Sirs, Can you explain what is discrete fourier series vis-a-vis discrete fourier transform? Thanks, Manish
discrete fourier series and transform
Started by ●December 23, 2012
Reply by ●December 23, 20122012-12-23
"manishp" <58525@dsprelated> writes:> Sirs, > > Can you explain what is discrete fourier series vis-a-vis discrete fourier > transform?Hi Manish, This is actually a very good question. The analysis and synthesis equations are identical. So what's the difference between the two? The difference between the two is in the assumptions about the input. In the DFS, the input is assumed to be periodic. In the N-point DFT, the input x[n] can be any discrete-time signal (periodic or not), and in which we construct an intermediate, periodic signal xbar[n] from x[n] that is the N samples from x[n] we are analyziing periodically extended. So the DFT provides us with the spectrum of N samples of x[n] as if those N samples were repeated. That is not the same as the spectrum of x[n], e.g., as from the Discrete-Time Fourier Transform (see note). --Randy Note: I am using the various Fourier transform terms as in @BOOK{signalsandsystems, title = "{Signals and Systems}", author = "{Alan~V.~Oppenheim, Alan~S.~Willsky, with Ian~T.~Young}", publisher = "Prentice Hall", year = "1983"} -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
On Sun, 23 Dec 2012 12:46:16 -0500, Randy Yates <yates@digitalsignallabs.com> wrote:>"manishp" <58525@dsprelated> writes: > >> Sirs, >> >> Can you explain what is discrete fourier series vis-a-vis discrete fourier >> transform?Manish, are there specific issues that you're having difficulty with? This can be a fairly broad topic and the definitions that you may find may not be universal.>Hi Manish, > >This is actually a very good question. The analysis and synthesis >equations are identical. So what's the difference between the two? > >The difference between the two is in the assumptions about the input. In >the DFS, the input is assumed to be periodic. In the N-point DFT, the >input x[n] can be any discrete-time signal (periodic or not), and in >which we construct an intermediate, periodic signal xbar[n] from x[n] >that is the N samples from x[n] we are analyziing periodically extended.I'd like to note that the construction of an intermediate periodic signal xbar(n) as Randy has described it and the periodic extension is merely a conceptual step to help some in understanding the process. Many do not feel that that is a necessary step, but it can be helpful for some in understanding the process or interpreting the result.>So the DFT provides us with the spectrum of N samples of x[n] as if >those N samples were repeated. That is not the same as the spectrum of >x[n], e.g., as from the Discrete-Time Fourier Transform (see note). > >--Randy > >Note: > >I am using the various Fourier transform terms as in > >@BOOK{signalsandsystems, > title = "{Signals and Systems}", > author = "{Alan~V.~Oppenheim, Alan~S.~Willsky, with Ian~T.~Young}", > publisher = "Prentice Hall", > year = "1983"} >I either don't have or can't find my copy of Oppenheim and Willsky, but in other texts from Oppenheim, e.g., Digitial Signal Processing and Discrete Time Signal Processing, periodic input sequences are used for the analysis, but it is not stated (anywhere that I can find) that this is necessary. In Discrete Time Signal Processing the analysis of the DFT is described using an approach that does not require any assumption of periodicity in the input. I built on that approach in this article to amplify the point: http://www.dsprelated.com/showarticle/175.php As Randy stated a common distinction between the DFS and DFT is that the DFS model assumes a periodic input, but the Wikipedia entry (which I agree with) states otherwise: http://en.wikipedia.org/wiki/Discrete_Fourier_series Likewise, a Berkely article starts with an assumption of periodicity, but then also calls the same treatment the Discrete-Time Fourier Series, which some people hold as distinct from the DFS: http://ptolemy.eecs.berkeley.edu/eecs20/week8/dfs.html I could go on in showing various definitions or descriptions that differ in significant ways, but I think you get the idea. So confusion on the topic is understandable. If this is for a class, use whatever definition your Prof. or Department prefers. Otherwise, in my experience it is a good idea to clarify with a source what their definition is to avoid confusion in a particular context. Depending on the source or context the DFS may or may not be equivalent to the DFT. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
On 12/23/12 8:00 AM, manishp wrote:> > Can you explain what is discrete fourier series vis-a-vis discrete fourier > transform? >this is a issue that has literally gotten us into a tiff here at comp.dsp . i'm definitely a partisan in that dispute. Randy's answer is as good as any. for me, i'm not willing to grant that there is any difference between the DFT and the DFS if there is no mathematical difference. which there isn't. the consequence is, when you yank N adjacent samples from x[n] and pass it to the DFT or DFS, you are periodically extending that set of N samples. whether you call it a DFT or DFS, if you perform any action on one domain that causes shifting in the other domain, that shifting is necessarily circular, as if x[n] is periodic with period N meaning: x[n+N] = x[n] for all integer n. so periodicity deniers have to use modulo arithmetic in the argument of x[n] (i.e. x[ n mod_N ]) when the apply the same theorems regarding shifting. that way they can say that x[n] is undefined for n < 0 and n > N-1. i find little point in doing that. imposing mod_N arithmetic to the argument of x[n] is identical to periodically extending it. i don't know why they just can say x[n] = x[n+N] . so the DFT transforms one periodic discrete sequence of period N to another periodic discrete sequence of the same period. it is also true that for a finite set of samples x[n] (for 0 <= n < N), that if you were to *zero* extend it out to forever and compute the DTFT of that. and then sample the result of the DTFT at N equally spaced samples, that would also be the DFT. and the act of sampling it exactly corresponds to periodic extension. there's just no way around the property of periodicity. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
manishp <58525@dsprelated> wrote:> Can you explain what is discrete fourier series vis-a-vis discrete fourier > transform?Fourier series and Fourier transform are reasonably well defined. The transform is the integral form, and the series the sum form. Seems to me that what is commonly called the FFT should instead be FFS, but it is a little late now. It might depend on the intent, instead the actual use. If one intends it as a discrete approximation of a continuous transform, or as a discrete transform itself. -- glen
Reply by ●December 24, 20122012-12-24
On 12/23/2012 4:33 PM, robert bristow-johnson wrote: ... > there's just no way around the property of periodicity. Sure there is. There are people around who avtually believe that the world ended when the Mayan calender is purported to have said it would, and that what we experience now is merely a periodic extension. Periodicity -- or its lack -- seems to be in the eye of the beholder. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry, i dunno when, but next time i have to be in Joisey, i wanna look you up again. you are comp.dsp's sage. On 12/24/12 5:59 PM, Jerry Avins wrote:> On 12/23/2012 4:33 PM, robert bristow-johnson wrote: > > ... > > > there's just no way around the property of periodicity. > > Sure there is. There are people around who actually believe that the > world ended when the Mayan calender is purported to have said it would, > and that what we experience now is merely a periodic extension.well, an interesting thought that i first heard from Daniel Dennett to support his thesis of physicalism and to deal with the issue of consciousness or qualia is that we are essentially automatons who *think* they have consciousness. wouldn't that be a similar existence?> Periodicity -- or its lack -- seems to be in the eye of the beholder.sorta like Beauty. interesting that both are properties of mathematics. and i understand that mathematical aesthetic can be in the eye of the beholder. i usually equate it with elegance and, for me, more elegance is always better as long as it remains accurate (well, of course there are times to make the elegant approximation and make use of it, sometimes we do that with an icky cost function and turn it into something you can turn into a closed-form solution). but i always prefer elegance and, i'll admit, i have my own ideas about what elegance means. but, there is also the concrete in mathematics. concrete things like Boolean algebra. if something looks, walks, and quacks like a duck, you really have to find something clearly incompatible with duck to say it ain't. i don't see anywhere that the periodicity deniers have done that. they *do* show examples where periodicity is not evident, but that is different than showing that the DFT is inconsistent with periodicity. where they take issue with me is i am saying that the DFT is *never* inconsistent with periodicity and, of course, that there are situations where periodicity is required. not just elegant (it's also more elegant because you never have to worry about when it doesn't happen) but *required*. it is required whenever shifting is done and it is never incompatible with when shifting is not done. if you say that x[n] is undefined for n < 0 and N >= n, then that's just a definition and the difference between that and defining it outside outside that interval has no consequence. or if you say that x[n] is zero outside of 0 <= n < N the DTFT of that is continuous and periodic. but at this point, of course x[n] is not periodic (unless it's zero). then when you define the DFT as the sampling of the DTFT at N equally-spaced frequencies between -pi and +pi, that action necessarily causes x[n] to be periodically shifted and overlap-added. and since it was zero outside that interval, then nothing but zeros get added up except one term, and that is x[n-m*N] for some integer m. or you can just say that the DFT maps a periodic sequence with period N to another periodic sequence of the same period and the iDFT back again. this is equivalent to saying that the DFT periodically extends the finite data set passed to it, and that is i believe the most concise way to put it. either way, it's unavoidable. just turning one's face away does not change the fact. Jerry, bestest regrads.. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●December 25, 20122012-12-25
On 12/24/2012 10:13 PM, robert bristow-johnson wrote:> > Jerry, i dunno when, but next time i have to be in Joisey, i wanna look > you up again. you are comp.dsp's sage. > > On 12/24/12 5:59 PM, Jerry Avins wrote: >> On 12/23/2012 4:33 PM, robert bristow-johnson wrote: >> >> ... >> >> > there's just no way around the property of periodicity. >> >> Sure there is. There are people around who actually believe that the >> world ended when the Mayan calender is purported to have said it would, >> and that what we experience now is merely a periodic extension. > > well, an interesting thought that i first heard from Daniel Dennett to > support his thesis of physicalism and to deal with the issue of > consciousness or qualia is that we are essentially automatons who > *think* they have consciousness.I believe that... for everyone else. I have no way to distinguish whether you are conscious or a very well programmed automaton. But I know I am conscious. I think, therefore I am conscious. Rick
Reply by ●December 26, 20122012-12-26
On 12/25/12 10:15 PM, rickman wrote:> On 12/24/2012 10:13 PM, robert bristow-johnson wrote: >> >> Jerry, i dunno when, but next time i have to be in Joisey, i wanna look >> you up again. you are comp.dsp's sage. >> >> On 12/24/12 5:59 PM, Jerry Avins wrote: >>> On 12/23/2012 4:33 PM, robert bristow-johnson wrote: >>> >>> ... >>> >>> > there's just no way around the property of periodicity. >>> >>> Sure there is. There are people around who actually believe that the >>> world ended when the Mayan calender is purported to have said it would, >>> and that what we experience now is merely a periodic extension. >> >> well, an interesting thought that i first heard from Daniel Dennett to >> support his thesis of physicalism and to deal with the issue of >> consciousness or qualia is that we are essentially automatons who >> *think* they have consciousness. > > I believe that... for everyone else. I have no way to distinguish > whether you are conscious or a very well programmed automaton. But I > know I am conscious. I think, therefore I am conscious.so you are a being with consciousness and feelings but everyone else are sophisticated automatons? are you the only such being? i dunno what this would be called, but could we apply a sorta "Copernican principle" but replace "the Earth" with "oneself"? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On Tue, 25 Dec 2012 22:15:45 -0500, rickman <gnuarm@gmail.com> wrote:>On 12/24/2012 10:13 PM, robert bristow-johnson wrote: >> >> Jerry, i dunno when, but next time i have to be in Joisey, i wanna look >> you up again. you are comp.dsp's sage. >> >> On 12/24/12 5:59 PM, Jerry Avins wrote: >>> On 12/23/2012 4:33 PM, robert bristow-johnson wrote: >>> >>> ... >>> >>> > there's just no way around the property of periodicity. >>> >>> Sure there is. There are people around who actually believe that the >>> world ended when the Mayan calender is purported to have said it would, >>> and that what we experience now is merely a periodic extension. >> >> well, an interesting thought that i first heard from Daniel Dennett to >> support his thesis of physicalism and to deal with the issue of >> consciousness or qualia is that we are essentially automatons who >> *think* they have consciousness. > >I believe that... for everyone else. I have no way to distinguish >whether you are conscious or a very well programmed automaton. But I >know I am conscious. I think, therefore I am conscious. > >RickSo you think. You can't prove that your consciousness isn't deterministic and therefore programmed. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
