Costas loop problem at a specific phase angle
Started by Unknown September 11, 2012
i've included a link where i've stored the costas loop model i've been work=
ing on. I am sorry, i am new here, and i did try to search and get a hold o=
f as many literature on the topic as possible.
http://dl.dropbox.com/u/102875916/COSTAS_PI_4_PROBLEM.mdl
my loop bW is: 1KHz
my Sampling: 100 MHz
Symbol Rate: 1Mhz
arm filter cutoffs: .5MHz -> 9MHz (both FIRs)
Loop Filters: values derived from Dr. Rice's book equations
I am not sure I have implemented it correctly. The loop seems to track ok (=
I've tried it with modulated data and it works ok) whenever the phase offse=
t i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, and so forth, it's i=
n no-man's land. I think that's what's called a cycle slip???.=20
-while at it, i want to know how to detect when there's slippage and engage=
 the loop per se, or what's the mechanism for the state detection algorithm=
i just want to know that I am at least in the right direction. Please, some=
one kindly has looked over my simulink model, tell me where I am going wron=
g with the design. (i've worked on this for about a month non-stop now, and=
 I don't know if i can read or study anything more to make me have an epiph=
any alone).
P.S. i did look at the model built posted at a russian website. It makes se=
nse except that it's all done at a baseband processing. I've questions abou=
t that too but that maybe later.
thanks and (great community by the way)
sam
On Tue, 11 Sep 2012 18:11:45 -0700, samberhanu wrote:
> i've included a link where i've stored the costas loop model i've been > working on. I am sorry, i am new here, and i did try to search and get a > hold of as many literature on the topic as possible. > > http://dl.dropbox.com/u/102875916/COSTAS_PI_4_PROBLEM.mdl > > my loop bW is: 1KHz my Sampling: 100 MHz Symbol Rate: 1Mhz arm filter > cutoffs: .5MHz -> 9MHz (both FIRs) > > Loop Filters: values derived from Dr. Rice's book equations > > I am not sure I have implemented it correctly. The loop seems to track > ok (I've tried it with modulated data and it works ok) whenever the > phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, and so > forth, it's in no-man's land. I think that's what's called a cycle > slip???. > > -while at it, i want to know how to detect when there's slippage and > engage the loop per se, or what's the mechanism for the state detection > algorithm? > > i just want to know that I am at least in the right direction. Please, > someone kindly has looked over my simulink model, tell me where I am > going wrong with the design. (i've worked on this for about a month > non-stop now, and I don't know if i can read or study anything more to > make me have an epiphany alone). > > P.S. i did look at the model built posted at a russian website. It makes > sense except that it's all done at a baseband processing. I've questions > about that too but that maybe later. > thanks and (great community by the way) > > sam
Few of us have Simulink. Surprisingly enough, DSP does not equal Matlab, and facility with one does not necessarily follow from facility with the other. Perhaps if you gave us a succinct mathematical model of the loop we could help you out -- you'll find that there's not a lot of enthusiasm in this group for blindly trusting to math packages: that's not generally the route to understanding in DSP problems. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
> phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, > and so forth, it's in no-man's land. I think that's what's called > a cycle slip???. If I recall correctly, the Costas loop can "lock" at either of two phases with respect to the carrier: 0 degrees and 180 degrees. Is that what you are seeing? Rob
On Sep 12, 12:22&#4294967295;am, Rob Doyle <radioe...@gmail.com> wrote:
> On 9/11/2012 6:11 PM, samberh...@gmail.com wrote:> I am not sure I have implemented it correctly. The loop seems to track > > ok (I've tried it with modulated data and it works ok) whenever the > > &#4294967295;> phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, > &#4294967295;> and so forth, it's in no-man's land. I think that's what's called > &#4294967295;> a cycle slip???. > > If I recall correctly, the Costas loop can "lock" at either of two > phases with respect to the carrier: 0 degrees and 180 degrees. > > Is that what you are seeing? > > Rob
there's a name I know... Hi Bob! Mark
On Tue, 11 Sep 2012 21:21:57 -0700, Rob Doyle wrote:
> On 9/11/2012 6:11 PM, samberhanu@gmail.com wrote: >> I am not sure I have implemented it correctly. The loop seems to track >> ok (I've tried it with modulated data and it works ok) whenever the > > phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, and > > so forth, it's in no-man's land. I think that's what's called a cycle > > slip???. > > If I recall correctly, the Costas loop can "lock" at either of two > phases with respect to the carrier: 0 degrees and 180 degrees. > > Is that what you are seeing?
If it's a properly implemented Costas loop and it's quadrature PSK, then it'll lock at 0, 90, 180 and -90. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
On Wednesday, September 12, 2012 5:43:36 PM UTC-4, Tim Wescott wrote:
> On Tue, 11 Sep 2012 21:21:57 -0700, Rob Doyle wrote: > > > > > On 9/11/2012 6:11 PM, samberhanu@gmail.com wrote: > > >> I am not sure I have implemented it correctly. The loop seems to track > > >> ok (I've tried it with modulated data and it works ok) whenever the > > > > phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, and > > > > so forth, it's in no-man's land. I think that's what's called a cycle > > > > slip???. > > > > > > If I recall correctly, the Costas loop can "lock" at either of two > > > phases with respect to the carrier: 0 degrees and 180 degrees. > > > > > > Is that what you are seeing? > > > > If it's a properly implemented Costas loop and it's quadrature PSK, then > > it'll lock at 0, 90, 180 and -90. > > > > > > -- > > My liberal friends think I'm a conservative kook. > > My conservative friends think I'm a liberal kook. > > Why am I not happy that they have found common ground? > > > > Tim Wescott, Communications, Control, Circuits & Software > > http://www.wescottdesign.com
thanks for your input. this is a BPSK signal. It locks at 0 & 180 as expected. But i've found out that my loop does this at the expense of a non-zero stead-state error. I guess that means it's really not correctly locking. Is this the phenomenon called false lock? How can i improve the steady state error? it's a positive steady state error. as far as i remember from control theory, this is done by increasing the proportional controller (Mr. Wescott, your article infers this also) one of the most frustrating things about this is that I have to find the proportional gain for the controller. It's supposed to be the slope of the s-curve at angle zero? I think it is but even with that value it seems it's not working. the equation set in Dr. Rice's book states Kp => the proportional controller gain to be set to 1/T*AGC gain * AGC(Vpp)^2.... is that correct?
On Sep 13, 7:39&#4294967295;pm, samb <samberh...@gmail.com> wrote:
> On Wednesday, September 12, 2012 5:43:36 PM UTC-4, Tim Wescott wrote: > > On Tue, 11 Sep 2012 21:21:57 -0700, Rob Doyle wrote: > > > > On 9/11/2012 6:11 PM, samberh...@gmail.com wrote: > > > >> I am not sure I have implemented it correctly. The loop seems to track > > > >> ok (I've tried it with modulated data and it works ok) whenever the > > > > &#4294967295;> phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, and > > > > &#4294967295;> so forth, it's in no-man's land. I think that's what's called a cycle > > > > &#4294967295;> slip???. > > > > If I recall correctly, the Costas loop can "lock" at either of two > > > > phases with respect to the carrier: 0 degrees and 180 degrees. > > > > Is that what you are seeing? > > > If it's a properly implemented Costas loop and it's quadrature PSK, then > > > it'll lock at 0, 90, 180 and -90. > > > -- > > > My liberal friends think I'm a conservative kook. > > > My conservative friends think I'm a liberal kook. > > > Why am I not happy that they have found common ground? > > > Tim Wescott, Communications, Control, Circuits & Software > > >http://www.wescottdesign.com > > thanks for your input. > this is a BPSK signal. It locks at 0 & 180 as expected. But i've found out that my loop does this at the expense of a non-zero stead-state error. I guess that means it's really not correctly locking. Is this the phenomenon called false lock? > How can i improve the steady state error? it's a positive steady state error. as far as i remember from control theory, this is done by increasing the proportional controller (Mr. Wescott, your article infers this also) > > one of the most frustrating things about this is that I have to find the proportional gain for the controller. It's supposed to be the slope of the s-curve at angle zero? I think it is but even with that value it seems it's not working. the equation set in Dr. Rice's book states Kp => the proportional controller gain to be set to 1/T*AGC gain * AGC(Vpp)^2.... is that correct?
here's another book that may help http://www.amazon.com/The-Theory-Practice-Modem-Design/dp/0471851086 MJark
On Thursday, September 13, 2012 8:47:30 PM UTC-4, Mark wrote:
> On Sep 13, 7:39&#4294967295;pm, samb <samberh...@gmail.com> wrote: > > > On Wednesday, September 12, 2012 5:43:36 PM UTC-4, Tim Wescott wrote: > > > > On Tue, 11 Sep 2012 21:21:57 -0700, Rob Doyle wrote: > > > > > > > > On 9/11/2012 6:11 PM, samberh...@gmail.com wrote: > > > > > > > >> I am not sure I have implemented it correctly. The loop seems to track > > > > > > > >> ok (I've tried it with modulated data and it works ok) whenever the > > > > > > > > &#4294967295;> phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, and > > > > > > > > &#4294967295;> so forth, it's in no-man's land. I think that's what's called a cycle > > > > > > > > &#4294967295;> slip???. > > > > > > > > If I recall correctly, the Costas loop can "lock" at either of two > > > > > > > > phases with respect to the carrier: 0 degrees and 180 degrees. > > > > > > > > Is that what you are seeing? > > > > > > > If it's a properly implemented Costas loop and it's quadrature PSK, then > > > > > > > it'll lock at 0, 90, 180 and -90. > > > > > > > -- > > > > > > > My liberal friends think I'm a conservative kook. > > > > > > > My conservative friends think I'm a liberal kook. > > > > > > > Why am I not happy that they have found common ground? > > > > > > > Tim Wescott, Communications, Control, Circuits & Software > > > > > > >http://www.wescottdesign.com > > > > > > thanks for your input. > > > this is a BPSK signal. It locks at 0 & 180 as expected. But i've found out that my loop does this at the expense of a non-zero stead-state error. I guess that means it's really not correctly locking. Is this the phenomenon called false lock? > > > How can i improve the steady state error? it's a positive steady state error. as far as i remember from control theory, this is done by increasing the proportional controller (Mr. Wescott, your article infers this also) > > > > > > one of the most frustrating things about this is that I have to find the proportional gain for the controller. It's supposed to be the slope of the s-curve at angle zero? I think it is but even with that value it seems it's not working. the equation set in Dr. Rice's book states Kp => the proportional controller gain to be set to 1/T*AGC gain * AGC(Vpp)^2.... is that correct? > > > > here's another book that may help > > > > http://www.amazon.com/The-Theory-Practice-Modem-Design/dp/0471851086 > > > > MJark
the reviews seem to be poor. nevertheless, for ten bucks, worth taking a shot, so ordered. hopefully, it'll help.
On Thu, 13 Sep 2012 16:39:17 -0700 (PDT), samb <samberhanu@gmail.com>
wrote:
>On Wednesday, September 12, 2012 5:43:36 PM UTC-4, Tim Wescott wrote: >> On Tue, 11 Sep 2012 21:21:57 -0700, Rob Doyle wrote: >>=20 >>=20 >>=20 >> > On 9/11/2012 6:11 PM, samberhanu@gmail.com wrote: >>=20 >> >> I am not sure I have implemented it correctly. The loop seems to track >>=20 >> >> ok (I've tried it with modulated data and it works ok) whenever the >>=20 >> > > phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, an= >d >>=20 >> > > so forth, it's in no-man's land. I think that's what's called a cycl= >e >>=20 >> > > slip???. >>=20 >> >=20 >>=20 >> > If I recall correctly, the Costas loop can "lock" at either of two >>=20 >> > phases with respect to the carrier: 0 degrees and 180 degrees. >>=20 >> >=20 >>=20 >> > Is that what you are seeing? >>=20 >>=20 >>=20 >> If it's a properly implemented Costas loop and it's quadrature PSK, then= >=20 >>=20 >> it'll lock at 0, 90, 180 and -90. >>=20 >>=20 >>=20 >>=20 >>=20 >> --=20 >>=20 >> My liberal friends think I'm a conservative kook. >>=20 >> My conservative friends think I'm a liberal kook. >>=20 >> Why am I not happy that they have found common ground? >>=20 >>=20 >>=20 >> Tim Wescott, Communications, Control, Circuits & Software >>=20 >> http://www.wescottdesign.com > >thanks for your input. >this is a BPSK signal. It locks at 0 & 180 as expected. But i've found out = >that my loop does this at the expense of a non-zero stead-state error. I gu= >ess that means it's really not correctly locking. Is this the phenomenon ca= >lled false lock?=20
How is this "steady state error" being measured and where? Do you mean it locks with some phase offset from 0 and 180? Do you mean the loop filter has a non-zero DC output? Do you mean it's slowly rotating? Help us out here and be clear about what you mean.
>How can i improve the steady state error? it's a positive steady state erro= >r. as far as i remember from control theory, this is done by increasing the= > proportional controller (Mr. Wescott, your article infers this also)=20
First you need to explain what you mean by "steady state error".
>one of the most frustrating things about this is that I have to find the pr= >oportional gain for the controller. It's supposed to be the slope of the s-= >curve at angle zero? I think it is but even with that value it seems it's n= >ot working. the equation set in Dr. Rice's book states Kp =3D> the proporti= >onal controller gain to be set to 1/T*AGC gain * AGC(Vpp)^2.... is that cor= >rect?
Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On Thu, 13 Sep 2012 16:39:17 -0700, samb wrote:
> On Wednesday, September 12, 2012 5:43:36 PM UTC-4, Tim Wescott wrote: >> On Tue, 11 Sep 2012 21:21:57 -0700, Rob Doyle wrote: >> >> >> >> > On 9/11/2012 6:11 PM, samberhanu@gmail.com wrote: >> >> >> I am not sure I have implemented it correctly. The loop seems to >> >> track >> >> >> ok (I've tried it with modulated data and it works ok) whenever the >> >> > > phase offset i apply is a non a PI/4 term. at PI/4, 3PI/4, 6PI/4, >> > > and >> >> > > so forth, it's in no-man's land. I think that's what's called a >> > > cycle >> >> > > slip???. >> >> >> > >> > If I recall correctly, the Costas loop can "lock" at either of two >> >> > phases with respect to the carrier: 0 degrees and 180 degrees. >> >> >> > >> > Is that what you are seeing? >> >> >> >> If it's a properly implemented Costas loop and it's quadrature PSK, >> then >> >> it'll lock at 0, 90, 180 and -90. >> >> >> >> >> >> -- >> >> My liberal friends think I'm a conservative kook. >> >> My conservative friends think I'm a liberal kook. >> >> Why am I not happy that they have found common ground? >> >> >> >> Tim Wescott, Communications, Control, Circuits & Software >> >> http://www.wescottdesign.com > > thanks for your input. > this is a BPSK signal. It locks at 0 & 180 as expected. But i've found > out that my loop does this at the expense of a non-zero stead-state > error. I guess that means it's really not correctly locking. Is this the > phenomenon called false lock?
False lock happens when there's a glitch in the phase detector response that makes the thing lock at the wrong place, or (depending on who's defining the term) when the loop manages to get balanced at a point where the phase detector slope is zero, but the loop is unstable.
> How can i improve the steady state error? > it's a positive steady state error. as far as i remember from control > theory, this is done by increasing the proportional controller (Mr. > Wescott, your article infers this also)
The way to eliminate steady-state error, assuming that your phase detector is working correctly, is with an integrator in the controller. Proportional gain will reduce, but never eliminate, steady-state error. If your phase detector isn't putting out zero at zero error, then you have bigger problems than your gain setting.
> one of the most frustrating things about this is that I have to find the > proportional gain for the controller. It's supposed to be the slope of > the s-curve at angle zero? I think it is but even with that value it > seems it's not working. the equation set in Dr. Rice's book states Kp => > the proportional controller gain to be set to 1/T*AGC gain * > AGC(Vpp)^2.... is that correct?
AGC? Automatic Gain Control? Where did that come in? The gain of the phase detector is the slope of the phase detection characteristic around zero error -- but that's data dependent, because there's only information when the data changes from 0 to 1 or visa- versa. So a long string of ones or zeros means you have no gain, while a long string of 0-1-0-1 means the gain is maximum -- you need to design your loop with this randomly varying gain in mind, or you need to design your transmission protocol to insure plenty of transitions. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
