Well, I think that whatever you do with a laptop computer it will not change your reputation if you explain it from the "weird side" of things. People need a "drawer" to fit you in, so you have to give them some key words they know. If you just fire up your laptop and hack away before them to produce strange sounds out of their voices they will still think "what a useless profession - how come someone is being paid to play with sounds?". So, you have to explain it first in simple terms before you do that to show them how much fun it can be. I often have the same problem, and I usually succeed by explaining it differently: - The general approach: You could say that DSP is some hybrid science between physics, information technology, communications engineering etc. and mention some of the (everyday) equipment that makes use of DSP, such as cell phones, TV sets, DVD players, ECG machines, modems, satellites, radio astronomy telescopes, etc. to illustrate what kind of work you're doing and where it can be found at work. - The specific approach: You could pick one application and explain it to them. If you're into audio, take a reverb for example. Tell them that DSP makes it possible to simulate a room with its acoustic properties without actually having it available. It's easy to see that a concert hall might not be available (or affordable) for some orchestra projects when you need it, so you have to simulate it digitally. Or take time stretching: a dialog that was recorded which is 1:30 min long and needs to fit in a 1:00 slot in a radio ad playlist. Or take de-noising to clean up noisy data.... or speech recognition... the list is quite endless... Cheers Stephan
DSP sound/audio demos
Started by ●November 16, 2003
Reply by ●November 19, 20032003-11-19
Jon Harris wrote:>>Reflections cause phase-cancellation, which cause notch-filter-type >>behaviour in a frequency response. This is non-linear, because it cannot > > be > >>compensated by a linear system (ok, perhaps that's my definition). I >>definitely did not mean harmonic generation (although that is non-linear >>also). > > > Sorry, a notch filter is a linear operation.Of course.> In theory, it can be > compensated for with a linear filter with an inverse characteristic.On second thoughts I see that at every point we have a sum of reflections (original signal filtered with the reflection characteristics of the surface) - this could be modelled with a transversal filter with IIR filters instead of simple tap coefficients. I guess that's linear. But it still isn't correctable with an eq, because every point in the room has a different frequency response.> Sound contractors do that all the time using an RTA.Yeah right - I used to do that as well. However, it doesn't result in an overall flat frequency response, and I explained why in my previous post. Usually your measurement does not correlate very much with your eq setting (unless you are standing right before or beneath the louspeakers).> Sure, you cannot perfectly correct a room for all locations, but you can > improve the frequency response for a large number of locations, perhaps even > the majority of seats.You can try to correct an overall trend (sound is muffeled, flat, washy, etc.) - but the effect of EQ is negligible compared to the acoustic change when a room is half or fully or quarter occupied with people. It's just not worth the bother.> > >>The only justification I see for equalizers in PA systems is for feedback >>suppression. > > > Of course, if the room was perfectly flat, there would be no dominant > frequency to feed back! In theory, you would have no feedback until all of > the sudden, every frequency would feed back. When you equalize for feedback > suppression, you care correcting the system frequency response. When this > is done right, this also tends to correct the room frequency response (OK, > also microphone/speaker frequency response).Feedback correction is just a couple of tight notch filters - this hardly evens out any frequency response or change the "timbre" of the program material. It just cancels resonant frequencies. Regards, Andor
Jerry Avins wrote:> > > > >>>>All > >>>>you have to do with an equalizer is compensate the major non-idealities > >>>>caused mainly by the speakers and the acoustic environment. > > I believe he meant, "All you _can_ (or maybe, ought to) do ...", but he > can clarify that.The equalizer can significantly flatten the response of an audio system. I did that many times and the improvement may be very noticeable.> > - it seems that at least some people are of the opinion that equalizers can > > be used to correct loudspeaker (or room) response. > > Indeed they can.You bet.> No equalizer can flatten the spiky response that shows up if > you run the response curve slowly enough.Flattening the major spikes is quite simple task for the parametric EQ. The notch is more difficult to correct because of the limited power available, however the notches in the response are less noticeable then the spikes.> >>> You cannot equalize a room, because a room does > >>>not have a well-defined frequency response.That is correct. However you can equalize the speaker axis emission in ideal non-echoic room. That makes the speaker sound better in general.> >> > >>If that were germane, one would need different equalization for every > >>cubic foot of space in the room. The phenomenon is real, but it > >>matters very little.I have seen acoustic arrays which were pretending to do that. The idea is similar to the holographic technology.> > The only justification I see for equalizers in PA systems is for feedback > > suppression.That is done better with LMS feedback cancellation and/or adaptive notches. But what really surprises me in all that arguments about FIRs ans IIRs that very few people understand that there is no direct relation between the "ringing" and the phase linearity. The passive RC filter can have very nonlinear phase, however it exibits no ringing. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Jerry Avins wrote:> glen herrmannsfeldt wrote:>> I had a physics lab class once where we measured the impedance, >> attenuation, and propagation velocity for different cables. One was a >> coax cable with a spiral wound center conductor which increases its >> inductance relative to capacitance, for a velocity of about 0.1c. It >> was designed for use as a delay line.> An interesting feature of that cable is that if you take the length of > the stretched-out inner conductor as the length of the cable, The group > velocity comes out not much different from RG59U. You could say that the > signal takes so long to come our because it gets dizzy along the way. > Did the cable have a blue jacket?I think the cable is commonly used in physics experiments, such as connecting photomultiplier tubes to the associated electronics. I don't remember the color, though. Yes, it is interesting that the inductance of a coil works out just about right so that the propagation velocity scales with wire length. I also worked some on TWT (traveling wave tube) designs which use a similar helical structure to slow down the wave. If you tried to argue that the signal was following the helix, though, how do you explain that the outer conductor is not helical? Besides, everyone knows that signals don't travel in wires, but in the space between the wires. -- glen
glen herrmannsfeldt wrote:> Jerry Avins wrote: > >> glen herrmannsfeldt wrote: > > >>> I had a physics lab class once where we measured the impedance, >>> attenuation, and propagation velocity for different cables. One was >>> a coax cable with a spiral wound center conductor which increases its >>> inductance relative to capacitance, for a velocity of about 0.1c. It >>> was designed for use as a delay line. > > >> An interesting feature of that cable is that if you take the length of >> the stretched-out inner conductor as the length of the cable, The >> group velocity comes out not much different from RG59U. You could say >> that the signal takes so long to come our because it gets dizzy along >> the way. Did the cable have a blue jacket? > > > I think the cable is commonly used in physics experiments, such as > connecting photomultiplier tubes to the associated electronics. I don't > remember the color, though. > > Yes, it is interesting that the inductance of a coil works out just > about right so that the propagation velocity scales with wire length. > > I also worked some on TWT (traveling wave tube) designs which use a > similar helical structure to slow down the wave. > > If you tried to argue that the signal was following the helix, though, > how do you explain that the outer conductor is not helical? Besides, > everyone knows that signals don't travel in wires, but in the space > between the wires. > > -- glenI could argue for the space _around_ the wires, but that's quibbling. It creates in me a wonder at the fitness of things to know that that component of the Poynting vector perpendicular to the power-line conductor heats it, while that component parallel to it is delivered downstream. Trying to visualize that while contemplating a drooping catenary is awesome. 8-) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Andor Bariska" <andor@nospam.net> wrote in message news:3fbb3cfa$1@pfaff2.ethz.ch...> Jon Harris wrote: > > >>Reflections cause phase-cancellation, which cause notch-filter-type > >>behaviour in a frequency response. This is non-linear, because it cannot > > > > be > > > >>compensated by a linear system (ok, perhaps that's my definition). I > >>definitely did not mean harmonic generation (although that is non-linear > >>also). > > > > > > Sorry, a notch filter is a linear operation. > > Of course. > > > In theory, it can be > > compensated for with a linear filter with an inverse characteristic. > > On second thoughts I see that at every point we have a sum of > reflections (original signal filtered with the reflection > characteristics of the surface) - this could be modelled with a > transversal filter with IIR filters instead of simple tap coefficients. > I guess that's linear. But it still isn't correctable with an eq, > because every point in the room has a different frequency response.We agree here.> > Sure, you cannot perfectly correct a room for all locations, but you can > > improve the frequency response for a large number of locations, perhapseven> > the majority of seats. > > You can try to correct an overall trend (sound is muffeled, flat, washy, > etc.) - but the effect of EQ is negligible compared to the acoustic > change when a room is half or fully or quarter occupied with people. > It's just not worth the bother.No direct experience, you might be right about that.> >>The only justification I see for equalizers in PA systems is forfeedback> >>suppression. > > > > > > Of course, if the room was perfectly flat, there would be no dominant > > frequency to feed back! In theory, you would have no feedback until allof> > the sudden, every frequency would feed back. When you equalize forfeedback> > suppression, you care correcting the system frequency response. Whenthis> > is done right, this also tends to correct the room frequency response(OK,> > also microphone/speaker frequency response). > > Feedback correction is just a couple of tight notch filters - this > hardly evens out any frequency response or change the "timbre" of the > program material. It just cancels resonant frequencies.But you have to ask yourself, why did the feedback eliminator pick those particular notches to fix the feedback? The answer is that the system response has a peak at that frequency! Hence my assertion that filtering done my feedback elimination devices does tend to flatten a system response. Not that it's perfect correction by any means, but it should be at least moving in the right direction.
Reply by ●November 20, 20032003-11-20
Jerry Avins wrote:> glen herrmannsfeldt wrote:(snip regarding propagation velocity in coax cables with high inductance center conductors)>> If you tried to argue that the signal was following the helix, though, >> how do you explain that the outer conductor is not helical? Besides, >> everyone knows that signals don't travel in wires, but in the space >> between the wires.> I could argue for the space _around_ the wires, but that's quibbling. > It creates in me a wonder at the fitness of things to know that that > component of the Poynting vector perpendicular to the power-line > conductor heats it, while that component parallel to it is delivered > downstream. Trying to visualize that while contemplating a drooping > catenary is awesome. 8-)Depending on the geometry between, around, or something in between. Between isn't too far off for coax, though. For twisted pair it is mostly between, but some a little farther out. Pretty often in the ethernet newsgroup it is necessary to explain the effect of mispaired cables. If signals really travel inside a wire then mispairing would not have any adverse affect. Though there was once a system for transmitting signals on a single wire, so in that case around would be the right description. -- glen
glen herrmannsfeldt wrote: ...> Though there was once a system for transmitting signals on a single > wire, so in that case around would be the right description. > > -- glenMy father, a sheet-metal worker, made a number of G-string launching cones for some of my ham friends. I don't think anyone ever came up with a satisfactory explanation of the wave distribution in the case of curved wire. (That catenary again!) So a G-string is not exactly co-ax with an infinite-diameter outer conductor. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●November 21, 20032003-11-21
Jerry Avins wrote:> glen herrmannsfeldt wrote: > > ... > >> I had a physics lab class once where we measured the impedance, >> attenuation, and propagation velocity for different cables. One was a >> coax cable with a spiral wound center conductor which increases its >> inductance relative to capacitance, for a velocity of about 0.1c. It >> was designed for use as a delay line. > > > An interesting feature of that cable is that if you take the length of > the stretched-out inner conductor as the length of the cable, The group > velocity comes out not much different from RG59U. You could say that the > signal takes so long to come our because it gets dizzy along the way. > Did the cable have a blue jacket? > > JerryHmmm if that's generally true as a first order approximation, it might explain why something I tried as an ignorant teenager interested in Ham radio _apparently_ worked. I needed/wanted a halfwave dipole. Did not have space. Used a couple of handy pieces of Al tubing as long as possible. Made up rest of length required with wire loosely wrapped around .5->.75 inch form. OK, so that was >40 yrs ago ,] As I recall, it did work.
Richard Owlett wrote:> Jerry Avins wrote: > >> glen herrmannsfeldt wrote: >> >> ... >> >>> I had a physics lab class once where we measured the impedance, >>> attenuation, and propagation velocity for different cables. One was >>> a coax cable with a spiral wound center conductor which increases its >>> inductance relative to capacitance, for a velocity of about 0.1c. It >>> was designed for use as a delay line. >> >> >> >> An interesting feature of that cable is that if you take the length of >> the stretched-out inner conductor as the length of the cable, The >> group velocity comes out not much different from RG59U. You could say >> that the signal takes so long to come our because it gets dizzy along >> the way. Did the cable have a blue jacket? >> >> Jerry > > > Hmmm if that's generally true as a first order approximation, it might > explain why something I tried as an ignorant teenager interested in Ham > radio _apparently_ worked. I needed/wanted a halfwave dipole. Did not > have space. Used a couple of handy pieces of Al tubing as long as > possible. Made up rest of length required with wire loosely wrapped > around .5->.75 inch form. OK, so that was >40 yrs ago ,] > As I recall, it did work.Well, a pair of opposed whips is a dipole. An opposed pair of end-loaded whips is an end-loaded dipole. Why not? It should work! Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
