Does anyone know whether a PCI card exists that will act as an audio active crossover network? Ie it should accept a digital input from a PC soundcard then be capable of splitting it digitally into a number of frequency bands (at least 3), with user definable cut off frequencies and attenuation rates. Obviously seperate outputs should be available for each frequency band per channel. Or is it pie in the sky? ;=} Martin
PC audio crossover
Started by ●September 30, 2004
Reply by ●September 30, 20042004-09-30
I think you are much more likely to find software running on a PC to do such a thing. Combined with a digital input/multiple-output sound card or cards, this should get you what you want. "Martin" <margrove@pgen.net> wrote in message news:c20d037a.0409300819.306b64f@posting.google.com...> Does anyone know whether a PCI card exists that will act as an audio > active crossover network? Ie it should accept a digital input from a > PC soundcard then be capable of splitting it digitally into a number > of frequency bands (at least 3), with user definable cut off > frequencies and attenuation rates. Obviously seperate outputs should > be available for each frequency band per channel. Or is it pie in the > sky? ;=} > Martin
Reply by ●October 2, 20042004-10-02
"Jon Harris" <goldentully@hotmail.com> wrote in message news:<2s31u8F1gssgcU1@uni-berlin.de>...> I think you are much more likely to find software running on a PC to do such a > thing. Combined with a digital input/multiple-output sound card or cards, this > should get you what you want. >Thanks for your views. As you've probably gathered I'm no expert on sound cards, but so far I've not come across any card that offers the type of control I require. If you know of a particular card or independent software or any combination of the above that will answer to my needs I'd be more than grateful if you would share it with me. Best wishes, Martin.
Reply by ●October 3, 20042004-10-03
On 2004-10-03 00:28:56 +0200, margrove@pgen.net (Martin) said:> Thanks for your views. As you've probably gathered I'm no expert on > sound cards, but so far I've not come across any card that offers the > type of control I require. If you know of a particular card or > independent software or any combination of the above that will answer > to my needs I'd be more than grateful if you would share it with me. > Best wishes, > Martin.From what I know, Terratec makes some cards that have several outputs and or which drivers (for Linux etc.) are available (cf. http://produceren.terratec.net/product.php?pid=7). The RME cards are another alternative (http://www.rme-audio.com/english/soundcds.htm). You could write your own software for this - a bit tedious perhaps, but possible. -- Stephan M. Bernsee http://www.dspdimension.com
Reply by ●October 8, 20042004-10-08
Stephan M. Bernsee <spam@dspdimension.com> wrote in message news:<2s9t4uF1i3p44U1@uni-berlin.de>...> On 2004-10-03 00:28:56 +0200, margrove@pgen.net (Martin) said: > > > Thanks for your views. As you've probably gathered I'm no expert on > > sound cards, but so far I've not come across any card that offers the > > type of control I require. If you know of a particular card or > > independent software or any combination of the above that will answer > > to my needs I'd be more than grateful if you would share it with me. > > Best wishes, > > Martin. > > From what I know, Terratec makes some cards that have several outputs > and or which drivers (for Linux etc.) are available (cf. > http://produceren.terratec.net/product.php?pid=7). The RME cards are > another alternative (http://www.rme-audio.com/english/soundcds.htm). > You could write your own software for this - a bit tedious perhaps, but > possible.Thanks, i've had a look and like the Terratec. Now it's just a question of software!
