Hi all, I'm looking for the audio effect library (commercial or public domain), I need the compressor, EQ, reverb, chorus, flanger... to process wave files on PC. It may be static or dynamic library and can be called by my Windows application. Can any one tell me where to get/buy? I've search for the FAQ of comp.dsp and can not find suitable library... Thanks in advance.
Looking for audio effect library
Started by ●November 18, 2003
Reply by ●November 18, 20032003-11-18
check out the [free] directx 9 sdk, lots of directx dmos (direct media objects) that you can plug into your app... sdj Karmas Lin wrote:> Hi all, > > I'm looking for the audio effect library (commercial or public domain), > I need the compressor, EQ, reverb, chorus, flanger... to process wave > files on PC. It may be static or dynamic library and can be called by > my Windows application. > Can any one tell me where to get/buy? > I've search for the FAQ of comp.dsp and can not find suitable library... > Thanks in advance. > >
Using the term "library" fairly loosely: OpenSource libraries include STK (all C++) by Perry Cook: http://www-ccrma.stanford.edu/software/stk/ and CMix: http://www.music.princeton.edu/winham/cmix.html There is also a lot of useful stuff at the musicdsp archive: http://www.musicdsp.org This includes implementations of the rbj EQ cookbook, which is very much the de facto standard for implementing EQ. Apparently it is used in commercial applications as well as in free ones. it also has info about the musicdsp list, which you might find useful to join. Compression functions seem to be less common in libraries. There is one in Audacity: http://audacity.sourceforge.net/ And here is source for a DirectX plugin based on the Cakewalk SDK: http://www.pacificsoundcraft.com/software/directx/compressor/Compressor-Source/ Finally, you will find loads of links to all sorts of audio things at Dave Phillips' Linux Sound site: http://www.linuxsound.at/ All public domain of course, and usually GPL. Some code may be LGPL. Richard Dobson Karmas Lin wrote:> Hi all, > > I'm looking for the audio effect library (commercial or public domain), > I need the compressor, EQ, reverb, chorus, flanger... to process wave > files on PC. It may be static or dynamic library and can be called by > my Windows application. > Can any one tell me where to get/buy? > I've search for the FAQ of comp.dsp and can not find suitable library... > Thanks in advance. > >
Reply by ●November 19, 20032003-11-19
In comp.dsp, sms@dspdimension.com (Stephan M. Bernsee) wrote:>...and, have a look at http://www.dspdimension.comAnd if all that isn't enough, try harmony-central.com.>Regards >--smb
