frequency domain multilexing
Started by manishp ●October 13, 2012
On Mon, 15 Oct 2012 07:39:18 -0500, "manishp" <58525@dsprelated>
wrote:
>>You multiply each signal by a _different_ carrier. >> >>For an example of this, turn on your radio and tune into your favorite >>station. Then your next favorite. > >Let me know if my question was confusing. I am re-stating again below:
Yes.
>I have 10 independent signals at base band. The first step would be to >convert each of these into carrier frequency by frequency modulation.
How are the carrier frequencies of the 10 signals related to each other? How widely are they spaced compared to the bandwidths of the signals?
>But having now got multiple signals each containing individual signals at >carrier frequency, how can this be converted into single signal for >transmission. Or in FDM, signals are transmitted as independent signals?
If they are adequately separated in frequency they're orthogonal to each other, so just adding them together creates a single stream that can be transmitted.
>Again, my fundamental doubt is how to combine multiple signals. What is the >mathematical process to achieve this from a designer's perspective.
Addition. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
