Hi All, I am working on image compression algo,which needs to be finally processor based.i need some suggestion regarding the time taken to code,test the an image processsing algo in a standard DSP processor such as TI's or in Xilinx FPGA.which one would be better???in terms of time taken and performance..??? cheers MIA
Image Processing Algo on Processor
Started by ●November 17, 2003
Reply by ●November 19, 20032003-11-19
A processor would anyday be faster than an FPGA. "MIA" <imran_akthar@hotmail.com> wrote in message news:b36ae06a.0311162210.5219df2b@posting.google.com...> Hi All, > I am working on image compression algo,which needs to be finally > processor based.i need some suggestion regarding the time taken to > code,test the an image processsing algo in a standard DSP processor > such as TI's or in Xilinx FPGA.which one would be better???in terms of > time taken and performance..??? > > > cheers > MIA
> "MIA" <imran_akthar@hotmail.com> wrote in message > news:b36ae06a.0311162210.5219df2b@posting.google.com...>> I am working on image compression algo,which needs to be finally >>processor based.i need some suggestion regarding the time taken to >>code,test the an image processsing algo in a standard DSP processor >>such as TI's or in Xilinx FPGA.which one would be better???in terms of >>time taken and performance..???Hemant Hariyani wrote: > A processor would anyday be faster than an FPGA. The algorithms could likely be implemnted in the FPGA in a highly parallel fashion, and would then be much faster than on a DSP. If the DSP is fast enough, though, that should save you much in design and implementation costs. What algorithms and how fast does it need to run? -- glen
Hemant Hariyani wrote:> A processor would anyday be faster than an FPGA.... Go to http://andraka.com/ to see your claim refuted. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●November 20, 20032003-11-20
Hi Hemant, I assume you mean faster to implement. It is certainly that. However, you would have to make a terrible mess of the FPGA implementation for it not to win handsomely in speed of execution. Regards, Steve "Hemant Hariyani" <hemanthariyani@ti.com> wrote in message news:<bpg5oq$ooo$1@home.itg.ti.com>...> A processor would anyday be faster than an FPGA. > > "MIA" <imran_akthar@hotmail.com> wrote in message > news:b36ae06a.0311162210.5219df2b@posting.google.com... > > Hi All, > > I am working on image compression algo,which needs to be finally > > processor based.i need some suggestion regarding the time taken to > > code,test the an image processsing algo in a standard DSP processor > > such as TI's or in Xilinx FPGA.which one would be better???in terms of > > time taken and performance..??? > > > > > > cheers > > MIA
Reply by ●November 21, 20032003-11-21
Thats what I meant... probably I should have used better words.... hardware implementation would anyday be faster than software as far as performance is concerned. Moreover, if you need to change your implementation time and again, FPGA could be a pain. Regards Hemant "Steve Underwood" <steveu@coppice.org> wrote in message news:80bddbd7.0311200553.2d9f3898@posting.google.com...> Hi Hemant, > > I assume you mean faster to implement. It is certainly that. However, > you would have to make a terrible mess of the FPGA implementation for > it not to win handsomely in speed of execution. > > Regards, > Steve > > > "Hemant Hariyani" <hemanthariyani@ti.com> wrote in messagenews:<bpg5oq$ooo$1@home.itg.ti.com>...> > A processor would anyday be faster than an FPGA. > > > > "MIA" <imran_akthar@hotmail.com> wrote in message > > news:b36ae06a.0311162210.5219df2b@posting.google.com... > > > Hi All, > > > I am working on image compression algo,which needs to be finally > > > processor based.i need some suggestion regarding the time taken to > > > code,test the an image processsing algo in a standard DSP processor > > > such as TI's or in Xilinx FPGA.which one would be better???in terms of > > > time taken and performance..??? > > > > > > > > > cheers > > > MIA
Reply by ●November 22, 20032003-11-22
FPGAs aren't hard to change, depending on the FPGA. Compiling the algorithm into something that will fit on a single chip can be hard if the wrong chip is chosen. Troubleshooting can be hard unless a good emulator is used. With a modern tool selt, FPGAs are reasonable easy. We use them a lot. In article <bpk72a$8tv$1@home.itg.ti.com>, "Hemant Hariyani" <hemanthariyani@ti.com> wrote:>Thats what I meant... probably I should have used better words.... hardware >implementation would anyday be faster than software as far as performance is >concerned. >Moreover, if you need to change your implementation time and again, FPGA >could be a pain. > >Regards >Hemant >"Steve Underwood" <steveu@coppice.org> wrote in message >news:80bddbd7.0311200553.2d9f3898@posting.google.com... >> Hi Hemant, >> >> I assume you mean faster to implement. It is certainly that. However, >> you would have to make a terrible mess of the FPGA implementation for >> it not to win handsomely in speed of execution. >> >> Regards, >> Steve >> >> >> "Hemant Hariyani" <hemanthariyani@ti.com> wrote in message >news:<bpg5oq$ooo$1@home.itg.ti.com>... >> > A processor would anyday be faster than an FPGA. >> > >> > "MIA" <imran_akthar@hotmail.com> wrote in message >> > news:b36ae06a.0311162210.5219df2b@posting.google.com... >> > > Hi All, >> > > I am working on image compression algo,which needs to be finally >> > > processor based.i need some suggestion regarding the time taken to >> > > code,test the an image processsing algo in a standard DSP processor >> > > such as TI's or in Xilinx FPGA.which one would be better???in terms of >> > > time taken and performance..??? >> > > >> > > >> > > cheers >> > > MIA > >
Reply by ●December 1, 20032003-12-01
Hello all, I am in similar situation as the originator of this message. I graduated a year or so ago and have taken DSP courses as part of my curriculum. I enjoyed the subject matter of DSP & image processing greatly however the labs were mostly done in MATLAB with minimal hardware integration. I now have an image processing project I would like to develop and am contemplating the hardware to use. this posting answered my questions on FPGA's (thank you) . what I would like to know is the how the following chips compare to FPGA in design and implementation and if they are worth considering. Thanks for your help. cw4511 ( http://www.chipwrights.com/docindex.html ) Ax36 ( http://www.omdi.com/ ) Kelvin <nobody@nowhere.nothing> wrote in message news:X1Lvb.16996$y9.5040@twister.socal.rr.com...> FPGAs aren't hard to change, depending on the FPGA. Compiling thealgorithm> into something that will fit on a single chip can be hard if the wrongchip is> chosen. Troubleshooting can be hard unless a good emulator is used. Witha> modern tool selt, FPGAs are reasonable easy. We use them a lot. > > > > In article <bpk72a$8tv$1@home.itg.ti.com>, "Hemant Hariyani" > <hemanthariyani@ti.com> wrote: > >Thats what I meant... probably I should have used better words....hardware> >implementation would anyday be faster than software as far as performanceis> >concerned. > >Moreover, if you need to change your implementation time and again, FPGA > >could be a pain. > > > >Regards > >Hemant > >"Steve Underwood" <steveu@coppice.org> wrote in message > >news:80bddbd7.0311200553.2d9f3898@posting.google.com... > >> Hi Hemant, > >> > >> I assume you mean faster to implement. It is certainly that. However, > >> you would have to make a terrible mess of the FPGA implementation for > >> it not to win handsomely in speed of execution. > >> > >> Regards, > >> Steve > >> > >> > >> "Hemant Hariyani" <hemanthariyani@ti.com> wrote in message > >news:<bpg5oq$ooo$1@home.itg.ti.com>... > >> > A processor would anyday be faster than an FPGA. > >> > > >> > "MIA" <imran_akthar@hotmail.com> wrote in message > >> > news:b36ae06a.0311162210.5219df2b@posting.google.com... > >> > > Hi All, > >> > > I am working on image compression algo,which needs to befinally> >> > > processor based.i need some suggestion regarding the time taken to > >> > > code,test the an image processsing algo in a standard DSP processor > >> > > such as TI's or in Xilinx FPGA.which one would be better???in termsof> >> > > time taken and performance..??? > >> > > > >> > > > >> > > cheers > >> > > MIA > > > >
Reply by ●December 6, 20032003-12-06
hi all, We want to design a product using DSP processor.I want suggestions for the processor available in market specifically TI's. the gist of the project is as below.. this project is for medical industry. a composite video stream either live or archived(usually of 5-8 minutes)is to be compressed.this is fed into a dsp processor which has to process (involves compression) these images (we are now using a video capture card at 30fps,704x576 PAL ) .after the compression is done ,this data is then stored into a hard disk. pls sugggest me the some processors specifically(TI processor,is the TI's digital multimedia processor TMS320DSC24 well suited???) suited for the above requirement.we wanted to use FPGA's but after reading the above problems i feel,we dnt have more development time and scarcity of guys in digital hardware. thanks in advance :-) miadsp
