FFT from incomplete data
Started by TomTurbo November 13, 2012
On Tue, 13 Nov 2012 01:22:36 -0800 (PST), TomTurbo
<thomaslehner72@gmail.com> wrote:
>Hi, > >I am computing the spectrum of a signal. Sometimes I don't have the full data >available because of communication losses. It is clear, that I can't show the >correct spectrum, but I want to show something that is as close as possible. > >Is there a mathematical correct way to do this ? > >Is there a way to do it without adding frequencies not present in the original signal ?
Hello Tom, I don't know what it means to "not have the full data available", but you might take a look at the article "Recovering Periodically-Spaced Missing Samples", by Andor Bariska in the November 2007 issue of the IEEE Signal Processing Magazine. Good Luck, [-Rick-]
I have the bad habit of using evolutionary algorithms (ES) to calculate Fourier coefficients. Does the FFT give the unique best fit to a power of 2 sequence of typical length (eg. 1024)?  If not then using something like ES would for sure be better though a bit time consuming (but I have fast algorithms).
