I have a fundamental question here regarding the bandwidth of QPSK system. For example, I've a QPSK system generates +1 and -1 in 10Mbit/s. Then, I modulate the QPSK signals with carrier frequency 62.5 MHz. What is the bandwidth of my system? Is it 10 MHz? Let's assume it is a single-carrier system. Thank you.
Bandwidth of single carrier system.
Started by ●December 19, 2012
Reply by ●December 19, 20122012-12-19
On Wed, 19 Dec 2012 15:49:23 -0600, "kbkien" <37528@dsprelated> wrote:>I have a fundamental question here regarding the bandwidth of QPSK system. > > >For example, I've a QPSK system generates +1 and -1 in 10Mbit/s. Then, I >modulate the QPSK signals with carrier frequency 62.5 MHz. What is the >bandwidth of my system? Is it 10 MHz? Let's assume it is a single-carrier >system. > >Thank you.Generally the bandwidth of a single-carrier is the symbol rate. If your QPSK system is uncoded at 10Mbit/s then the symbol rate is 5MHz, which can also be used as the bandwidth. This depends somewhat on what you mean by "bandwidth", and what sort of pulse shaping or filtering may be applied to the signal. If matched filtering is used then the 3dB bandwidth will be pretty close to the symbol rate. The required channel width may be much more than that in order to accommodate the slope of the band edges. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
>On Wed, 19 Dec 2012 15:49:23 -0600, "kbkien" <37528@dsprelated> wrote: > >>I have a fundamental question here regarding the bandwidth of QPSKsystem.>> >> >>For example, I've a QPSK system generates +1 and -1 in 10Mbit/s. Then, I >>modulate the QPSK signals with carrier frequency 62.5 MHz. What is the >>bandwidth of my system? Is it 10 MHz? Let's assume it is asingle-carrier>>system. >> >>Thank you. > >Generally the bandwidth of a single-carrier is the symbol rate. If >your QPSK system is uncoded at 10Mbit/s then the symbol rate is 5MHz, >which can also be used as the bandwidth. > >This depends somewhat on what you mean by "bandwidth", and what sort >of pulse shaping or filtering may be applied to the signal. If >matched filtering is used then the 3dB bandwidth will be pretty close >to the symbol rate. The required channel width may be much more than >that in order to accommodate the slope of the band edges. > > >Eric Jacobsen >Anchor Hill Communications >http://www.anchorhill.com >symbol rate is a completely different concept from bandwidth though they are related. In QPSK system say you start with data bitrate of 20Mbps, you then map bits to symbols(2 bits become one symbol) which leads to symbol rate of 5Msps. If you send these symbols directly out of digital system(through DAC,RF))then it will contain power at very wide range of frequencies centred on your carrier and you are going to have lot of problems with RF engineers and other users of spectrum though it can be done in local short distance cases. In most cases you need to limit the frequency range to practical limits that allows you to send enough information so that symbols will be recovered by receiver and at same time you do not upset other users of spectrum(legal and cost requirements) or upset RF designers. In the case of FDM based systems such as your qpsk carried onto one carrier then the symbols are shaped such that you pass a bandwidth numerically equivalent to 1/2 symbol rate on either side of carrier i.e. you need to pass a final bandwidth of 10 MHz and thus = symbol rate in Msps numerically but remember they are two different things. The criteria of passband width being half is based on -3dB point or so i.e. you pass frequencies such that 5MHz is at -3dB. There will be some excess bandwidth controllable through shaping filter. Why 5MHz is enough is quite simple. If channel passes a 5MHz sinusoid then you can imagine it will pass worse case symbol sequenc of +1,-1,+1,-1...etc draw it on paper and you will see. The crieria for ofdm(as opposed to FDM) is different and worth comparing. Kadhiem
> >symbol rate is a completely different concept from bandwidth though they >are related. >In QPSK system say you start with data bitrate of 20Mbps, you then mapbits should read 10 Mbps(not 20 Mbps) Kadhiem
>> >>symbol rate is a completely different concept from bandwidth though they >>are related. >>In QPSK system say you start with data bitrate of 20Mbps, you then map >bits > >should read 10 Mbps(not 20 Mbps) > >Kadhiem >Apologies, examples using numbers are so difficult to get them right in posting. Last go at it: symbol rate is a completely different concept from bandwidth though they are related. In QPSK system say you start with data bitrate of 10Mbps, you then map bits to symbols(2 bits become one symbol) which leads to symbol rate of 5Msps. If you send these symbols directly out of digital system(through DAC,RF))then it will contain power at very wide range of frequencies centred on your carrier and you are going to have lot of problems with RF engineers and other users of spectrum though it can be done in local short distance cases. In most cases you need to limit the frequency range to practical limits that allows you to send enough information so that symbols will be recovered by receiver and at same time you do not upset other users of spectrum(legal and cost requirements) or upset RF designers. In the case of FDM based systems such as your qpsk carried onto one carrier then the symbols are shaped such that you pass a bandwidth numerically equivalent to 1/2 symbol rate on either side of carrier i.e. you need to pass a final bandwidth of 5MHz and thus = symbol rate in Msps numerically but remember they are two different things. The criteria of passband width being half is based on -3dB point or so i.e. you pass frequencies such that 2.5MHz is at -3dB at baseband level. There will be some excess bandwidth controllable through shaping filter. Why 2.5MHz is enough is quite simple. If channel passes upto a 2.5MHz sinusoid then you can imagine it will pass worse case symbol sequenc of +1,-1,+1,-1...etc draw it on paper and you will see. The crieria for ofdm(as opposed to FDM) is different and worth comparing. Kadhiem
"kbkien" <37528@dsprelated> wrote in message news:5bOdnQe0fsL-q0_NnZ2dnUVZ_sudnZ2d@giganews.com...>I have a fundamental question here regarding the bandwidth of QPSK system. > > > For example, I've a QPSK system generates +1 and -1 in 10Mbit/s. Then, I > modulate the QPSK signals with carrier frequency 62.5 MHz. What is the > bandwidth of my system? Is it 10 MHz? Let's assume it is a single-carrier > system. > > Thank you.
Reply by ●December 20, 20122012-12-20
"kaz" <37480@dsprelated> wrote:> symbol rate is a completely different concept from bandwidth though they > are related.Symbol rate is completely different concept from bandwidth. They are independent and unrelated. The choice of either is a matter of system preference. (Think of UWB or PRML types of signal). VLV
"Vladimir Vassilevsky" <nospam@nowhere.com> writes:> "kaz" <37480@dsprelated> wrote: > >> symbol rate is a completely different concept from bandwidth though they >> are related. > > Symbol rate is completely different concept from bandwidth. They are > independent and unrelated. > The choice of either is a matter of system preference. > (Think of UWB or PRML types of signal).The OP was (fairly) clear about his question and said nothing of UWB or other bandwidth-spreading techniques. -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Keywords here are "pulse shaping filter" and "Nyquist ISI criterion" (see Wikipedia on both), "root-raised cosine filter" and its "rolloff" as a straightforward example.
"mnentwig" <24789@dsprelated> wrote in message news:KpqdnWspuYj8Ak_NnZ2dnUVZ_rudnZ2d@giganews.com...> Keywords here are "pulse shaping filter" and "Nyquist ISI criterion" (see > Wikipedia on both), "root-raised cosine filter" and its "rolloff" as a > straightforward example.Nyquist applies if we require symbols to be orthogonal to each other and use term "equivalent bandwidth". This is particular case rather then general. VLV
