq = Fs-F1 > >% ----- Part 1 ----- > >% Create a real, undersampled signal that will fold into passband >x = cos(2*pi*F1*t); > >% Calculate the spectrum >NFFT = 1024; >z = fft(x, NFFT); >Pzz = abs(z); > >% Plot the spectrum >Dec = 1; >f = ((Fs/2) / Dec) * linspace(0, 1, NFFT/2+1); >figure(100); >plot(f, 2*Pzz(1:1+NFFT/2)/NFFT); >axis([f(1), f(end), 0, 1.01*max(2*Pzz(1:1+NFFT/2)/NFFT)]); >title('Spectrum of Undersampled Real Signal'); > >% ----- Part 2 ----- > >% Translate spectrum of original signal (becomes complex in time) >xs = x .* exp(-i*2*pi*LO*t); > >% Calculate the spectrum >NFFT = 1024; >z = fft(xs, NFFT); >Pzz = abs(z); > >% Plot the spectrum >Dec = 1; >f = ((Fs/2) / Dec) * linspace(0, 1, NFFT/2+1) + LO; >figure(200); >plot(f, 2*Pzz(1:1+NFFT/2)/NFFT); >axis([f(1), f(end), 0, 1.01*max(2*Pzz(1:1+NFFT/2)/NFFT)]); >title('Spectrum of Complex Signal'); > > >
But sampling only applies to real signal (call it I or Q, Re or Im). It remains that the ADC must sample correctly each channel separately. A complex signal cannot exist in real design, instead we have two channels and process them as if they are members of a complex signal. Kadhiem
Remember also a complex approach does not change frequency value of signal
but may eliminate a dc mirror copy
Kadhiem
I haven't run your code but I think the conceptual problem is that not all =
complex signals are analytic signals. An analytic signal has no negative fr=
equency components. When you multiplied by exp(I ....) you just made a smal=
l circular shift in the frequency domain but you still have negative freque=
ncies. Instead you should construct your complex signal using x + i*hilbert=
(x)
Bob
On Sun, 05 Aug 2012 08:38:11 -0500, "Walter Wego" <61340@dsprelated>
wrote:
>Hi, > >I know you have to sample above Nyquist or you risk aliases folding into >the passband. > >But it if your signal is complex, it seems to me that in a given interval >of time you&rsquo;ve collected twice the information you would have for a real >signal, or that you&rsquo;ve effectively doubled your sample rate. > >I got that same message when looking through old posts on DSP Related. > >I thought that implied that for a basebanded complex signal (for example) >the highest frequency you could correctly reconstruct would be twice that >for a real signal. > >But I&rsquo;m not finding that to be the case in practice, as the Matlab >snippet below shows &ndash; the complex signal folds into the passband just as >the real signal does. > >While I still have some hair left to tear out, can someone help me >understand where I&rsquo;m going astray, and why the part 2 of code below gives >the &ldquo;wrong&#4294967295;? result? > >Thanks, it&rsquo;s much appreciated. > >Walt
Hello Walt, If I may be so bold, in your spectrum analysis modeling I suggest that you always plot the full freq spectra range from 0 -to- Fs (or -Fs/2 -to- approx. +Fs/2). Your real signal has a non-zero spectral component at 768 Hz, and a non-zero spectral component at -768 Hz. Your complex signal will have the same spectrum as the real signal, only the spec components of the complex signal will be shifted in the negative freq direction by 32 Hz. Those shifted components will reside at -800 and +736 Hz. Your 2nd plot has an incorrect freq-axis vector. Suggest you plot using: Freq_Axis = (-NFFT/2:(NFFT/2)-1)*(Fs/NFFT); plot(Freq_Axis, fftshift(Pzz), '-bs') hold on plot(Freq_Axis, fftshift(Pzz_2), '-ro') hold off title('Blue = real sig, Red = complex sig.') xlabel('Hz'), grid on, zoom on Good Luck, [-Rick-] PS. I've been watching "Breaking Bad" on Netflix. Walt, would your last name happen to be "White"?
wrote:
>Hi, > >I know you have to sample above Nyquist or you risk aliases folding into >the passband. > >But it if your signal is complex, it seems to me that in a given interval >of time you&rsquo;ve collected twice the information you would have for a real >signal, or that you&rsquo;ve effectively doubled your sample rate. > >I got that same message when looking through old posts on DSP Related. > >I thought that implied that for a basebanded complex signal (for example) >the highest frequency you could correctly reconstruct would be twice that >for a real signal. > >But I&rsquo;m not finding that to be the case in practice, as the Matlab >snippet below shows &ndash; the complex signal folds into the passband just as >the real signal does. > >While I still have some hair left to tear out, can someone help me >understand where I&rsquo;m going astray, and why the part 2 of code below gives >the &ldquo;wrong&rdquo; result? > >Thanks, it&rsquo;s much appreciated. > >Walt > >clear all > >Fs = 2048; >t = (0:1/Fs:4-1/Fs); >F1 = 1024+256; >LO = 32; > >nyquistfreq = Fs/2 >aliasfreq = Fs-F1 > >% ----- Part 1 ----- > >% Create a real, undersampled signal that will fold into passband >x = cos(2*pi*F1*t); > >% Calculate the spectrum >NFFT = 1024; >z = fft(x, NFFT); >Pzz = abs(z); > >% Plot the spectrum >Dec = 1; >f = ((Fs/2) / Dec) * linspace(0, 1, NFFT/2+1); >figure(100); >plot(f, 2*Pzz(1:1+NFFT/2)/NFFT); >axis([f(1), f(end), 0, 1.01*max(2*Pzz(1:1+NFFT/2)/NFFT)]); >title('Spectrum of Undersampled Real Signal'); > >% ----- Part 2 ----- > >% Translate spectrum of original signal (becomes complex in time) >xs = x .* exp(-i*2*pi*LO*t); > >% Calculate the spectrum >NFFT = 1024; >z = fft(xs, NFFT); >Pzz = abs(z); > >% Plot the spectrum >Dec = 1; >f = ((Fs/2) / Dec) * linspace(0, 1, NFFT/2+1) + LO; >figure(200); >plot(f, 2*Pzz(1:1+NFFT/2)/NFFT); >axis([f(1), f(end), 0, 1.01*max(2*Pzz(1:1+NFFT/2)/NFFT)]); >title('Spectrum of Complex Signal');
For real-valued signals sampling at Fs provides low-pass support for signals from zero to Fs/2. For complex-valued signals sampling at Fs provides baseband support from -Fs/2 to +Fs/2, or double the bandwidth of the real-valued case. So when you put real-valued signal energy at higher than Fs/2, it will "alias" in either case. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On Sun, 05 Aug 2012 09:41:45 -0700, Rick Lyons
<R.Lyons@_BOGUS_ieee.org> wrote:
> >Your 2nd plot has an incorrect freq-axis vector. >Suggest you plot using: > > Freq_Axis = (-NFFT/2:(NFFT/2)-1)*(Fs/NFFT); > plot(Freq_Axis, fftshift(Pzz), '-bs') > hold on > plot(Freq_Axis, fftshift(Pzz_2), '-ro') > hold off > title('Blue = real sig, Red = complex sig.') > xlabel('Hz'), grid on, zoom on >
Oops. I forgot to mention; the above "Pzz_2" is the complex signal's power spectrum. Sorry 'bout that. [-Rick-]
On Sun, 05 Aug 2012 11:03:13 -0500, "kaz" <37480@dsprelated> wrote:
>Remember also a complex approach does not change frequency value of signal >but may eliminate a dc mirror copy > >Kadhiem
Whoa, wait! Multiplying a real-valued signal by a negative-frequency complex exponential yields a complex-valued time signal whose spectrum is different from the real-valued signal's spectrum. [-Rick-]
>On Sun, 05 Aug 2012 11:03:13 -0500, "kaz" <37480@dsprelated> wrote: > >>Remember also a complex approach does not change frequency value of
signal
>>but may eliminate a dc mirror copy >> >>Kadhiem > >Whoa, wait! Multiplying a real-valued signal >by a negative-frequency complex exponential >yields a complex-valued time signal whose >spectrum is different from the real-valued >signal's spectrum. > >[-Rick-] >
Of course you can shift signal anywhere to positive or negative frequency but I am talking about a pair of a given signal as Re/Im. Each of Re or Im will have mirror image around dc but the pair as a complex signal may have one copy only depending on their balance. Kadhiem
On Sun, 05 Aug 2012 08:38:11 -0500, Walter Wego wrote:
> Hi, > > I know you have to sample above Nyquist or you risk aliases folding into > the passband. > > But it if your signal is complex, it seems to me that in a given > interval of time you&rsquo;ve collected twice the information you would have > for a real signal, or that you&rsquo;ve effectively doubled your sample rate. > > I got that same message when looking through old posts on DSP Related. > > I thought that implied that for a basebanded complex signal (for > example) the highest frequency you could correctly reconstruct would be > twice that for a real signal. > > But I&rsquo;m not finding that to be the case in practice, as the Matlab > snippet below shows &ndash; the complex signal folds into the passband just as > the real signal does. > > While I still have some hair left to tear out, can someone help me > understand where I&rsquo;m going astray, and why the part 2 of code below > gives the &ldquo;wrong&rdquo; result? > > Thanks, it&rsquo;s much appreciated.
Walter: It looks like Rick already gave you a good answer to the question you were asking, so I'll let that stand (besides, I'm too lazy to look at someone else's code -- I have to spend at least 30 seconds per line telling myself "no, this is not necessarily crap, it's just that I didn't write it"). So instead I'll comment on your assertion that you must sample above Nyquist or risk aliasing. This (and related assertions of varying degrees of erroneousness) have been made on this group before, often enough that I have an answer all ready for all of them: http://www.wescottdesign.com/articles/Sampling/sampling.pdf I'm not sure if the answer for your case is in there. It is: (a), yes, sampling a complex signal gets you (essentially) two samples per interval, and hence could Nyquist with half as many samples as you'd think, (b), the Nyquist criterion says you need 2 * B total _independent_ samples -- if your quadrature samples aren't independent (i.e., if you haven't filtered out the lower sideband) then they won't help. And (c), if you read the paper you'll find that the Nyquist criterion, as you state it, is unreachable, because there are no humanly-accessible signals of finite bandwidth. To really use Nyquist's work correctly you have to understand how aliasing mucks things up, why it's impossible to fully meet the criterion, and (like the story of the mathematician, the engineer, and the pretty girl) what you need to do to make your system work close enough. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
