Low Pass Filter: f = 1/ 2Pi RC Why 2Pi ?
Started by ADI8421 ●October 6, 2012
1000 ohm resistor and 0.01 uF capacitor = Standard 2 element Low Pass
filter.
RC time constant = 10us
Low pass fc = 1/2PiRC = 15915.494 Hz = -3db corner frequency = Vout/Vin =
0.707106...
I'm trying to comprehend the use of 2Pi in the above equation.
We're multiplying 2Pi by 10us period.
This gives a result of 62.831us period which when inverted ie. 1/62.831us
gives us 15915.494 Hz. Is my understanding correct here ?
My second train of thought was that 2Pi was a conversion of our 10us period
to angular velocity in radians as used in w(omega)= 2Pif = radians per
second repesentation of f.
But this second train of thought surely can't be correct, because our
original time constant of 10us hasn't changed, merely a new representation
of it in radians. But then, can you even describe a time period rather than
cycle frequency, in radians to start with ?.
Please tell me that the second train of thought is crap and I'll be real
happy.
So, if the second train of thought is crap then this begs a further
question:
Why is it that 2Pi just happens to be the precise multiplier required, of
our 10us time period, or any time period in fact, to allow us to arrive at
our f-3db result ?
This can't just be coincidence. If we wanted to arrive at an f-2db result,
the multiplier would be some other unrecognisable figure. Why does 2Pi hold
this important -3db position ?
If I can get a grasp on this, then a lot of other maths related stuff will
fall into place.
Thanks for a marvelous forum. So many 'brainy' dudes!
Cheers Jim
On 10/6/12 10:26 AM, ADI8421 wrote:
> 1000 ohm resistor and 0.01 uF capacitor = Standard 2 element Low Pass > filter. > > RC time constant = 10us > > Low pass fc = 1/2PiRC = 15915.494 Hz = -3db corner frequency = Vout/Vin = > 0.707106... > > I'm trying to comprehend the use of 2Pi in the above equation. > We're multiplying 2Pi by 10us period. > This gives a result of 62.831us period which when inverted ie. 1/62.831us > gives us 15915.494 Hz. Is my understanding correct here ? > > My second train of thought was that 2Pi was a conversion of our 10us period > to angular velocity in radians as used in w(omega)= 2Pif = radians per > second repesentation of f.
that's pretty much it.
> But this second train of thought surely can't be correct, because our > original time constant of 10us hasn't changed, merely a new representation > of it in radians.
tau = RC = natural time constant. the impulse response h(t) = h(0) e^(-t/tau) decays to a relative value of e^(-1) by this time. omega_c = 1/tau = *angular* cutoff frequency, rads per unit time (whatever unit time that tau is measured in. f_c = omega_c/(2 pi)
> But then, can you even describe a time period rather than > cycle frequency, in radians to start with ?. > Please tell me that the second train of thought is crap and I'll be real > happy.
your second train of thought was closer to reality.
> So, if the second train of thought is crap then this begs a further > question: > > Why is it that 2Pi just happens to be the precise multiplier required, of > our 10us time period, or any time period in fact, to allow us to arrive at > our f-3db result ? > This can't just be coincidence. If we wanted to arrive at an f-2db result, > the multiplier would be some other unrecognisable figure. Why does 2Pi hold > this important -3db position ? >
it doesn't, for angular frequency. if your language is in angular frequency, there is no 2*pi until you speak of the periods of sinusoids.
-- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
maybe there is a better answer, but I'd say the "2 pi" are tied to the
reactance of a capacitor X = 1 / (omega C) with omega = 2 pi f.
To get it to the same unit as the resistance R, "volts per ampere".
On Sat, 06 Oct 2012 09:26:16 -0500, ADI8421 wrote:
> 1000 ohm resistor and 0.01 uF capacitor = Standard 2 element Low Pass > filter. > > RC time constant = 10us > > Low pass fc = 1/2PiRC = 15915.494 Hz = -3db corner frequency = Vout/Vin > = 0.707106... > > I'm trying to comprehend the use of 2Pi in the above equation. > We're multiplying 2Pi by 10us period. > This gives a result of 62.831us period which when inverted ie. > 1/62.831us gives us 15915.494 Hz. Is my understanding correct here ? >
The short answer is that we use the 2 pi because that's what makes the math work. I think your biggest confusion is taking the time constant as a "period", as if it's the cycle time of a periodic signal. It's not. What it _is_ is just a number that appears in the step response of the RC filter: v(t) = V0 * (1 - e^(-t/tau)), where tau is the time constant. Where the 2 pi comes in is when you find the Laplace transform of the system, and analyze its frequency response. The transfer function of the system is H(s) = 1 / (RC * s + 1) If you want to take its frequency response, then you use H(omega) = 1 / (RC * j * omega + 1) where omega -- because that's the way the math works -- is the radian frequency of the sine wave you're shoving in, and j (I hope you already know, or I'm losing you: sorry) is the mathematician's 'i', = sqrt(-1). It turns out that omega = 1/RC is a very characteristic frequency for the filter, because at that frequency H = 1/(j + 1). And 1/(j + 1) has a magnitude of sqrt(1/2), or -3dB down, or 1/2 power. All that's left is to observe -- because that's the way the math works -- is that one Hertz is 2 pi radians/second, and your question is answered. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
OK. Recognize the capacitors with tighter tolerance than +/- 5% are specialty items, and they 1% resistors are sold for a premium.
Nominally, yes. In practice, rarely.
Given the precision of the components, it is more accurate to call that approximately 16 KHz. In order avoid propagating errors, you might call it 15.9 KHz. No greater specificity is warranted.
10 us ti not the period. It is the time constant. Time constant is the time required for a DC level to decay to 1/e of its original.
No. See above for why not.
Spot on.
> But this second train of thought surely can't be correct, because our > original time constant of 10us hasn't changed, merely a new representation > of it in radians. But then, can you even describe a time period rather than > cycle frequency, in radians to start with ?. > Please tell me that the second train of thought is crap and I'll be real > happy.
You should also learn what it means to "beg the question". It means embedding in the premises the result that you want to establish in a logical argument. It's either a deliberate dirty trick or a failure of logical analysis. You probably want proof of that, so here's the best I can offer: http://en.wikipedia.org/wiki/Begging_the_question and http://begthequestion.info/. As always, feel free to beg an answer.
Because, as I wrote above, 10 us is a time constant, not a period. The reciprocal of a time constant is a period in radians per unit time, but most of us prefer degrees or whole turns.
> This can't just be coincidence. If we wanted to arrive at an f-2db result, > the multiplier would be some other unrecognisable figure. Why does 2Pi hold > this important -3db position ? > > If I can get a grasp on this, then a lot of other maths related stuff will > fall into place.
I hope you're right. Also, try to keep a handle on what a number really means. Would you claim that you got 31.6042 MPG from your last tankful, just because that number came up on your calculator?
Come back and keep it lively.
> Cheers Jim
Ta. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Thankyou Tim. I still don't quite grasp it, but I will eventually, given the above statement to ponder. Thankyou to all who offered guidance, even the ugly guy with the small penis and deficient social skills. Many thanks. Jim
> Because, as I wrote above, 10 us is a time constant, not a period. The > reciprocal of a time constant is a period in radians per unit time, but > most of us prefer degrees or whole turns.
<sniff> Surely you meant to say Napiers per second, since we're talking about an argument to e, here. (If you can get picky about the meaning of "to beg the question", I can get picky about obscure units... :) -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
 > <sniff>
I know what a neper is (I'm sure you don't mean that), but not a napier.
Can you enlighten me please?
As for begging the question rather than raising it, it's the same order
of difference as that between a proposal and a proposition.
Jerry
&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
On 10/6/12 10:28 PM, Jerry Avins wrote:
> On 10/6/2012 8:36 PM, Tim Wescott wrote: > > On Sat, 06 Oct 2012 12:42:51 -0400, Jerry Avins wrote: > > > >> On 10/6/2012 10:26 AM, ADI8421 wrote: > > > >> Because, as I wrote above, 10 us is a time constant, not a period. The > >> reciprocal of a time constant is a period in radians per unit time, but > >> most of us prefer degrees or whole turns. > > > > <sniff> > > > > Surely you meant to say Napiers per second, since we're talking about > > an argument to e, here. > > > > (If you can get picky about the meaning of "to beg the question", I > > can get picky about obscure units... > > I know what a neper is (I'm sure you don't mean that), but not a napier. > Can you enlighten me please?
he means neper. a neper and a radian are both the same thing. from a physical POV (not a convention), they are both the dimensionless number 1. from a pure calculus POV, 100 kHz is about 628/ms. that is what "omega" is inside the cos() function, if "t" is in ms. same for nepers. while "turns" is a natural measure, *humans* then create these units called percentages, degrees. but those units are also really just dimensionless numbers. a % is the real number: 1/100. and a degree is pi/180. they are not physical units, but conventional units and conventional units are nothing other than scale factors. physical units have *dimension* as a property. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
>On 10/6/12 10:28 PM, Jerry Avins wrote: >>The reciprocal of a time constant is a period in radians per unit time,
The reciprocal of a cycle time period is frequency in Hertz. So ... with a cycle time period of 1ms the reciprocal is 1000 Hz. But if our 1ms figure is a time constant then the reciprocal result of 1000 is not Hertz but Radians per unit time ? Cheers Jim
