Eric Jacobsen <eric.jacobsen@ieee.org> wrote:> Usually there's a framing system (or other similar mechanism) with > Unique Words that will reveal the proper data polarity.> Many FEC codes are linear, so the inverse of a codeword is also a > codeword, and a Viterbi decoder will properly decode an encoded data > stream or its inverse. So the Unique Words (or whatever mechanism is > used) can be either coded or uncoded, it's a system/architecture > decision.10baseT ethernet, like coaxial ethernet uses polarity sensitive Manchester coding. It is, however, easy for transceivers to detect the polarity and correct it, with the added advantage of another LED and marketing point. (Or maybe without the LED, but still with the marketing point.)> Using differential coding gets around all of that.As well as I understand it, ethernet could have done that for 10baseT (UTP ethernet), but keeping the same coding as coaxial seemed to be an advantage. -- glen
180 phase ambiguity
Started by ●August 14, 2012
Reply by ●November 12, 20122012-11-12
On Mon, 12 Nov 2012 07:44:43 +0000 (UTC), glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:>Eric Jacobsen <eric.jacobsen@ieee.org> wrote: > >> Usually there's a framing system (or other similar mechanism) with >> Unique Words that will reveal the proper data polarity. > >> Many FEC codes are linear, so the inverse of a codeword is also a >> codeword, and a Viterbi decoder will properly decode an encoded data >> stream or its inverse. So the Unique Words (or whatever mechanism is >> used) can be either coded or uncoded, it's a system/architecture >> decision. > >10baseT ethernet, like coaxial ethernet uses polarity sensitive >Manchester coding. It is, however, easy for transceivers to detect >the polarity and correct it, with the added advantage of another >LED and marketing point. (Or maybe without the LED, but still with >the marketing point.) > >> Using differential coding gets around all of that. > >As well as I understand it, ethernet could have done that for >10baseT (UTP ethernet), but keeping the same coding as coaxial >seemed to be an advantage. > >-- glenThere's a downside to differential coding in that it costs a little bit of link margin in AWGN, so you give up a little bit of potential performance to use it. The performance loss is due to the "error doubling" effect from a symbol error creating an error for the current symbol as well as making the reference for the next symbol erroneous. So it's generally not used in a lot of systems for that reason, and many systems need a framing structure for other reasons, so the UWs for polarity ambiguity resolution kind of come for free in that case. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
